PQ50WS-25S-UNIT
PQ50WS-25S-UNIT
    HRS(广濑)
    CONN CBL PLUG 25POS CRIMP CASE F
PQ50WS-25S-UNIT 数据手册
High Power/Signal Connectors for Industrial Machinery PQ Series Variations Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PQ50W Non water-resistant 20 position type Non water-resistant 48 position type Water-resistant 50 pos. type Contact (19A/pin) type Contact (12.5A/pin) type Contact (12.5A/pin) type PQ50S ■General PQ50 The PQ series is an interface connector designed to handle high power/signal connections in industrial machinery. Available in a water-resistant or non-waterresistant type, they are capable of handling up to 12.5A/ pin (PQ50S and PQ50W) or 19A/pin (PQ50). ■Features Side locking structure emits a tactile click and produces a secure lock PQ50 and PQ50S Series [ Non water-resistant type ] Clear tactile click! 1. Side locking spring structure delivers a clear tactile click. The left and right buttons disengage the mated lock. (Side locking system). The easy mating operation delivers a clear tactile click. (Fig.1) 2. Strengthened cable clamps Cable clamp strength is 98N or more. (* Actual is 400N or more.) The structure will prevent the mated connecter and clamp from detaching against excessive forces. Easy extraction Fig.1 3. Different cover options A robust, enhanced, shielded die-cast shell is available on the PQ50 series or a engineered, light weight plated plastic resin shell for the PQ50S series. The die cast shell delivers an enhanced EMI shield on the PQ50 series and the plated plastic resin of the PQ50S series’ cover case and panel shell ensure ESD and EMI performance. It is possible to insert the terminated housing from the rear Panel Shell M3 Screw Housing 4. Coding key system provides flexibility with multiple options The coding key system prevents incorrect mating and has multiple variations available. Chassis Panel Female Contact 5. Rear mounted panel shell is available. After attaching the panel shell to the chassis, it is possible to install or remove the crimp housing. (Fig.2) 6. Reliable ground connection structure. Fig.2 Easy and reliable ground connection The crimp contacts can be mounted directly onto the panel shell with screws which enhances the grounding connections. (Fig.3) 7. Supports NFPA79 compliant cables (with 600V capability). (PQ50 Series) Due to restrictions on the AWM cables by NFPA79 revision, the requirements of listed cables has increased for wires used in industrial machines in the U.S.A. This product complies with the restrictions and requirements of NFPA79. JIS C2805 (R type, N type) or equivalent Fig.3 In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2017.3③ 1 PQ Series●High Power/Signal Connectors for Industrial Machinery [Water-resistant type] PQ50W Series Special locking structure with lever 1. Water resistant (IP65) Rated at IP65 when in the mated condition. 2. Special locking structure. Special lever and cam structure delivers easier operation and assists with the insertion and extraction of this connector. (Fig.1) 3. Rear mounted unit offers easy operations. Male and Female plastic crimp case can be installed not only for panel side metal shell but also plug side one. (Fig.2) Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4. Metal plated cover of engineering plastic resin adds strength and EMI protection. This robust connector uses a metal plated material of special engineering plastic for the cover and panel shell to ensure high ESD and EMI performance. Fig.1 Supports mounting from the backside of the panel 5. Independent ground contact structure. Secure grounding is accomplished by use of the plated plastic cover and the independent ground contacts. (Fig.3) Panel Side Plug Side 6. Coding key system provides flexibility with multiple options The coding key system prevents incorrect mating and has multiple variations available. Panel Side:Female Cont. Panel Side:Male Cont. Plug Side: Male Cont. Plug Side: Female Cont. [Contact variations] Fig.2 1. Available contact options Two styles are available; one with 19A/pin contacts or one with 12.5A/pin contacts. Independent Ground Contacts 2. Lance protection structure The side wall of the contact prevents lance deformation and helps to prevent tangled wires. (Fig.4) 3. Sequential contacts of different length are available Two types of different contact length are available for the male contact. (Fig.5) Independent Ground Contacts 4. Highly reliable contact structure The female contact assures a reliable connection by using multiple contact points and a unique spring structure. (Fig.6) Lance Protection Structure [ 19A/pin type ] Male contact Different length sequential contacts [ 19A/pin type ] Lance Sequence Contact (Long) Female contact Fig.3 Highly Reliable Contact Structure [ 19A/pin type ] 3 Point Contact [ 12.5A/pin type ] 2 Point Contact Spring Deflection Spring Deflection Standard Contact [ 12.5A/pin type ] Male contact Lance protection guard Lance Female contact 1.2mm [ 12.5A/pin type ] Two types of contacts can be used depending on application Sequence Contact (Long) Lance protection guard Fig.4 2 1.2mm Multiple contact points and very flexible spring design. Standard Contact Fig.5 Fig.6 PQ Series●High Power/Signal Connectors for Industrial Machinery ■Product Specifications [Non water-resistant type] PQ50 Series Voltage Ratings Current AC/DC 600V With UL1015 16 AWG 19A/pin Items Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1. Contact resistance 2. Insulation resistance 3. Withstand voltage 4. Durability 5. Vibration resistance 6. Shock resistance 7. Temperature cycles 8. Moisture resistance in steady state 9. Salt water spray * Depending on current capacity of the cable used. Specifications 1 10mø max Operating Temp. Range −40ç to +105ç Storage Temp. Range −55ç to +85ç Conditions Measured at 100mA Minimum of 5,000Mø Measured at DC 500V No flashover or breakdown. Contact resistance: Increase by 10mø or less from the initial value. Apply AC 2,200V for one minute. qNo electrical discontinuity of 10µs or more. wNo broken, cracked or loosened parts. qChange of contact resistance: 20mø or less wInsulation resistance: minimum of 1,000Mø eNo broken, cracked or loosened parts. qChange of contact resistance: 20mø max wInsulation resistance: minimum of 1,000Mø (after drying). eNo breakage, cracks or loosened parts. No significant corrosion or damage that impairs functioning. Perform 500 mating cycles. Frequency 10 to 55 Hz (5 min/cycle). With half amplitude 0.75mm, 2 hours each for 3 directions. Acceleration 490m/s2, duration 11ms, half-sine wave, 3 times each for 6 axial directions. Temperature: −55 ➝ +15 to 35 ➝ +105 ➝ +15 to +35ç Time: 30 ➝ 2 to 3 ➝ 30 ➝ 2 to 3 min. Subjected to 5 cycles of time and temp as noted. Left in environment of 60ç ±2° and humidity of 90% to 95% for 96 hours. 5% concentration of salt water spray for 48 hours. (in mated condition) 1 Excluding conductor resistance of the cable. *For test methods not described here, JIS C 5402 is applied. [ Non water-resistant type ] PQ50S Series Voltage Rating Current AC/DC 300V 12.5A/pin Items 1. Contact resistance 2. Insulation resistance 3. Withstand voltage 4. Durability 5. Vibration resistance With UL1007 18 AWG * Depending on current capacity of the cable used. Specifications 1 5mø max 8. Moisture resistance in steady state 9. Salt water spray −40ç to +105ç Storage Temp. Range −55ç to +85ç Conditions Measured at 100mA Minimum of 5,000Mø Measured at DC 500V No flashover or breakdown. Contact resistance: Increase by 10mø or less from the initial value. Apply AC 2,200V for one minute. qNo electrical discontinuity of 10µs or more. wNo broken, cracked or loosened parts. 6. Shock resistance 7. Temperature cycles Operating Temp. Range qChange of contact resistance: 10mø or less wInsulation resistance: Minimum of 1,000Mø eNo broken, cracked or loosened parts. qChange of contact resistance: 10mø or less wInsulation resistance: Minimum of 1,000Mø (after drying). eNo broken, cracked or loosened parts. No significant corrosion or damage that impairs functioning. Perform 500 mating cycles. Frequency 10 to 55 Hz (5 min/cycle) With half amplitude 0.75mm, 2 hours each for 3 directions. Acceleration 490m/s2, duration 11ms, half-sine wave, 3 times each for 6 axial directions. Temperature: −55 ➝ +15 to 35 ➝ +105 ➝ +15 to +35ç Time: 30 ➝ 2 to 3 ➝ 30 ➝ 2 to 3 min. Subjected to 5 cycles of time and temp. as noted. Left in environment of 60ç ±2° and humidity of 90% to 95% for 96 hours. 5% concentration of salt water spray for 48 hours. (in mated condition) 1 Excluding conductor resistance of the cable. *For test methods not described here, JIS C 5402 is applied. 3 PQ Series●High Power/Signal Connectors for Industrial Machinery [ Water-resistant type ] PQ50W Series With 12.5A/pin type contacts Ratings Voltage Current Items 1. Contact resistance 2. Insulation resistance 3. Withstand voltage Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4. Durability 5. Vibration resistance 12.5A/pin AC/DC 300V With UL1007 18 AWG * Depending on current capacity of the cable used. 8. Moisture resistance in steady state 9. Salt water spray 10. Water resistance −40ç to +105ç Storage Temp. Range −55ç to +85ç Specifications Conditions 5mø max 1 Measured at 100mA Minimum of 5,000Mø Measured at DC 500V No flashover or breakdown. Contact resistance : Increase by 10mø or less from the initial value. Apply AC 2,200V for one minute. qNo electrical discontinuity of 10µs or more. wNo broken, cracked or loosened parts. 6. Shock resistance 7. Temperature cycles Operating Temp. Range qChange of contact resistance: 10mø or less wInsulation resistance : 1,000Mø or more eNo broken, cracked or loosened parts. qChange of contact resistance : 10mø or less wInsulation resistance : 1,000Mø or more (after drying) eNo broken, cracked or loosened parts. No significant corrosion or damage that impairs functioning. IP65 Perform 500 mating cycles. Frequency 10 to 55 Hz (5 min/cycle) With half amplitude 0.75mm, 2 hours each for 3 directions. Acceleration 490m/s2, duration 11ms, half-sine wave, 3 times each for 6 axial directions. Temperature : −55 ➝ +15 to 35 ➝ +105 ➝ +15 to +35ç Time : 30 ➝ 2 to 3 ➝ 30 ➝ 2 to 3 min. Subjected to 5 cycles of time and temp. as noted. Left in environment of 60ç ±2° and humidity of 90% to 95% for 96 hours. 5% concentration of salt water spray for 48 hours. (in mated condition) 1 Excluding conductor resistance of the cable. *For test methods not described here, JIS C 5402 is applied. ■Materials / Finish PQ50 Series Item Parts Crimp case Panel Shell Crimp case Crimp case Shell Cover case M4 pan head machine screw Clamp metal Crimp case In-line plug shell In-line cover case M4 pan head machine screw Clamp metal Materials PBT resin Zinc die cast PBT resin Stainless steel Zinc die cast Item Parts Crimp case Receptacle Panel Shell Materials PBT resin Heat-resistant engineering plastic resin Brass PBT resin Stainless steel Heat-resistant engineering plastic resin Steel Brass Receptacle Plug In-line plug Steel Steel PBT resin Finish Black Nickel plating Black Remarks UL94V-0 UL94V-0 Nickel plating -------------- Black UL94V-0 Nickel plating -------------- Finish Black Remarks UL94V-0 Nickel plating -------------- Black UL94V-0 -------------- Zinc die cast Steel Steel PQ50S Series M4 insert nut Crimp case Crimp case Shell Plug Cover case Clamp metal M4 insert nut 4 Nickel plating UL94V-0 -------------- PQ Series●High Power/Signal Connectors for Industrial Machinery PQ50W Series Item Crimp case Parts Crimp case Panel Shell Ground contact O-ring for mating Lock lever Rubber packing Receptacle Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Plug shell Materials PBT resin Heat-resistant engineering plastic resin Stainless steel NBR PA resin NBR Heat-resistant engineering plastic resin Stainless steel Ground contact M2 tapping screw Steel Cover case Gasket NBR Clamp metal (body) Heat-resistant engineering plastic resin Cable clamp M3 insert nut Brass M3 pan head machine screw Steel Plug Finish Black Nickel plating Remarks UL94V-0 UL94V-0 -------------- Black UL94V-0 -------------- Black UL94V-0 Nickel plating Trivalent chromate Nickel plating Red -------------- Black UL94V-0 Nickel plating -------------- Finish Remarks ● Contacts (PQ50, PQ50S, PQ50W) Part No. PQ50 -15PCFA PQ50A -15PCFA PQ50 -15SCFA PQ50 -1618PCFA PQ50A -1618PCFA PQ50 -1618SCFA PQ50 -2022PCFA PQ50A -2022PCFA PQ50 -2022SCFA PQ50S -1822PCFA PQ50SA-1822PCFA PQ50S -1822SCFA PQ50S -2428PCFA PQ50SA-2428PCFA PQ50S -2428SCFA Parts Materials Male contact Female contact Male contact Female contact Male contact Copper alloy Female contact Gold plating (contact area) + Tin plating (barrel area) -------------- Male contact Female contact Male contact Female contact ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Crimp Housing PQ 50 W S − 25 P − UNIT ❶ ❷ ❸ ❹ ❶ Series name ❷ Wiring style ❸ Connector specifications ❹ Contact size ❺ Shell size ❻ Contact type ❼ Shapes ❺ ❻ ❼ PQ Crimping W…Water-resistant type None…Non water-resistant type S…Small contact (12.5A/pin) type None…Standard contact (19A/pin) type 25…25 pos. unit    20…20 pos. unit   48…48 pos. unit P…Male contact S…Female contact … UNIT Rear mount multiple unit (PQ50W) None… (PQ50, PQ50S) ●Crimp contact PQ 50 S A − 1822 PC F A ❶ ❷ ❸ ❹ ❶ Series name ❷ Wiring style ❸ Contact size ❹ Contact usage ❺ Applicable cable type ❻ Contact type ❼ Contact shapes ❽ Contact plating type ❺ ❻ ❼ ❽ PQ Crimping S…Small contact (12.5A/pin) type A…Sequence contact (long contact) 15…… 14 to 15 AWG (UL1015) 1618…16 to 18 AWG (UL1007, UL1015) 1822…18 to 22 AWG (UL1007) 17 AWG PC…Male contact F…End-to-end contacts (on reel) A…Gold plating (contact area) None…Standard contact (19A/pin) type None…Standard contact 2022…20 to 22 AWG (UL1007, UL1015) 2428…24 to 28 AWG (UL1007) 23 AWG SC…Female contact None…Discrete contacts 5 PQ Series●High Power/Signal Connectors for Industrial Machinery ● Clamp metal PQ W − CM (17.5) ❶ ❷ ❸ ❶ Series name ❷ Connector specifications ❸ Clamp name ❹ Applicable cable diameter ❹ PQ W…Water-resistant type CM…Clamp metal (15.0)…For applicable cable diameter Ø15.0 (17.5)…For applicable cable diameter Ø17.5 (22.0)…For applicable cable diameter Ø22.0 None…Non water-resistant type PQ50, PQ50S Series Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PQ 50 S − 48 P − PC M ❶ ❷ ❸ ❹ ❶ Series name ❷ Wiring style ❸ Contact size ❹ Shell size ❺ Contact type ❺ ❻ ❼ PQ Crimping S…Small contact (12.5A/pin) type 20…20 pos. shell type P…Male contact PC…Plug cover case FL … Panel shell M…Heat-resistant engineering plastic resin ❻ Case type ❼ Case material None…Standard contact (19A/pin) type 48…48 pos. shell type S…Female contact JC … In-line plug cover case DS…In-line plug shell None…Zinc die cast PQ50W Series PQ 50 W − 50 − PC ❶ ❷ ❸ ❹ ❶ Series name ❷ Wiring style ❸ Connector specifications ❹ Shell size ❺ Case type ❺ PQ Crimping Water-resistant type 50…50 pos. shell type PC…Plug cover case FL … Panel shell ■Functional Diagram PQ50, PQ50S Series qPanel mount receptacle (Female contact) wCable plug eIn-line cable plug (Male contact) (Female contact) PQ50W Series qPanel mount receptacle 6 wCable plug PQ Series●High Power/Signal Connectors for Industrial Machinery ■Panel mount receptacle PQ50 Series ■Crimp case (19A/pin, for female contact) 8.6 18.6 27 28.4 (P=4.6) 27.8 25.6 13 1.7 (P=6.2) 6.2 27.1 18.4 9.2 236-2014-2 00 50 pcs/box PQ50-20S(01) 236-2014-2 01 1 pcs/box R2MAX (39.4) X MA R2 38.6 19.4 31.2 27.2(intersection) Part No. HRS No. Packaging PQ50-20S-FL 236-2001-0 00 50 pcs/box PQ50-20S-FL(01) 236-2001-0 01 1 pcs/box 38.4 48 Recommended panel dimensions for attaching panel shell from panel’s front side. 21 31.2 10.7 3 43.2 13.2(intersection) 10.5 48.6±0.3 51.5±0.1 X MA 21 (intersection) ■Panel Shell 63 51.5 48 38.6 40.6±0.3 2-M3×0.5 (through hole) 33.2±0.3 PQ50-20S 40.6±0.3 R2MAX 46.6 33.2±0.3 Packaging 16.6±0.1 22.1±0.3 HRS No. R2 2-M4×0.7(through hole) 2-M3×0.5(through hole) 2-Ø4.3±0.2 R2 28.4±0.3 51.5±0.1 MA X AX M R2 Recommended panel dimensions for attaching panel shell from panel’s back side. ■Cable Plug PQ50 Series ■Crimp case (19A/pin, for male contact) (P=4.6) E D C (P=6.2) 6.2 27 18.4 9.2 B 33.3 A A 12.8 8.8 3 18.6 28.6 2 B C D E 1 1 2 3 4 4 PQ50-20P (48.8) Part No. HRS No. Packaging PQ50-20P 236-2011-4 00 50 pcs/box PQ50-20P(01) 236-2011-4 01 1 pcs/box 27 ■Plug Cover case 2 34.2 42.8 (16) JIS B 1188 M4×0.7×16 M4×0.7 M4×0.7×8.1 Ø4 . 56.5 64 3 M4×0.7×9 Part No. HRS No. Packaging PQ50-20P-PC 236-2000-8 00 50 pcs/box PQ50-20P-PC(01) 236-2000-8 01 1 pcs/box 48.8 33.2 28 17.6 11.5 12.5 15.1 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. 16.6±0.1 21±0.3 PQ50-20S R1 2.5 7 PQ Series●High Power/Signal Connectors for Industrial Machinery ■In-Line Cable Plug PQ50 Series 2 ■ In-line Plug Cover case JIS B 1188 M4×0.7×16 (16) 38.6 42.8 M4×0.7 M4×0.7×8.1 Ø4 . 56.5 64 3 M4×0.7×9 17.6 48.8 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HRS No. Packaging PQ50-20S-JC 236-2002-3 00 50 pcs/box PQ50-20S-JC(01) 236-2002-3 01 1 pcs/box 33.2 28 11.5 12.5 15.1 Part No. R1 2. 5 ■In-line Plug shell 40.5 38.6 10.2 31.2 33 33.1 27.2 Part No. HRS No. Packaging PQ50-20S-DS 236-2015-5 00 50 pcs/box PQ50-20S-DS(01) 236-2015-5 01 1 pcs/box ■ Cable Plug PQ50S Series ■Crimp case (12.5A/pin, for male contact) (P=3.85) 3.85 11.55 34 26.25 18.75 11.25 F E D C B 12.8 G A 19.25 28.6 1 2 3 4 5 6 8.8 H 33.3 3.75 (P=3.75) A B C D E 1 2 3 4 5 6 PQ50S-48P (55.8) Part No. HRS No. Packaging PQ50S-48P 236-2023-3 00 60 pcs/box PQ50S-48P(01) 236-2023-3 01 1 pcs/box ■Plug Cover case (16) JIS B 1188 M4×0.7×16 50 M4×0.7×6.5 Ø4 . 64 79 3 M4×0.7×6.5 Packaging PQ50S-48P-PCM 236-2003-6 00 60 pcs/box PQ50S-48P-PCM(01) 236-2003-6 01 1 pcs/box 17.6 56 38.2 28 5 2. R1 HRS No. 14 17.6 Part No. 8 M4×0.7 F G H PQ Series●High Power/Signal Connectors for Industrial Machinery ■Panel mount receptacle PQ50S Series ■Crimp cace (12.5A/pin, for female contact) 1.7 8.6 13.15 19.25 27 28.4 P=3.75 27.95 25.75 P=3.85 11.55 34.1 26.25 18.75 11.25 H G F E D C B A 1 2 3 4 5 6 PQ50S-48S 236-2024-6 00 60 pcs/box PQ50S-48S(01) 236-2024-6 01 1 pcs/box 58.5±0.1 47.6±0.3 (46.4) 2-M3×0.7 (through hole) 10.7 7.6 14.8 45.6 21.8 11.3 R2MAX 59.6±0.3 R2 MAX 58.5±0.1 47.6±0.3 Packaging PQ50S-48S-FLM 236-2004-9 00 60 pcs/box PQ50S-48S-FLM(01) 236-2004-9 01 1 pcs/box 49.4 35.1 (intersection) 57.6 56 (intersection) ■Clamp metal common for PQ50 and PQ50S Series 33.2±0.3 HRS No. 2-Ø4.3±0.2 Part No. R2MAX Recommended panel dimensions for attaching panel shell from panel’s front side. 31.2 69.7 58.5 56 (intersection) 45.6 16.6±0.1 21.8±0.3 ■Panel Shell 16.6±0.1 22.8±0.3 Packaging 33.2±0.3 HRS No. M4×0.7×6.5 R2 MAX R2 MAX Recommended panel dimensions for attaching panel shell from panel’s back side. 36.3±0.3 ■Clamp metal for Ø15.0mm cable type 37.16 JIS B 1188 M4×0.7×12 M4×0.7 5.5 1.6 (12) 2-4.4 45.4 23.5 (intersection) HRS No. Packaging PQ-CM(15.0) 236-2005-1 00 60 pcs/box PQ-CM(15.0)(01) 236-2005-1 01 1 pcs/box 15 10 Part No. ■Clamp metal for Ø22.0mm cable type 37.16 JIS B 1188 M4×0.7×12 (12) 2-4.4 HRS No. Packaging PQ-CM(22.0) 236-2013-0 00 50 pcs/box PQ-CM(22.0)(01) 236-2013-0 01 1 pcs/box 11.9 Part No. 1.5 45.4 27 M4×0.7 22 10 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. R2M AX PQ50S-48S 9 PQ Series●High Power/Signal Connectors for Industrial Machinery ■Cable Plug PQ50W Series ■Crimp case (12.5A/pin, for male contact) 16.85 20.6 No.A1 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. No.A5 Part No. HRS No. Packaging PQ50WS-25P-UNIT 236-2021-8 00 1 pcs/box No.E1 23.9 14.8 24.9 7.4 19.5 15 7.5 No.E5 ■Crimp case (12.5A/pin, for female contact) 19.5 15 7.5 Part No. HRS No. Packaging PQ50WS-25S-UNIT 236-2022-0 00 1 pcs/box No.E1 No.A1 No.E5 No.A5 23.9 14.8 24.9 7.4 16.85 20.6 ■Panel mount receptacle PQ50W Series 34.9 35.8 ■Panel Shell (36.3) (5) (28) (102) PQ50W Part No. PQ50W-50-FL HRS No. Packaging 236-2020-5 00 1 pcs/box B 44.3 65.8 B 58.8±0.1 50±0.1 23.4±0.1 27.4±0.1 R2.5MAX 4-M3 (through hole) Panel dimensions for attaching panel shell from panel’s front side. 10 PQ Series●High Power/Signal Connectors for Industrial Machinery ■Cable Plug PQ50W Series ■Cover Case Part No. HRS No. Packaging PQ50W-50-PC 236-2018-3 00 1 pcs/box (2.45) 55.5 31 35.9 ■Metal Cable Clamp for PQ50W Series ■Cable clamp for Ø17.5mm cable type 34 35.5 27 28 (3) Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 65.5 80.5 31.5 Part No. HRS No. Packaging PQW-CM(17.5) 236-2019-6 00 1 pcs/box 11 PQ Series●High Power/Signal Connectors for Industrial Machinery Crimp Contacts ■Male contact (19A/pin type) PQ50A-**PC*A 2.2 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3 Part No. 24.35 23.15 PQ50-**PC*A 0.9 3.8 HRS No. 2.2 0.9 3 3.8 Packaging Applicable Cables PQ50 -15PCFA(Note) 236-2016-8 00 3,500 pcs/reel 14 to 15 AWG (UL1015) insulator outer diameter max. Ø3.3mm PQ50A-15PCFA 236-2073-1 00 3,500 pcs/reel 14 to 15 AWG (UL1015) insulator outer diameter max. Ø3.3mm PQ50 -1618PCFA 236-2006-4 00 3,500 pcs/reel 16 to 18 AWG (UL1007, UL1015), insulator outer diameter max. Ø3.3mm PQ50A-1618PCFA 236-2007-7 00 3,500 pcs/reel 16 to 18 AWG (UL1007, UL1015), insulator outer diameter max. Ø3.3mm PQ50 -2022PCFA 236-2031-1 00 3,500 pcs/reel 20 to 22 AWG (UL1007, UL1015), insulator outer diameter max. Ø2.7mm PQ50A-2022PCFA 236-2032-4 00 3,500 pcs/reel 20 to 22 AWG (UL1007, UL1015), insulator outer diameter max. Ø2.7mm PQ50 -15PCA 236-2037-8 00 100 pcs/pack 14 to 15 AWG insulator outer diameter max. Ø3.3mm PQ50A-15PCA 236-2073-1 00 100 pcs/pack 14 to 15 AWG insulator outer diameter max. Ø3.3mm PQ50 -1618PCA 236-2038-0 00 100 pcs/pack 16 to 18 AWG (UL1007, UL1015), insulator outer diameter max. Ø3.3mm PQ50A-1618PCA 236-2040-2 00 100 pcs/pack 16 to 18 AWG (UL1007, UL1015), insulator outer diameter max. Ø3.3mm PQ50 -2022PCA 236-2039-3 00 100 pcs/pack 20 to 22 AWG (UL1007, UL1015), insulator outer diameter max. Ø2.7mm PQ50A-2022PCA 236-2041-5 00 100 pcs/pack 20 to 22 AWG (UL1007, UL1015), insulator outer diameter max. Ø2.7mm Note : Please see ATAI-E2926 for the details of UL1015 14 AWG cable crimping. 18.9 ■Female contact (19A/pin) type 2.9 3 Part No. HRS No. 3.9 Packaging Applicable Cables PQ50-15SCFA(Note) 236-2017-0 00 3,500 pcs/reel 14 to 15 AWG (UL1015) insulator outer diameter max. Ø3.3mm PQ50-1618SCFA 236-2008-0 00 3,500 pcs/reel 14 to 15 AWG (UL1007, UL1015), insulator outer diameter max. Ø3.3mm PQ50-2022SCFA 236-2010-1 00 3,500 pcs/reel 20 to 22 AWG (UL1007, UL1015), insulator outer diameter max. Ø2.7mm PQ50-15SCA 236-2043-0 00 100 pcs/pack 14 to 15 AWG (UL1007, UL1015), insulator outer diameter max. Ø3.3mm PQ50-1618SCA 236-2044-3 00 100 pcs/pack 16 to 18 AWG (UL1007, UL1015), insulator outer diameter max. Ø3.3mm PQ50-2022SCA 236-2045-6 00 100 pcs/pack 20 to 22 AWG (UL1007, UL1015), insulator outer diameter max. Ø2.7mm Note : Please see ATAI-E3038 for the details of UL1015 14 AWG cable crimping. 12 PQ Series●High Power/Signal Connectors for Industrial Machinery Crimp Contacts ■Male contact (12.5A/pin type) PQ50S-****PC*A PQ50SA-****PC*A Wire gauge marking 23.2 0.7 2.15 2.25 Part No. 1.35 2.15 HRS No. Packaging 0.7 2.25 Applicable Cables PQ50S -1822PCFA 236-2025-9 00 6,000 pcs/reel 17 to 22 AWG (UL1007), insulator outer diameter max. Ø2.25mm PQ50SA-1822PCFA 236-2029-0 00 6,000 pcs/reel 17 to 22 AWG (UL1007), insulator outer diameter max. Ø2.25mm PQ50S -2428PCFA 236-2027-4 00 6,000 pcs/reel 23 to 28 AWG (UL1007), insulator outer diameter max. Ø1.8mm PQ50SA-2428PCFA 236-2030-9 00 6,000 pcs/reel 23 to 28 AWG (UL1007), insulator outer diameter max. Ø1.8mm PQ50S -1822PCA 236-2046-9 00 100 pcs/pack 17 to 22 AWG (UL1007), insulator outer diameter max. Ø2.25mm PQ50SA-1822PCA 236-2048-4 00 100 pcs/pack 17 to 22 AWG (UL1007), insulator outer diameter max. Ø2.25mm PQ50S -2428PCA 236-2047-1 00 100 pcs/pack 23 to 28 AWG (UL1007), insulator outer diameter max. Ø1.8mm PQ50SA-2428PCA 236-2049-7 00 100 pcs/pack 23 to 28 AWG (UL1007), insulator outer diameter max. Ø1.8mm ■Female contact (12.5A/pin type) 2.15 1822S Wire gauge marking 17.8 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1822P 1822P 1.35 24.4 Wire gauge marking 2.15 2.25 Part No. PQ50S-1822SCFA HRS No. Packaging Applicable Cables 236-2026-1 00 6,000 pcs/reel 17 to 22 AWG (UL1007), insulator outer diameter max. Ø2.25mm PQ50S-2428SCFA 236-2028-7 00 6,000 pcs/reel 23 to 28 AWG (UL1007), insulator outer diameter max. Ø1.8mm PQ50S-1822SCA 236-2050-6 00 100 pcs/pack 17 to 22 AWG (UL1007), insulator outer diameter max. Ø2.25mm PQ50S-2428SCA 236-2051-9 00 100 pcs/pack 23 to 28 AWG (UL1007), insulator outer diameter max. Ø1.8mm 13 PQ Series●High Power/Signal Connectors for Industrial Machinery Coding Key System ■For 19A/pin type crimp case 3 2.9 5.95 27.7 24.8 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. PQ50-SC-KY HRS No. Packaging 236-2009-2 00 100 pcs/pack ■For 12.5A/pin type crimp case 27.8 3.05 1.8 2.23 23.7 Part No. PQ50S-SC-KY HRS No. Packaging 236-2033-7 00 100 pcs/pack Contact Extraction Tools ■For 19A/pin type crimp housing Ø7 80 PQ50/RE-MD Part No. PQ50/RE-MD HRS No. Packaging 902-2201-0 00 1 pcs/box ■For 12.5A/pin type crimp housing PQ 50 S/RE-MD Part No. PQ50S/RE-MD 14 Ø10 75 HRS No. Packaging 902-2202-2 00 1 pcs/box PQ Series●High Power/Signal Connectors for Industrial Machinery Hand Crimp Tool The complete hand tool with crimper frame (1) is available for each terminal and wire gauge. Parts (2) to (8) can be ordered to accommodate repairs and to be able to switch to other wire gauges without having to purchase another complete tool. Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ①Crimper Frame Part No. HT702 qCrimper Frame HRS No. 250-1001-1 00 * Unit Name Upper row: Part No. Lower row: HRS No. PQ50-1618(1007) 【250-1002-4】 PQ50-1618(1015) 【250-1003-7】 PQ50A-1618(1007) 【250-1004-0】 PQ50A-1618(1015) 【250-1005-2】 PQ50-2022(1007) 【250-1006-5】 PQ50-2022(1015) 【250-1007-8】 HT702 【250-1001-1】 Switch wire crimper and insulation crimper die according to the wire size being used. PQ50A-2022(1007) 【250-1008-0】 PQ50A-2022(1015) 【250-1009-3】 Applicable Cables Applicable Contacts PQ50-1618PCA PQ50-1618SCA PQ50 -1618PCA PQ50A-1618PCA PQ50-2022PCA PQ50-2022SCA PQ50 -2022PCA PQ50A-2022PCA UL UL1007 UL1015 UL1007 UL1015 UL1007 UL1015 UL1007 UL1015 AWG 16 18 16 18 16 18 16 18 20 22 20 22 20 22 20 22 wIC (Insulation Crimper) 286191 【250-1002-4(61)】 285990 【250-1003-7(61)】 286191 【250-1004-0(61)】 285990 【250-1005-2(61)】 286197 【250-1006-5(61)】 286193 【250-1007-8(61)】 286197 【250-1008-0(61)】 286193 【250-1009-3(61)】 PQ50-14(1015) 【250-1019-7】 PQ50-15PCA PQ50-15SCA UL1015 14 286629 【250-1019-7(61)】 PQ50A-14(1015) 【250-1021-9】 PQ50 -15PCA PQ50A-15PCA UL1015 14 286629 【250-1021-9(61)】 PQ50S-1820(1007) 【250-1010-2】 PQ50S-2022(1007) 【250-1011-5】 PQ50SA-1820(1007) 【250-1012-8】 PQ50SA-2022(1007) 【250-1013-0】 18 PQ50S-1822PCA PQ50S-1822SCA UL1007 20 22 18 PQ50SA-1822PCA UL1007 20 22 286219 【250-1010-2(61)】 286220 【250-1011-5(61)】 286219 【250-1012-8(61)】 286220 【250-1013-0(61)】 Ex.: When unit PQ50-1618 (1007) is purchased as a whole, all of parts (2) through (8) are included. If the insulation crimper (IC) only is needed for PQ50-1618(1007), then 250-1002-4 61 should be ordered. 15 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PQ Series●High Power/Signal Connectors for Industrial Machinery Powered by TCPDF (www.tcpdf.org) Upper row: Part No. / Lower row: HRS No. uContact Holder eWC rIA tWA iCrimper Spacer yContact Holder A B/C (Wire Crimper) (Insulation Anvil) (Wire Anvil) 285991 285992 285993 285994 285995 285996 【250-1002-4(62)】 【250-1002-4(63)】 【250-1002-4(64)】 【250-1002-4(65)】 【250-1002-4(66)】 【250-1002-4(67)】 285991 285992 285993 285994 285995 285996 【250-1003-7(62)】 【250-1003-7(63)】 【250-1003-7(64)】 【250-1003-7(65)】 【250-1003-7(66)】 【250-1003-7(67)】 285991 285992 285993 285994 286192 285996 【250-1004-0(62)】 【250-1004-0(63)】 【250-1004-0(64)】 【250-1004-0(65)】 【250-1004-0(66)】 【250-1004-0(67)】 285991 285992 285993 285994 286192 285996 【250-1005-2(62)】 【250-1005-2(63)】 【250-1005-2(64)】 【250-1005-2(65)】 【250-1005-2(66)】 【250-1005-2(67)】 286194 285992 286196 285994 285995 285996 【250-1006-5(62)】 【250-1006-5(63)】 【250-1006-5(64)】 【250-1006-5(65)】 【250-1006-5(66)】 【250-1006-5(67)】 286194 285992 286196 285994 285995 285996 【250-1007-8(62)】 【250-1007-8(63)】 【250-1007-8(64)】 【250-1007-8(65)】 【250-1007-8(66)】 【250-1007-8(67)】 286194 285992 286196 285994 286192 285996 【250-1008-0(62)】 【250-1008-0(63)】 【250-1008-0(64)】 【250-1008-0(65)】 【250-1008-0(66)】 【250-1008-0(67)】 286194 285992 286196 285994 286192 285996 【250-1009-3(62)】 【250-1009-3(63)】 【250-1009-3(64)】 【250-1009-3(65)】 【250-1009-3(66)】 【250-1009-3(67)】 286630 286631 286632 285994 285995 285996 【250-1019-7(62)】 【250-1019-7(63)】 【250-1019-7(64)】 【250-1019-7(65)】 【250-1019-7(66)】 【250-1019-7(67)】 286630 286631 286632 285994 286192 285996 【250-1021-9(62)】 【250-1021-9(63)】 【250-1021-9(64)】 【250-1021-9(65)】 【250-1021-9(66)】 【250-1021-9(67)】 286223 286225 286226 286233 286234 285996 【250-1010-2(62)】 【250-1010-2(63)】 【250-1010-2(64)】 【250-1010-2(65)】 【250-1010-2(66)】 【250-1010-2(67)】 286224 286225 286226 286233 286234 285996 【250-1011-5(62)】 【250-1011-5(63)】 【250-1011-5(64)】 【250-1011-5(65)】 【250-1011-5(66)】 【250-1011-5(67)】 286223 286225 286226 286233 286235 285996 【250-1012-8(62)】 【250-1012-8(63)】 【250-1012-8(64)】 【250-1012-8(65)】 【250-1012-8(66)】 【250-1012-8(67)】 286224 286225 286226 286233 286235 285996 【250-1013-0(62)】 【250-1013-0(63)】 【250-1013-0(64)】 【250-1013-0(65)】 【250-1013-0(66)】 【250-1013-0(67)】 Ex.: When unit PQ50-1618 (1007) is purchased as a whole, all of parts (2) through (8) are included. If the insulation crimper (IC) only is needed for PQ50-1618(1007), then 250-1002-4 61 should be ordered. ® 16 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 03/2017. Contents are subject to change without notice for the purpose of improvements.
PQ50WS-25S-UNIT 价格&库存
很抱歉,暂时无法提供与“PQ50WS-25S-UNIT”相匹配的价格&库存,您可以联系我们找货
