QTE-060-01-L-D-A-RT1
    SAMTEC(申泰)
    .8MM DOUBLE ROW MI TERMINAL ASSE
QTE-060-01-L-D-A-RT1 数据手册
® (0.80 mm) .0315" PITCH • QTE/QSE SERIES QTE Board Mates: QSE QTE - QSE - LEAD STYLE –020, –040, –060 Board Mates: QTE –014, –028, –042 Cable Mates: EQCD, EQDP Standoffs: SO - = Gold flash on contact, Matte Tin on tail –L = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail (14 pairs per bank = –D–DP) SPECIFICATIONS Insulator Material: Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: Contact: 2 A per pin (2 pins powered) Ground Plane: 23 A per ground plane (1 ground plane powered) Operating Temp Range: -55 °C to +125 °C Voltage Rating: 225 VAC when mated & 5 mm Stack Height Max Cycles: 100 - A –D A HEIGHT WITH QSE* –01 (4.27) .168 (5.00) .197 –02 (7.26) .286 (8.00) .315 –03 (10.27) .404 (11.00) .433 –04 (15.25) .600 (16.00) .630 –05 (18.26) .718 (19.00) .748 –07 (24.24) .954 (25.00) .984 –09 (13.26) .522 (14.00) .551 OTHER OPTIONS - –K = SingleEnded –D–DP = Differential Pair (–01 only) ”X”R Leave blank for Tray Packaging = (7.00 mm) .275" DIA Polyimide film Pick & Place Pad –TR =Tape & Reel (Not available with –05 & –07 lead style) –L = Latching Option (N/A on –042 & –060 positions) = 50 µ" (1.27 µm) Electro-Polished Selective Gold on contact, Matte Tin on tail (passes 10 year MFG testing) –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (Not available with –05 & –07 lead style) –D–DP = (No. of Positions per Row/14) x (20.00) .7875 –D = (No. of Positions per Row/20) x (20.00) .7875 (5.97) .235 *Processing conditions will affect mated height. See SO Series for board space tolerances. (7.11) .280 (0.76) .030 A View complete specifications at: samtec.com?QTE QSE - PINS PER ROW NO. OF PAIRS - - –F = Gold flash on contact, Matte Tin on tail (40 total pins per bank = –D) –L –014, –028, –042 =10 µ" (0.25 µm) Gold on contact, Matte Tin on tail (14 pairs per bank = –D–DP) EXTENDED LIFE PRODUCT - TYPE –D = SingleEnded –D–DP = Differential Pair –C HIGH MATING CYCLES –D–DP = (No. of Positions per Row/14) x (20.00) .7875 + (1.27) .050 –D = (No. of Positions per Row/20) x (20.00) .7875 + (1.27) .050 (7.24) .285 PLATING OPTION 01 –020, –040, –060 10 YEAR MFG = 50 µ" (1.27 µm) Electro-Polished Selective Gold on contact, Matte Tin on tail (passes 10 year MFG testing) - A OTHER OPTIONS –GP = Guide Post –K = (8.25 mm) .325" DIA Polyimide Film Pick & Place Pad –L = Latching Option (Not available on –042 & –060 positions) - ”X”R Leave blank for Tray Packaging –TR =Tape & Reel (40 positions max. with –GP) –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (40 positions max. with –GP) (7.49) .295 (3.25) .128 F-224 TYPE –C QTE LEAD STYLE PROCESSING Note: Some lengths, styles and options are non-standard, non-returnable. - PLATING OPTION –F Specify LEAD STYLE from Chart (40 total pins per bank = –D) QTE/QSE Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (020-060) Board Stacking: For applications requiring more than two connectors contact ipg@samtec.com PINS PER ROW NO. OF PAIRS (0.76) .030 (3.05) .120 View complete specifications at: samtec.com?QSE samtec.com/QStrip Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
QTE-060-01-L-D-A-RT1 价格&库存
很抱歉,暂时无法提供与“QTE-060-01-L-D-A-RT1”相匹配的价格&库存,您可以联系我们找货
