IP68 SEALED
USB PANEL MOUNT
RPBU, RPCU SERIES
RPBU
Mates wtih:
RCU (Single Port only)
RPBU
NO. OF
PORTS
–01
SPECIFICATIONS
–02
–VT
= USB A Type
–B
OPTION
–LC
= Vertical
Through-hole
= Locking Clip
(–VT only)
–RA
= USB B Type
(45.20) 1.780
LEAD STYLE
–A
= 30 µ"
(0.76 µm)
Gold on
contact,
Matte tin
on tail
= Dual Port
(–A only)
TYPE
–S
= Single Port
Insulator Material:
Black Liquid Crystal Polymer
Contact:
Phosphor Bronze
Current Rating:
4.2 A per pin
(1 pin powered)
Operating Temp Range:
-20 °C to +80 °C
Seal: Silicone
Lead-Free Solderable:
Yes
PLATING
= Right-angle
A
(20.50)
.807
(16.80)
.661
TYPE –B
TYPE –A
(36.20) 1.425
(17.06) .672
NO. OF
PORTS
A
B
C
–01
(48.15)
1.896
(39.10)
1.539
(20.01)
.788
–02
(69.80)
2.748
(60.75)
2.392
(42.00)
1.654
B
C
DUST CAPS
DCA-RPBU-01-01-A
(9.53)
.375
–B–VT
RPCU
Mates with:
RCU
RPCU
–B–RA
PLATING
–G
= 30 µ" (0.76 µm)
Gold on contact,
Nickel on shell
SPECIFICATIONS
Insulator Material:
Contact Material:
Phosphor Bronze
-20 °C to +80 °C
Shield Material:
Phosphor Bronze
Wire:
20 AWG (Power)
25 AWG (Signal)
28 AWG (Drain)
–A–VT
DCA-RPBU-02-01-A
DCA-RPBU-01-01-B
–A–RA
CABLE LENGTH
–00.25
= (0.25 m) 9.84" Cable
–00.50
= (0.50 m) 19.68" Cable
Standard lengths
END 1 OPTION
–AMS
END 2 OPTION
AM
= USB A Type,
Sealed
= USB A Type,
Not Sealed
–BMS
–BM
= USB B Type,
Sealed
= USB B Type,
Not Sealed
–BC
(Assembled Length
= Cable Length
+ (42.8 mm) 1.69")
= Blunt Cut
Cable Length + (42.8) 1.69
(15.90)
.626
(20.00)
.787
Note:
Some lengths, styles and
options are non-standard,
non-returnable
–AMS
samtec.com/AccliMate
samtec.com?RPBU
or samtec.com?RPCU
–AM
F-224227
WEB
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
RPCU-G-00.25-BMS-BC 价格&库存
很抱歉,暂时无法提供与“RPCU-G-00.25-BMS-BC”相匹配的价格&库存,您可以联系我们找货
