SCPU-10-G-02.00-MBS-AM 数据手册
F-224 SUPPLEMENT
SCPE–G–02.00–S–O–NP
SCPE, SCPU, SCPFE SERIES
SCPU–17–G–02.00–AMS–AM
IP68 SEALED USB & ETHERNET PLUGS
Mates with:
SCRES
SPECIFICATIONS
For complete specifications
see www.samtec.com?SCPE
Insulator Material:
Polycarbonate
Contact Material:
Phosphor Bronze
Shield Material:
Phosphor Bronze
Wire:
24 AWG
Overmold:
PA66 GF13 FR
Current Rating:
3.8 A per pin (1 pin powered)
Operating Temp Range:
-40 °C to +70 °C
RoHS Compliant:
Yes
–G
SCPE
= 50 µ"
(1.27 µm)
Gold on
Contact,
Nickel on
Shell
= Sealed
Circular
Ethernet
Cable Plug
END
OPTION
WIRE
LENGTH
PLATING
TYPE
–D
–01.00
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
Mates with:
SCRUS
SPECIFICATIONS
see www.samtec.com?SCPU
Insulator Material:
Glass Filled Thermoplastic
Contact Material:
Copper Alloy
Shield Material: CRS
Wire:
20 AWG (Power)
25 AWG (Signal)
28 AWG (Drain)
Sealed Overmold:
PA66 GF13 FR
-20 °C to +75 °C
RoHS Compliant:
Yes
–O
= Double Ended
(Both Ends Sealed)
= (1 m) 39" Cable
–02.00
= Outdoor
Rated
–S
= (2 m) 79" Cable
NP
–NP
= Cat 5e
(No polarization
mates with
SCRES –C5E)
= Single Ended
(End No. 1 Sealed)
Standard lengths
Assembled Length = Wire Length + (3.0) .12
(42.00)
1.65
DUST CAP
• DCA-17-02
O
END NO. 2
(–S)
–S SHOWN
END NO. 1
FIELD TERMINATION KIT
• Ethernet Field Termination Kit available for long cable run and small-opening applications
so housings can be customer-installed after the runs are complete.
• SCPFE-17-G-01 Series (For cable outside diameter range of 5.00-5.75 mm)
• SCPFE-17-G-02 Series (For cable outside diameter range of 5.75-6.50 mm)
SHELL
SIZE
SCPU
PLATING
–G
–17
(Standard USB only)
= 30 µ"
(0.76 µm)
Gold on
Contact,
Nickel on
Shell
WIRE
LENGTH
–01.00
= (1 m) 40" Cable
–02.00
= (2 m) 79" Cable
Standard lengths
(Assembled Length
= Wire Length
+ (19.5 mm) .77")
(42.00) 1.65
END 1
OPTION
–AMS
= USB A Type,
Sealed
ALSO
AVAILABLE
(MOQ REQUIRED)
• Other wire
lengths
END 2
OPTION
–AM
= USB A Type,
Not Sealed
–BMS
= USB B Type,
Sealed
ALSO
AVAILABLE
(MOQ REQUIRED)
• Other wire lengths
• Other end options
–AMS
–BMS
DUST CAPS & PANEL PLUG
Note:
non-returnable.
• Dust Caps: DCA-17-01 or DCA-10-01
• Panel Plug: SCPPA-17-01
–AM
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
SCPU-10-G-02.00-MBS-AM 价格&库存
很抱歉,暂时无法提供与“SCPU-10-G-02.00-MBS-AM”相匹配的价格&库存,您可以联系我们找货
