SDHK-8BNS-K-303-TB(HF)
    JST
SDHK-8BNS-K-303-TB(HF) 数据手册
SDHK CONNECTOR Emboss Tape 1.1 mm pitch/ Micro SD card Flip cover type SDHK CONNECTOR Specifications • Current rating: 0.5 A AC/DC • Voltage rating: 15 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 80 mΩ max. After environmental tests/ 160 mΩ max. • Insulation resistance: 100 MΩ min. • Withstanding voltage: 500 VAC/minute • Applicable card: Micro SD card This is micro SD card cnnector of flip cover type that can approach from above the PC board surface. Connector * In using the products, refer to “Handling Precaution for Terminal and Connector” described on our website (Technical documents of Product information page). * Contact JST for details. * RoHS2 compliance PC board layout 16.2 1.2 ±0.05 ±0.05 ±0.05 11.7 1.9 12.8 Material and Finish Contact: Copper alloy, nickel-undercoated, gold-plated Housing: Heat resisting resin, black Cover: Stainless RoHS2 compliance The product listed above are supplied on embossed-tape. 1 Q'ty/reel 1,400 ±0.05 4.8 3.2 ±0.05 1.9 3.5 9.9 Model No. SDHK-8BNS-K-303-TB(HF) ±0.05 ±0.05 7.7 ±0.05 1.1 8.3 4.7 ±0.05 13 13.4 ±0.05 ±0.05 0.8 1.4 ±0.05 ±0.05 ±0.05
SDHK-8BNS-K-303-TB(HF) 价格&库存
很抱歉,暂时无法提供与“SDHK-8BNS-K-303-TB(HF)”相匹配的价格&库存,您可以联系我们找货
    • 1+6.135621+0.79761
    • 50+4.7895850+0.62263
    • 100+4.27760100+0.55608
    • 300+3.93076300+0.51099
    • 500+3.86470500+0.50240
    • 1000+3.815151000+0.49596
    • 4000+3.773864000+0.49059
    库存:124
    • 4+25.402174+3.30220
    • 10+24.3199210+3.16151
    • 25+20.9039125+2.71744
    • 100+18.52954100+2.40878
    • 500+18.09630500+2.35246
    • 1000+9.082001000+1.18063
    库存:516
      • 1+11.152511+1.44979
      • 50+8.1535950+1.05994
      • 100+7.61466100+0.98988
      • 300+7.25826300+0.94355
      • 500+7.18872500+0.93451
      • 1000+7.136571000+0.92773
      • 2000+7.110492000+0.92434
      • 4000+7.093104000+0.92208
      库存:948
