SDHR-8BRS-K-363-A0-P-ETB(HF)(A) 数据手册
Emboss Tape
SDHR CONNECTOR
For Micro SD card Push-Push type
Specifications
• Current rating: 0.5 A AC, DC
• Voltage rating: 100 V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 100 mΩ max.
After environmental testing/ 80 mΩ max.
(variation from initial value)
• Insulation resistance: 1,000 MΩ min.
• Withstanding voltage: lintial; 500 VAC/minute
After humidity test; 300 VAC/minute
• Applicable card: Micro SD card
This is the cnnector for micro SD card
connector in which mounting height of
1.45mm maximum is kept and push-push
mechanism is adopted.
Connector
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
* Compliant with RoHS.
PC board layout
13.5
±0.05
1±0.05
1.2 ±0.05
3.1±0.05
1.15 ±0.05
Contact: Copper alloy, nickel-undercoated, gold-plated
Housing: Heat resisting resin, black
Shell: Stainless, nickel-undercoated, gold-plated
Card stopper, Crank pin, Spring: Stainless
RoHS compliance This product displays (HF) on a label.
This products listed above are supplied on embossed-tape.
1
0.5 ±0.05
2,000
1.5 ±0.05
3.9
±0.05
2-R0.5
±0.05
1
±0.05
45°
0.7
11.6 ±0.05
13.7
±0.05
*Connector mounted area is pattern prohibition.
±0.05
14.7
3.5
4.3
14.5
±0.05
±0.05
±0.05
±0.05
1
±0.05
1±0.05
1
0.85 ±0.05
±0.05
Q'ty / reel
0.5±0.05
(0.5)
1±0.05
0.5
±0.05
6.75 ±0.05
4.2
Material and Finish
1
1±0.05
±0.05
5.1
6.4
±0.05
±0.05
13.8
±0.05
Model No.
±0.05
0.3±0.05
0.5 ±0.05
0.4
1.4
12.9
0.6
1
0.45 ±0.05
±0.05
0.85 ±0.05
0.5±0.05
±0.05
±0.05
3.5 ±0.05
0.65
±0.05
1±0.05
1.35 ±0.05
4.1
(2.1 When putting in a card)
9.4 ±0.05
(5.6 When releasing a card)
15.3
(1.6 When pushing in a card)
11.25 ±0.05
SDHR-8BRS-K-363-A0-P-ETB(HF)(A) 价格&库存
很抱歉,暂时无法提供与“SDHR-8BRS-K-363-A0-P-ETB(HF)(A)”相匹配的价格&库存,您可以联系我们找货
