F-224 WEB
SL–120–G–10
SDL–125–TT–12
SDL–115–G–19
(2.54 mm) .100"
SL, SDL SERIES
SL–110–TT–11
LOW PROFILE MACHINED SOCKET STRIPS
FEATURES
• Achieve low profile
without sacrificing
insertion depth!
• Choice of four precision
screw machined lead
styles.
• Exceptionally low profile,
down to (2.11 mm) .083"
off of board.
• Mates with BBL or BDL
for board stacking
spaces down to
(3.89 mm) .153"
SPECIFICATIONS
Mates with:
TS, TD, HTS, BBS, BBD,
BBL, BDL, BHS
1
PLATING
OPTION
NO. PINS
PER ROW
LEAD
STYLE
SL
= Single Row Low Profile Socket Strip
SDL
= Double Row Low Profile Socket Strip
thru
(2.54)
.100
(2.54)
.100
TYP
(1.27)
.050
(2.54) .100 X No. of Positions
+ (0.23) .009
(5.08)
.200
–G
= 30 µ" (0.76 µm)
Gold contact,
10 µ" (0.25 µm)
Gold shell
01
+ (0.23) .009
For complete specifications
see www.samtec.com?SL or
www.samtec.com?SDL
Insulator Material:
Black Glass Filled Polyester
(SDL)
Black Liquid Crystal Polymer
(SL)
Contact/Shell Materials:
BeCu/Brass
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
RoHS Compliant:
Yes
Lead-Free Solderable:
SL: Yes
SDL: No, Lead Wave only
TYPE
STRIP
32
–T
= 30 µ" (0.76 µm)
Gold contact,
Tin shell
01
thru
(2.54)
.100
(1.27)
.050
(2.54)
.100
TYP
–TT
36
= Tin contact and shell
(LIF not available)
Low Insertion Force (LIF) Available
–10
= Low Profile
(Hollow Leg)
–11
–19
–12
= Low Profile
(Standard Mount)
For LIF specify –31
= Micro-Socket
(Hollow Leg)
For LIF specify –39
= Micro-Socket
(Hollow Leg)
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
(1.83)
.072 DIA
(1.83)
.072 DIA
FILE NO. E111594
(5.84)
.230
(3.10)
.122
(0.76)
.030
(1.32)
.052
DIA
(0.76)
.030
DIA
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
Contact Length =
(2.11 mm) .083"
Lead DIA Accepted =
(0.38 mm) .015" to (0.51 mm) .020"
Insertion Depth =
(2.67 mm) .105" to (4.32 mm) .170"
Style 10 Component Part No. =
SC-3P1
(6.10)
.240
(1.83)
.072 DIA
(0.51)
.020
(3.35)
.132
(1.32)
.052
DIA
(4.83)
.190
(2.41)
.095
(0.51)
.020
(1.32)
.052
DIA
(4.19)
.165
(4.45)
.175
(1.32)
.052
DIA
(0.74)
.029
DIA
Micro
Socket
Contact Length =
(1.58 mm) .062"
Lead DIA Accepted =
(0.41 mm) .016" to (0.51 mm) .020"
Insertion Depth =
(1.65 mm) .065" to (3.81 mm) .150"
Style 12 Component Part No. =
SC-5P1
(0.25)
.010
(2.11)
.083
(0.76)
.030
DIA
(0.51)
.020
DIA
Contact Length =
(1.58 mm) .062"
Lead DIA Accepted =
(0.41 mm) .016" to (0.53mm) .021"
Insertion Depth =
(2.03 mm) .080" to (2.67 mm) .105"
Style 11 Component Part No. =
SC-4P1
Style 31 Component Part No. =
EZ-4P1
(1.83)
.072 DIA
Standard
Socket
(Reference only.
Not available
with SL & SDL)
Contact Length =
(1.58 mm) .062"
Lead DIA Accepted =
Insertion Depth =
(1.65 mm) .065" to (3.56 mm) .140"
Style 19 Component Part No. =
SC-8P1
Style 39 Component Part No. =
EZ-8P1
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“SDL-128-G-19”相匹配的价格&库存,您可以联系我们找货
