282-681
282-681
    WAGO(万可电子)
    端子块连接器 3 位置 馈通式 灰色 10-24AWG
282-681 数据手册
3-CONDUCTOR THROUGH TERMINAL BLOCK CENTRE MARKING for DIN 35 rail 282-681 PDF Datasheet © 1992 - 2011 CADENAS GmbH 3-CONDUCTOR THROUGH TERMINAL BLOCK CENTRE MARKING for DIN 35 rail 282-681 PDF Datasheet © 1992 - 2011 CADENAS GmbH ITEM-NO. (ITEM-NO.) 282-681 Cross section1 (Cross section / mm²) 0.2 - 6 Cross section2 (Cross section / AWG) 24 - 10 Strip length (Strip length / mm) 12 - 13 Measured voltage (Measured voltage / V) 800 Measured shock voltage (Measured shock voltage / kV) 8 Pollution degree (Pollution degree) 3 Current intensity (Current intensity / A) 41 Height (Height / mm) 32.5 Width (Width / mm) 8 Depth (Depth / mm) 93 No. of connection Points (No. of connection Points) 3 No. of potentials (No. of potentials) 1 COLOR (COLOR) grau WEIGHT (WEIGHT / g) 21.29 Comment (Comment)
282-681 价格&库存
很抱歉,暂时无法提供与“282-681”相匹配的价格&库存,您可以联系我们找货
    • 1+100.708351+13.08905
    • 10+71.4542610+9.28690
    • 25+63.2110325+8.21553
    • 50+58.2242850+7.56740
    • 100+54.18645100+7.04261
    • 250+50.07485250+6.50822
    • 500+47.72116500+6.20232
    • 1000+45.884491000+5.96360
    库存:2204
    282-681
      • 5+82.61089
      库存:540
