793-501
793-501
    WAGO(万可电子)
793-501 数据手册
Printview: WMB Multi marking system; plain; for terminal block width 5 - 17.5 mm; 10 strips with 10 markers per card - Item No.: 793-501 . WMB Multi marking system; plain; for terminal block width 5 - 17.5 mm; 10 strips with 10 markers per card Item No.: 793-501 . WMB Multi marking system; plain; for terminal block width 5 - 17.5 mm; 10 strips with 10 markers per card . Marking . Business data Supplier WAGO Item no. 793-501 GTIN / EAN 4017332542623 Content 1 Order amount 5 Customer item number . Notes Technical data Miscellaneous Color white Fire load [MJ] 0.257 [MJ] Weight [g] 8.522 [g] Marking plain Marker width [mm] 5 [mm] Marker width (max.) [mm] 5 [mm] WAGO Kontakttechnik GmbH & Co. KG 1 Printview: WMB Multi marking system; plain; for terminal block width 5 - 17.5 mm; 10 strips with 10 markers per card - Item No.: 793-501 Images & drawings . WAGO Kontakttechnik GmbH & Co. KG 2 Printview: WMB Multi marking system; plain; for terminal block width 5 - 17.5 mm; 10 strips with 10 markers per card - Item No.: 793-501 Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 3
793-501 价格&库存
很抱歉,暂时无法提供与“793-501”相匹配的价格&库存,您可以联系我们找货
  • 1+94.274781+12.21981
  • 10+80.1420910+10.38794
  • 25+75.1245425+9.73757
  • 50+71.5361350+9.27245
  • 100+68.12094100+8.82977
  • 250+63.85852250+8.27728
  • 500+60.81288500+7.88251
  • 1000+57.913511000+7.50670
库存:337
793-501
    • 1+387.54054
    • 10+379.78223
    库存:360
