793-923
793-923
    WAGO(万可电子)
    WMB Multiple marking system
793-923 数据手册
Printview: WMB Multi marking system; Vertical marking; 2001 ... 2100 (1x); for terminal block width 5 - 17.5 mm; 10 strips with 10 markers per card; consecutive numbers each strip - Item No.: 793-923 . WMB Multi marking system; Vertical marking; 2001 ... 2100 (1x); for terminal block width 5 - 17.5 mm; 10 strips with 10 markers per card; consecutive numbers each strip Item No.: 793-923 . WMB Multi marking system; Vertical marking; 2001 ... 2100 (1x); for terminal block width 5 - 17.5 mm; 10 strips with 10 markers per card; consecutive numbers each strip . Marking . Business data Supplier WAGO Item no. 793-923 GTIN / EAN 4017332921220 Content 1 Order amount 5 Customer item number . Notes Technical data Miscellaneous Color white Fire load [MJ] 0.257 [MJ] Weight [g] 9 [g] Printing direction Vertical marking Marker width [mm] 5 [mm] Marker width (max.) [mm] 5 [mm] WAGO Kontakttechnik GmbH & Co. KG 1 Printview: WMB Multi marking system; Vertical marking; 2001 ... 2100 (1x); for terminal block width 5 - 17.5 mm; 10 strips with 10 markers per card; consecutive numbers each strip - Item No.: 793-923 Images & drawings . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 2
793-923 价格&库存
很抱歉,暂时无法提供与“793-923”相匹配的价格&库存,您可以联系我们找货
