J11SFM-03V-KX
J11SFM-03V-KX
    JST
    P=2.2mm
    1X3P 2.2MM
J11SFM-03V-KX 数据手册
JFA CONNECTOR J1000 SERIES 6 2.2 mm pitcth/Disconnectable Crimp style connectors (For Wire-to-board/Wire-to-wire) JFA CONNECTOR/J1000 SERIES X B 1 A 5 2 ■ Standards J1000 SERIES/J1100 X B 1 A 1 A 2 5 6 X B A J1000 SERIES/J1800 Connectors for signal circuit or power supply circuit, applicable to the factory automation, heavy electric machinery, and other industrial equipment in general. In spite of various kinds of housings available, their contacts are designed to be common. The applicable tooling can be standardized. ・ ・ ・ ・ 1 ®  ouble-spring construction D Up to AWG #18 with 2.2 mm pitch Housing lance Secure locking method ® ® ・Current rating : AC/DC B X 1 : Recognized E 60389 ■ Specifications 6 2 2 3 3 4 4 5 5 6 ® No. of circuits 3 6 8 12 20 22 26 30 #18 6.4 5.5 5.5 4.7 4.0 3.9 3.6 3.6 #20 5.4 4.6 4.6 3.9 3.4 3.3 3.0 3.0 Wire size®(AWG) #24 #22 4.0 4.8 3.4 4.0 3.1 4.0 2.7 3.4 2.4 3.0 2.3 2.9 2.2 2.6 2.1 2.6 Unit : A #26 3.4 2.9 2.6 2.6 2.0 1.9 1.8 1.7 #28 2.8 2.4 2.2 2.0 1.8 1.7 1.6 1.5 ・Voltage rating: 125 V AC/DC…J1100 series 250 V AC/DC…J1800 series ・Temperature range: -55℃ to +105℃ ( including temperature rise in applying electrical current ) ・Applicable wire: AWG #28 to #18 ・Applicable PC board thickness: 1.6 mm * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. JFA CONNECTOR/J1000 SERIES J1000 series products line-up 2.2 mm pitch , Voltage rating 125 V AC/DC Type Wire-to-board Top entry type Wire-to-wire Side entry type Free hanging type JFA CONNECTOR/J1000 SERIES J1100 Single-row type J1000 SERIES/J1100 Center locking type No. of circuits 3 3 3 J1100 Dual-row type J1000 SERIES/J1800 No. of circuits 6, 8, 12, 20, 22, 26, 30 6, 8, 12, 20, 30 6, 8, 12, 20, 26 2.2 mm pitch , Voltage rating 250 V AC/DC Type Side locking type (Thin type) Wire-to-board Top entry type Side entry type 8 8 J1800 Single-row type No. of circuits 2 JFA CONNECTOR/J1000 SERIES Receptacle contact Strip contact Model No. Gold-plated J1000 SERIES/J1100 (4.3) (2) J 1Ⅱ Size Applicable wire SF1F-002GC-P0.6 Gold (0.2µm) M Tin SF1F-002T-P0.6 SF1F-01GC-P0.6 Gold (0.2µm) ME SF1F-21GC-P0.6 Gold (0.2µm) L Tin SF1F-21T-P0.6 12.8 (7) Series mm2 AWG # Insulation O.D. (mm) Q'ty/ reel 0.08~0.2 28~24 0.88~1.43 6,000 0.2~0.5 24~20 1.30~1.90 5,500 0.3~0.8 22~18 1.50~2.10 5,000 Material and Finish L Copper alloy, nickel-undercoated, selective gold-plated Tin-plated Series name Wire range mark RoHS2 compliance Note: 1. Contact JST for 0.76 µm gold-plated product. 2. Please note that the above general specifications may differ from the safety standards. Tin-plated 12.8 (4.3) (7) (2) 1ⅡL J1000 SERIES/J J1800 Series name Wire range mark Tab contact Strip contact Model No. Size SF1M-002GC-M0.6A Gold (0.2µm) M Tin SF1M-002T-M0.6A SF1M-01GC-M0.6A Gold (0.2µm) ME SF1M-21GC-M0.6A Gold (0.2µm) L Tin SF1M-21T-M0.6A (20.9) (4.3) (2) Series (10.8) Applicable wire mm2 AWG # Insulation O.D. (mm) Q'ty/ reel 0.08~0.2 28~24 0.88~1.43 6,000 0.2~0.5 24~20 1.30~1.90 5,500 0.3~0.8 22~18 1.50~2.10 5,000 Material and Finish J 1 Copper alloy, nickel-undercoated, selective gold-plated Tin-plated L Series name RoHS2 compliance Note: 1. Contact JST for 0.76 µm gold-plated product. 2. Please note that the above general specifications may differ from the safety standards. Wire range mark Crimping machine, Applicator Strip contact Model No. Crimping machine SF1F-002(*) -P0.6 AP-K2N SF1M-002(*) -M0.6A SF1F-01GC -P0.6 AP-K2N SF1M-01GC -M0.6A Crimp applicator Applicator Crimp applicator Dies Hand tool with dies MKS-L MK/SF1F/ M-002-06 APLMK SF1F/ M002-06 YRK-1220 MKS-L MK/SF1F/ M-01-06 APLMK SF1F/ M01-06 YRK-1230 Strip contact Model No. SF1F-21(*) -P0.6 SF1M-21(*) -M0.6A Crimping machine AP-K2N Applicator Crimp applicator Hand tool with dies Crimp applicator Dies MKS-L MK/SF1F/ M-21-06 APLMK SF1F/ M21-06 YRK-1210 Note: Finish (*): GC...Nickel-undercoated, 0.2 µm selective gold-platted T... Tin-plated ・ Extraction tool for J1100 series: EJ-JFAJ1100/EJ-JFAJ1100N ・ Extraction tool for J1800 series: EJ-JFAJ18 ・ Refer to crimping tools for details of YRK series hand crimping tools that uses a strip contact. Note: Contact JST for fully automatic crimping applicator. Recognition mark Plating of the contact Each contact has a marking on its side so that the type or thickness of the plating is recognized. ex. 1 ... gold-plated 0.2 µm thickness 3 ... gold-plated 0.76 µm thickness 5 ... tin-plated Common marking on the contact and its application tools In order to avoid incorrect combination of the hand crimp tools or extraction tools and the contacts, the series name (for example J1 ) and wire range mark (M, ME, L) are shown on both the tools and the contacts. For example J1 3 M..... AWG #28 ~ #24 ME.... AWG #24 ~ #20 L..... AWG #22 ~ #18 Receptacle contact Tab contact Wire range mark Series name Receptacle contact Indication of the plating Tab contact Wire range mark Indication of the plating Series name J1000 SERIES/J1100 Assembly layout Type Wire-to-board Top entry type Wire-to-wire Side entry type Free hanging type (10.6) X X A A (10.6) (11.8) (23.4) A X J1100 Single-row type J1000 SERIES/J1800 (22.9) A A (33.2) A (14.5) X B B A A X B B A A (14.5) (15.7) A B (23.4) J1100 Dual-row type X (25.1) (33.2) B A 4 J1000 SERIES/J1100 Receptacle housing No. of Keying circuits <Single-row type> Model No. A J11SF-03V-KX J11SF-03V-KY X 3 Dimensions (mm) Y B Q’ty/box 4.4 8.0 1,200 4.4 8.0 1,200 Material and Finish Glass-filled PBT, UL94V-0, black J1000 SERIES/J1800 6.6 X A 2.2 A RoHS2 compliance (11.3) Keying No. 16.7 B Line No. Tab housing No. of Keying circuits 3 2 <Single-row type> 1 X Circuit No. Keying No. Model No. J11SFM-03V-KX X 3 Dimensions (mm) ̶ Y A B 4.4 ̶ 9.2 ̶ Q’ty/box 500 ̶ Material and Finish Series name Glass-filled PBT, UL94V-0, black RoHS2 compliance B A 29.3 Line No. A 8.4 2.2 Header Top entry type 1 ±0.1 (2.5) 3 2 1 X Keying No. Series name 2 ±0.05 (8.4) Circuit No. Connector outline 2.7 A 8.4 Model No. X B03B-J11SK-GWXR B03B-J11SK-GWYR B03B-J11SK-TXR B03B-J11SK-TYR Y X Y 3.6 Dimensions (mm) Q’ty/ box A B 4.4 9.2 625 4.4 9.2 625 Material and Finish (2.4) PC board layout (Connector mounting side) 19.5 Keying Post: Copper alloy, gold-plated, tin-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, tin-plated (B) 2.2 A 3 Gold (0.2µm) Tin A±0.05 3.2 No. of circuits Plating φ1 ±0.05 2.2 ±0.05 Line No. 2.7 ±0.05 <Single-row type> RoHS2 compliance Note:1. Gold-plated product displays (LF) on a label. 2. Contact JST for 0.76 µm gold-plated product. B Header Side entry type <Single-row type> X B A (0.6) Keying No. 19 5 3.1 8 3.3 9.6 8.4 Line No. A 2.2 1 ±0.1 (19) 3 2 1 Series name (0.6) No. of circuits Plating (B) 8 ±0.05 Circuit No. Connector outline 2 ±0.05 φ1 ±0.05 Tin Model No. X S03B-J11SK-GWXR S03B-J11SK-GWYR S03B-J11SK-TXR S03B-J11SK-TYR Y X Y Dimensions (mm) Q’ty/ box A B Material and Finish 2.2 ±0.05 A±0.05 3 Gold (0.2µm) Keying (2.4) PC board layout (Connector mounting side) Post: Copper alloy, gold-plated, tin-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, tin-plated RoHS2 compliance Note:1. Gold-plated product displays (LF) on a label. 2. Contact JST for 0.76 µm gold-plated product. 4.4 9.2 600 4.4 9.2 600 J1000 SERIES/J1100 Receptacle housing No. of Keying circuits <Dual-row type> 6 8 12 20 16.7 Keying No. B A 26 30 (15.2) X 10.5 3.9 2.2 B A 22 X Y X Y X Y X Y X Y X Y X Y Model No. J11DF-06V-KX J11DF-06V-KY J11DF-08V-KX J11DF-08V-KY J11DF-12V-KX J11DF-12V-KY J11DF-20V-KX J11DF-20V-KY *J11DF-22V-KX *J11DF-22V-KY *J11DF-26V-KX *J11DF-26V-KY *J11DF-30V-KX *J11DF-30V-KY Dimensions (mm) Q’ty/box A B 8.0 800 4.4 8.0 800 6.6 10.2 500 6.6 10.2 500 11.0 14.6 400 11.0 14.6 400 19.8 23.4 250 19.8 23.4 250 22.0 25.6 250 22.0 25.6 250 26.4 30.0 200 26.4 30.0 200 30.8 34.4 180 30.8 34.4 180 4.4 J1000 SERIES/J1800 Material and Finish Line No. Glass-filled PBT, UL94V-0, black RoHS2 compliance Note: * Marked products are unlisted in UL. Tab housing No. of Keying circuits <Dual-row type> 6 10 9 8 7 6 5 4 3 X 2 1 Circuit No. 8 Keying No. 12 Series name 20 26 B 29.3 Line No. X Y X Y X Y X Y Q’ty/box A B 4.4 9.2 400 4.4 9.2 400 6.6 ̶ 11.4 ̶ 300 ̶ J11DFM-12V-KX 11.0 ̶ 15.8 ̶ 200 ̶ J11DFM-20V-KX 19.8 ̶ 24.6 ̶ 150 ̶ *J11DFM-26V-KX *J11DFM-26V-KY 26.4 31.2 120 26.4 31.2 120 J11DFM-06V-KX J11DFM-06V-KY J11DFM-08V-KX ̶ ̶ ̶ B Glass-filled PBT, UL94V-0, black RoHS2 compliance Note: * Marked products are unlisted in UL. A 3.9 12.3 Y Dimensions (mm) Material and Finish A 2.2 X Model No. 6 J1000 SERIES/J1100 Header Top entry type No. of circuits Plating <Dual-row type> Circuit No. 6 10 9 8 7 6 5 4 3 2 1 Tin X Keying No. Series name 8 J1000 SERIES/J1800 B 3.2 2.7 12 B 12.3 A 3.9 3.9 A 19.5 3.6 1 ±0.1 X Y X Y X Y X Y X Y X Y X Y X Y 22 Gold (0.2 µm) X 26 Gold (0.2 µm) X 30 Gold (0.2 µm) X Y Y Y φ1 ±0.05 2.2 ±0.05 Model No. B06B-J11DK-GWXR B06B-J11DK-GWYR B06B-J11DK-TXR B06B-J11DK-TYR B08B-J11DK-GWXR B08B-J11DK-GWYR B08B-J11DK-TXR B08B-J11DK-TYR B12B-J11DK-GWXR B12B-J11DK-GWYR B12B-J11DK-TXR B12B-J11DK-TYR B20B-J11DK-GWXR B20B-J11DK-GWYR B20B-J11DK-TXR B20B-J11DK-TYR *B22B-J11DK-GWXR *B22B-J11DK-GWYR *B26B-J11DK-GWXR *B26B-J11DK-GWYR *B30B-J11DK-GWXR *B30B-J11DK-GWYR Dimensions (mm) Q’ty/ A B C box 4.4 9.2 ̶ 500 4.4 9.2 ̶ 500 6.6 11.4 4.4 400 6.6 11.4 4.4 400 11.0 15.8 8.8 280 11.0 15.8 8.8 280 19.8 24.6 17.6 180 19.8 24.6 17.6 180 22.0 26.8 19.8 160 26.4 31.2 24.2 140 30.8 35.6 28.6 120 Material and Finish Post: Copper alloy, gold-plated, tin-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, tin-plated A ±0.05 (2.4) A ±0.05 (12.3) 2.7 ±0.05 3.9 ±0.05 φ1 ±0.05 2.2 ±0.05 Gold (0.2 µm) Tin 2 ±0.05 (12.3) 1 ±0.1 2 ±0.05 (2.5) C ±0.05 2.7 ±0.05 20 Connector outline Connector outline 3.9 ±0.05 Gold (0.2 µm) Tin 2.2 (2.5) Gold (0.2 µm) Tin Line No. C (2.4) Gold (0.2 µm) Keying (B) (B) PC board layout (Other than 6-circuit) (Connector mounting side) PC board layout (6-circuit) (Connector mounting side) RoHS2 compliance Note:1. Gold-plated product displays (LF) on a label. 2. Contact JST for 0.76 µm gold-plated product. 3. * Marked products are unlisted in UL. Header Side entry type No. of circuits Plating <Dual-row type> 10 9 8 7 6 5 4 3 2 1 X Circuit No. 6 Keying No. Tin Series name 8 B A 13.5 12.3 3.9 Line No. Gold (0.2 µm) X Y X Y X Y X Y X Y X Y X Y X Y X Y Model No. S06B-J11DK-GWXR S06B-J11DK-GWYR S06B-J11DK-TXR S06B-J11DK-TYR S08B-J11DK-GWXR S08B-J11DK-GWYR S08B-J11DK-TXR S08B-J11DK-TYR S12B-J11DK-GWXR S12B-J11DK-GWYR S12B-J11DK-TXR S12B-J11DK-TYR S20B-J11DK-GWXR S20B-J11DK-GWYR S20B-J11DK-TXR S20B-J11DK-TYR *S30B-J11DK-GWXR ― Material and Finish (21.2) 8 ±0.05 30 2 ±0.05 1 ±0.1 (2.4) Gold (0.2 µm) Tin 2.2 φ1 ±0.05 (0.6) A ±0.05 (B) PC board layout (Other than 6- & 8-circuit) (Connector mounting side) 7 3.3 3.1 2.2 ±0.05 Connector outline 2.2 ±0.05 8 ±0.05 (21.2) 2 ±0.05 1 ±0.1 (0.6) 2.2 ±0.05 φ1 ±0.05 20 (0.6) 8 Gold (0.2 µm) Tin A C (2.4) 12 B C ±0.05 Gold (0.2 µm) Tin 21.2 2.2 Connector outline Gold (0.2 µm) Keying 2.2 ±0.05 A ±0.05 (B) PC board layout (6- & 8-circuit) (Connector mounting side) Post: Copper alloy, gold-plated, tin-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, tin-plated RoHS2 compliance Note:1. Gold-plated product displays (LF) on a label. 2. Contact JST for 0.76 µm gold-plated product. 3. * Marked product is unlisted in UL. Dimensions (mm) Q’ty/ A B C box 4.4 9.2 ̶ 375 4.4 9.2 ̶ 375 6.6 11.4 ̶ 300 6.6 11.4 ̶ 300 11.0 15.8 8.8 225 11.0 15.8 8.8 225 19.8 24.6 17.6 135 19.8 24.6 17.6 135 30.8 35.6 28.6 ̶ ̶ ̶ 90 ̶ J1000 SERIES/J1800 Assembly layout Wire-to-board Type Top entry type Side entry type (7) (23) (8) (23.5) Single-row type Receptacle housing Keying No. No. of circuits Circuit No. 8 Keying Model No. Q’ty/box X J18SF-08V-KX 450 ̶ Y ̶ 8 7 6 5 4 3 2 1 Material and Finish 4.8 5.1 Glass-filled PBT, UL94V-0, black 2.2 RoHS2 compliance 7.5 20.7 (31.5) Header Top entry type 8 X Y Model No. Q’ty/box B08B-J18SK-TXR 245 ̶ ̶ Material and Finish 7.5 ±0.05 Post: Copper alloy, tin-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, tin-plated 2.7 ±0.05 2.2 ±0.05 5 6 7 8 (4.65) 20.7 ±0.05 RoHS2 compliance PC board layout (Connector mounting side) 30 18.5 7.5 3.2 20.7 2.7 7 2.2 2 ±0.05 Keying 1.6 2 3 4 Series name 1 Keying No. φ1 (7) (2.7) Circuit No. No. of circuits (30) 18.5 ±0.05 (1.6) 1 ±0.05 Connector outline 19.5 3.6 Header Side entry type 20.7 ±0.05 Circuit No. 2.2 ±0.05 2 3 4 φ1 ±0.05 (19) 5 6 7 8 Keying No. Series name 30 20.7 7.5 23 ±0.05 Connector outline 23 (4.65) 8 Keying X Y Model No. Q’ty/box ̶ 220 ̶ S08B-J18SK-TXR Material and Finish Post: Copper alloy, tin-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, tin-plated φ2 ±0.05 PC board layout (Connector mounting side) RoHS2 compliance 19 3.3 3.1 8 6.8 2.2 7.5 ±0.05 No. of circuits 8 ±0.05 (0.6) (30) 8 (0.6) 8 JFA CONNECTOR/J1000 SERIES Model number allocation Receptacle contact Tab contact S F1 F - 21 T - P 0.6 S F1 M - 21 T - M 0.6 A J1000 SERIES/J1100 Form: S…Strip form Series name Form: S…Strip form Series name Kind of terminal: F…Receptacle contact Applicable wire: 002…AWG #28 ~ AWG #24 01…AWG #24 ~ AWG #20 21…AWG #22 ~ AWG #18 Surface finish: GC…Nickel-undercoated, selective gold-plated (0.2 µm) GI…Nickel-undercoated, selective gold-plated (0.76 µm) T…Tin-plated Material: P…Copper alloy J1000 SERIES/J1800 Terminal size Receptacle housing Kind of terminal: M…Tab contact Applicable wire: 002…AWG #28 ~ AWG #24 01…AWG #24 ~ AWG #20 21…AWG #22 ~ AWG #18 Surface finish: GC…Nickel-undercoated, selective gold-plated(0.2 µm) GI…Nickel-undercoated, selective gold-plated(0.76 µm) T…Tin-plated Material: M…Copper alloy Terminal size Sub model number Tab housing J11 DFM - 06 V - K X J11 DF - 06 V - K X Series name Series name Type of connector: SF…Single-row type DF…Dual-row type Type of connector: SFM…Single-row type Circuits: 3, 6, 8, 12, 20, 22, 26, 30 Circuits: 3, 6, 8, 12, 20, 26 Flammability: V…UL94V-0 Flammability: V…UL94V- 0 Color indication: K…Black Color indication: K…Black Keying: X…X-Keying, Y…Y-Keying Keying: X…X-Keying, Y…Y-Keying Header B 06 B - J11 D K - T X R PC board mounting direction: B…Top entry type S…Side entry type Circuits: 3, 6, 8, 12, 20, 22, 26, 30 Shape of assembled product Series name Rows: S…Single-row, D…Dual-row Color indication: K…Black Surface finish: GW…Nickel-undercoated, selective gold-plated(0.2 µm) GZ…Nickel-undercoated, selective gold-plated(0.76 µm) T…Tin-plated Keying: X…X-Keying, Y…Y-Keying Packaging form: R…Tray 9 DFM…Dual-row type
J11SFM-03V-KX 价格&库存
很抱歉,暂时无法提供与“J11SFM-03V-KX”相匹配的价格&库存,您可以联系我们找货
