LPAM-40-01.5-L-08-2-K-TR 数据手册
F-217
LPAM–20–01.5–L–06–2–K
LPAM–20–01.5–L–04–2–K
(1.27 mm) .050"
LPAM SERIES
HIGH-SPEED LOW PROFILE OPEN-PIN-FIELD
SPECIFICATIONS
Mates with:
LPAF
For complete specifications and
recommended PCB layouts see
www.samtec.com?LPAM
Insulator Material:
Black LCP
Terminal Material:
Copper Alloy
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
2.2 A per pin
(6 adjacent pins powered)
Working Voltage:
250 VAC
RoHS Compliant:
Yes
Lead-Free Solderable:
Yes
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
Rating based on Samtec reference channel.
For full SI performance data visit Samtec.com
or contact SIG@samtec.com
NO. PINS
PER ROW
43
4 mm, 4.5 mm
and 5 mm stack heights
G b p s
LEAD
STYLE
Dual Blade
terminal
Solder
crimp
HIGH-SPEED CHANNEL PERFORMANCE
LPAM/LPAF @ 5 mm Mated Stack Height
LPAM
FILE NO. E111594
4, 6 or 8 row standard
.050" (1.27 mm) X
.050" (1.27 mm) pitch
Up to 40 pins
per row
PLATING
OPTION
NO. OF
ROWS
–L
– 04
SOLDER
TYPE
K
TR
–K
=Tape &
Reel
ALSO AVAILABLE
(MOQ Required)
• Tin-Lead Solder Charge
• Other pins/row and row counts
• Other Gold plating options
Contact Samtec.
–01.0
= (1.0 mm)
.039"
–10, – 20,
– 30, –40
–01.5
(Per Row)
= (1.5 mm)
.060"
= 10 µ"
(0.25 µm)
Gold on
contact area,
Matte Tin on
solder tail
MATED HEIGHT
LPAF
LPAM
MATED
HEIGHT
B
–04
(8.18)
.322
(10.72)
.422
(13.26)
.522
–08
=Six
Rows
No. of positions x
(1.27) .050 + (6.76) .266
(1.27)
.050
LPAF LEAD STYLE
–03.0
–03.5
= Polyimide
film Pick &
Place Pad
=Eight
Rows
MATED HEIGHT*
LPAM
LEAD
STYLE
– 06
–2
= Lead-Free
Solder
Crimp
– 08
NO. OF
ROWS
–06
=Four
Rows
B
–01.0 (4.00) .157 (4.50) .177
–01.5 (4.50) .177 (5.00) .197
(1.27) .050
*Processing conditions will
affect mated height.
(1.27)
.050
Note: Patent Pending
A
(1.32) .052 DIA
No. of positions x
(1.27) .050 + (3.10) .122
Note: Some sizes, styles and
options are non-standard,
non-returnable.
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
LEAD
STYLE
A
–01.0
(3.68)
.145
(4.19)
.165
–01.5
– TR
LPAM-40-01.5-L-08-2-K-TR 价格&库存
很抱歉,暂时无法提供与“LPAM-40-01.5-L-08-2-K-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+280.233711+36.41709
- 10+238.1390710+30.94678
- 25+223.2327825+29.00967
- 50+217.8281350+28.30733
- 国内价格 香港价格
- 300+179.04754300+23.26769
- 600+177.96417600+23.12690
