MMSD-15-20-L-40.00-D-K-LUS 数据手册
REVISION AT
DO NOT
SCALE FROM
THIS PRINT
NOTES:
MMSDX-XX-XXX-X-XX.XX-X-X-XXX
1. C REPRESENTS A CRITICAL DIMENSION.
FEP CABLE OPTION
2. BURR ALLOWANCE: .003[.08] MAX.
3. PARTS TO BE MOLDED TO POSITION.
OPTION
-T: FEP INSULATION
4. MINIMUM PIN PULLOUT FORCE: 4.000LB[17.79N]
(LEAVE BLANK FOR STANDARD
5. CONTACT MUST BE INSERTED UNTIL RETENTION
SINGLE
PVC INSULATION)
FEATURE LOCKS INTO PLACE.
(SEE NOTE 14)
-M: METAL LATCH (USE IPD1-XX-D-X-M)
6. ALL FINISHED GOODS ARE TO BE ELECTRICAL TESTED INCLUDING HI-POT TEST
No OF POSITIONS
(LEAVE BLANK FOR PLASTIC)
@ 1000 VOLTS DC. AFTER FINAL ELECTRICAL TEST, LABEL EACH ASSEMBLY
-02 THRU -25
WITH (1) ET STAMP ON THE BODY. C
DOUBLE
(PER ROW)
7. TINNED COPPER WIRE IS ROHS COMPLIANT.
-LUS: PLASTIC LATCH UP, STRAIGHT
8. FOLLOW CO-RF-WI-3001-M AND SAMTEC PACKAGING STANDARDS.
WIRE GAUGE (AWG)
-LDS: PLASTIC LATCH DOWN, STRAIGHT
9. MINIMUM METAL LATCH RETENTION FORCE: 1.000LB[4.45N]
PVC: -20, -22, -24, -26, -28, -30
10. REFER TO CRIMP SPECIFICATIONS PRINT FOR CRIMP AND STRIP
-LUX: PLASTIC LATCH UP, CROSSED
FEP: -20,-24-28-30
DIMENSIONS, TOLERANCES, TOOLING AND ITS REQUIREMENTS.
-LDX: PLASTIC LATCH DOWN, CROSSED
11. FOR LENGTHS LESS THAN 12 IN, TOLERANCE SHALL
-MUS: METAL LATCH UP, STRAIGHT
COLOR
CODE
BE ±.125[3.18]. FOR OTHER LENGTHS, TOLERANCES SHALL BE ±2%.
-MDS: METAL LATCH DOWN, STRAIGHT
C (SEE TABLE 3, SHEET 3)
12. LOCATION OF GATE PAD IS AT THE DISCRETION OF THE VENDOR.
-MUX: METAL LATCH UP, CROSSED
13. GOLD PLATING IS NOT REQUIRED ON THE OUTSIDE OF THE CONTACT
-MDX: METAL LATCH DOWN, CROSSED
BOX OR ON THE SIDE WITH THE RETENTION LANCE.
BLACK CABLE)
14. ASSEMBLIES USING THE FEP OPTION ARE FOR CRIMP APPLICATIONS ONLY.
POLARIZATION OPTION
(NOT AVAILABLE WITH FEP OPTION)
15. CUT LENGTH IS ASSEMBLY LENGTH MINUS OVERALL LENGTH SUBTRACTOR.
(-P, -K, OR -G OPTION IS REQUIRED.)
PLATING SPECIFICATION
-P: POLARIZATION (SEE FIG 3, SHEET 2)
-F: 3 µ" SELECTIVE GOLD IN CONTACT
(NOT AVAILABLE WITH -LUS, -LDS, -LUX, -K, -G OPTIONS)
AREA, BRIGHT TIN ON TAIL.
(No OF POS x .100[2.54])
-K: KEYED POLARIZATION
-L: 10 µ" SELECTIVE GOLD IN CONTACT
+ .058[1.47] REF
(USE IPD1-XX-D-K) (SEE FIG 4, SHEET 2)
C
(NOT AVAILABLE WITH -P, -G OPTIONS)
-S: 30 µ" SELECTIVE GOLD IN CONTACT
05
01
-G: GUIDE POST
(USE IPD1-XX-D-GP) (SEE FIG 6, SHEET 3)
C
ASSEMBLED LENGTH
(NOT AVAILABLE WITH -LDS, -LUX, -P, -K OPTIONS)
.353 8.97
.250 6.35
SPECIFY IN INCHES [USE DWC-XX-XX]
REF
REF
(SINGLE END: 03.00 INCH MINIMUM,
(LEAVE BLANK FOR NO POLARIZATION;
DOUBLE END: 03.25 INCH MINIMUM)
AVAILABLE TO EXISTING CUSTOMERS ONLY)
10
.100 2.54
REF
END OPTION
-S: SINGLE END
-D: DOUBLE END
(MUST CHOOSE FROM
LUS, LDS, LUX, LDX, MUS,
MDS, MUX, OR MDX)
06
"A"
IPD1-XX-D
C .505 12.83
REF
.285 7.24
REF
C
C
XX.XX
(SEE NOTE 11)
XX.XX
(SEE NOTE 11)
FIG 1
"A"
MMSD-05-22-X-XX.XX-S SHOWN
FIG 2
SECTION "A"-"A"
MMSD-05-22-X-XX.XX-D SHOWN
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.3]
2
.XXX: .005 [.13]
.XXXX: .0020 [.051]
MATERIAL:
F:\DWG\MISC\MKTG\MMSDX-XX-XXX-X-XX.XX-X-X-XXX-MKT.SLDDRW
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
HOUSING: NYLON 66, COLOR: WHITE
CONTACT: PHOS BRONZE
CABLE; INSULATION: SEE CALLOUT
WIRE: TINNED COPPER
LATCH: NICKEL-PLATED BeCu, #25, 1/2 HT
SHEET SCALE: 1:0.666667
DESCRIPTION:
.100[2.54] SOCKET DISCRETE CABLE ASSEMBLY
DWG. NO.
BY:
DEAN P
07/16/2004
SHEET 1 OF 4
REVISION AT
01
N
N/2 + 1
N
N/2
(SEE TABLE 2)
N/2
N/2 + 1
01
(SEE TABLE 2)
LATCHEND 2
N/2
N
N/2 + 1
01
LATCHEND 1
LATCHEND 2
N/2 + 1
N/2
(SEE TABLE 2)
N
N
N/2
N/2 + 1
01
(SEE TABLE 2)
LATCHEND 2
N
-LDS
[LATCH DOWN - CABLE STRAIGHT]
(SEE SHEET 3, TABLE 4 FOR PIN MAPPING)
N
N/2
N/2
N/2 + 1
01
(SEE TABLE 2)
LATCHEND 1
LATCHEND 1
LATCHEND 2
.022 0.56 REF
01
(SEE TABLE 2)
LATCHEND 1
N/2 + 1
-LUX
[LATCH UP - CABLE CROSSED]
N/2
N/2 + 1
(SEE TABLE 2)
-LUS
[LATCH UP - CABLE STRAIGHT]
01
N
01
(SEE TABLE 2)
-LDX
[LATCH DOWN - CABLE CROSSED]
.022 0.56 REF
(TYP) (2 PLCS)
02 01
PROPRIETARY NOTE
IPD1-XX-D-P
07
IPD1-02-D-K
(MMSDX-06-XX-X-XX.XX-X-P SHOWN)
(NOT AVAILABLE WITH -LUS, -LDS, -LUX OPTIONS)
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
IPD1-XX-D-K
FIG 3
-P: POLARIZATION
(MMSDX-06-XX-X-XX.XX-X-K-XXX SHOWN)
(NOT AVAILABLE WITH -P OPTION)
(SAME AS FIG. 1, UNLESS OTHERWISE STATED)
-02 POS
(DIFFERENT AS SHOWN)
FIG 4
SHEET SCALE: 1.25:1
DESCRIPTION:
DWG. NO.
BY:
DEAN P
07/16/2004
SHEET 2 OF 4
REVISION AT
.260 6.60 REF
IPD1-XX-D-X-M
.618 15.70
REF
.310 7.87
REF
.109 2.77 REF
IPD1-XX-D-GP
FIG 6
FIG 5
(MMSDX-06-XX-X-XX.XX-S-G SHOWN)
(SAME AS FIG 1, UNLESS OTHERWISE STATED)
(MMSDX-06-XX-X-XX.XX-S-M SHOWN)
PROPRIETARY NOTE
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
SHEET SCALE: 2:1
DESCRIPTION:
DWG. NO.
BY:
DEAN P
07/16/2004
SHEET 3 OF 4
REVISION AT
CABLE CUT IN-PROCESS
"A"
(SEE TABLE 1, SHT 1)
"A"
OVERALL LENGTH
(SEE TABLE 5)
OVERALL LENGTH
(SEE TABLE 5)
"A"
-S: SINGLE END
-D: DOUBLE END
PROPRIETARY NOTE
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
SHEET SCALE: 2:1
DESCRIPTION:
DWG. NO.
BY: DEAN P
07/16/2004 SHEET 4 OF 4
