QTH-120-06-L-D-A
QTH-120-06-L-D-A
    SAMTEC(申泰)
    .5MM DOUBLE ROW MI SOCKET ASSEMB
QTH-120-06-L-D-A 数据手册
QTH–060–01–F–D–RA–PGP F-219 ® QTH–060–01–F–D–DP–RA–K (0.50 mm) .0197" QTH-RA SERIES QTH–030–01–L–D–RA RIGHT-ANGLE GROUND PLANE HEADER Right-angle SPECIFICATIONS Board Mates: QSH For complete specifications and recommended PCB layouts see www.samtec.com?QTH-RA or www.samtec.com?QTH-DP-RA Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Weld Tab: Phosphor Bronze Ground Plane: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: Contact: 2.2 A per pin (2 pins powered) Ground Plane: 21.8 A per ground plane (1 ground plane powered) Operating Temp Range: -55 °C to +125 °C Voltage Rating: 220 VAC RoHS Compliant: Yes Integral metal plane for power or ground Guide Post PINS PER ROW NO. OF PAIRS QTH 01 PLATING OPTION OTHER OPTION RA TYPE PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (020-090) –F = Gold Flash on contact, Matte Tin on tails –030, –060, –090 –D = (60 total pins per bank) –L –020, –040, –060 A (with option -PGP) B (without option -PGP) NO. OF PINS PER PAIRS ROW (7.98) .314 02 (2.03) .080 Note: Some lengths, styles and options are non-standard, non-returnable. (0.38) .015 (0.20) .008 –020 –030 –040 –060 –060 –090 A B C (30.80) 1.213 (50.80) 2.000 (70.80) 2.788 (25.72) 1.013 (45.72) 1.800 (65.72) 2.588 (25.72) 1.013 (45.72) 1.800 (65.72) 2.588 (8.85) .348 (0.64) .025 SQ –PGP OPTION SHOWN Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM –K = (7.00 mm) .275" DIA Polyimide film Pick & Place Pad = Differential Pair C 01 = Plastic Guide Post –D–DP = 10 µ" (0.25 µm) Gold contact, Matte Tin on tails –D–DP = (20 pairs per bank) –PGP –D = SingleEnded All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
QTH-120-06-L-D-A 价格&库存
很抱歉,暂时无法提供与“QTH-120-06-L-D-A”相匹配的价格&库存,您可以联系我们找货
