S2SDT-05-24-L-12.00-S
    SAMTEC(申泰)
    2.00 MM TIGER EYE DOUBLE ROW DI
S2SDT-05-24-L-12.00-S 数据手册
(2.00 mm) .0787" PITCH • CABLE ASSEMBLY/COMPONENTS - SERIES S2SD - PINS PER ROW –05, –07, –10, –15, –20, –25, –30 = Double Row PVC Cable S2SDT (Standard sizes) = Double Row Blue *Teflon™ Fluoropolymer Cable (24, 28, 30 AWG only) - WIRE GAUGE PLATING OPTION –24 –L = 10 µ" (0.25 µm) Gold on contact –24C = Color Coded Cable (S2SD only) - ASSEMBLED LENGTH - –“XX.XX” –S = Wire Length in Inches (69.85 mm) 02.75" min. Specify “S” for single ended and “D” for double ended. –(X)S –24C CABLE COLOR CODING PIN COLOR 1 2 3 4 5 6 7 8 9 10 ETC BROWN RED ORANGE YELLOW GREEN VIOLET GRAY WHITE BLACK BLUE REPEAT = Screw Down (10 positions minimum) (mates with T2M-DS) - - POSITIONS PER ROW –05, –07, –10, –15, –20, –25, –30 (Standard sizes) ROW OPTION –D = Double Row (11.38) .448 *Teflon™ is a trademark of The Chemours Company FC, LLC used under license by Samtec. Assembly Length ± (3.18) .125 Notes: Teflon™ Fluoropolymer cable is intended for crimp only. Contact Samtec for solderable cable applications. - LATCH OPTION –M = Metal Retention Latch = Screw Down (2.00) .079 DIA (2.03) .080 (2.64) .104 SERIES CC81L = Contact, Loose CC81R = Contact, Full Reel (17,000 Parts per Reel) For wiring option information refer to drawings on web. - WIRE GAUGE - 01 - –2426 = 24 to 26 AWG –2830 PLATING OPTION –L = 10 µ" (0.25 µm) Gold on contact = 28 to 30 AWG (3.68) .145 (1.78) .070 –M –NDX = Notch down, crossed (Pin 1 to Pin 1) (5.15) .203 –S (2.07) .081 –NUX = Notch up, crossed (Pin 1 to Pin N) (7.52) .296 View complete specifications at: samtec.com?S2SD & samtec.com?S2SDT ISD2 –NDS = Notch down, straight (Pin 1 to Pin 2) = Retention Latch (–SR mates with T2M-WT) No. of positions x (2.00) .0787 + (3.50) .138 SPECIFICATIONS = Notch up, straight (Pin 1 to Pin N-1) –(X)R –30 Insulator Material: Black LCP Contact Material: BeCu Plating: Au over 50 µ" (1.27 µm) Ni Wire: 24, 26, 28 or 30 AWG Operating Temp Range: -10 °C to +105 °C (PVC) -40 °C to +125 °C (*Teflon™ Fluoropolymer) Current Rating (S2SD-24/T2M): 3.8 A per pin (2 pins powered) Voltage Rating: 250 VAC –NUS –D = Double End –28 Board Mates: T2M END 2 OPTIONS (Only available with –D, –DR & –DS) = Single End –26 S2SD(T) - END OPTIONS (12.35) .486 (3.17) .125 –S TOOLING Note: Some lengths, styles and options are non-standard, non-returnable. F-224 Hand Tool: CAT-HT-281-2430-13 Mini Applicator: CAT-MC-281-2426-XX-01 (24-26 AWG) Extraction Tool: CAT-EX-169-01 Mini Applicator: CAT-MC-281-2830-XX-01 (28-30 AWG) View complete specifications at: samtec.com?ISD2, samtec.com?CC81R & samtec.com?CC81L samtec.com/2mm-TigerEye Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
S2SDT-05-24-L-12.00-S 价格&库存
很抱歉,暂时无法提供与“S2SDT-05-24-L-12.00-S”相匹配的价格&库存,您可以联系我们找货
