S2SDT-05-24-S-05.20-DR-NDX 数据手册
(2.00 mm) .0787" PITCH • CABLE ASSEMBLY/COMPONENTS
SERIES
S2SD
PINS
PER ROW
–05, –07,
–10, –15,
–20, –25, –30
= Double Row
PVC Cable
S2SDT
(Standard sizes)
= Double Row
Blue *Teflon™
Fluoropolymer Cable
(24, 28, 30 AWG only)
WIRE
GAUGE
PLATING
OPTION
–24
–L
= 10 µ"
(0.25 µm)
Gold on
contact
–24C
= Color
Coded
Cable
(S2SD only)
ASSEMBLED
LENGTH
–“XX.XX”
–S
= Wire Length in
Inches (69.85 mm)
02.75" min.
Specify “S” for single ended
and “D” for double ended.
–(X)S
–24C CABLE
COLOR CODING
PIN
COLOR
1
2
3
4
5
6
7
8
9
10
ETC
BROWN
RED
ORANGE
YELLOW
GREEN
VIOLET
GRAY
WHITE
BLACK
BLUE
REPEAT
= Screw Down
(10 positions minimum)
(mates with T2M-DS)
POSITIONS
PER ROW
–05, –07, –10, –15,
–20, –25, –30
(Standard sizes)
ROW
OPTION
–D
= Double
Row
(11.38)
.448
*Teflon™ is a trademark of The
Chemours Company FC, LLC
used under license by Samtec.
Assembly
Length
± (3.18)
.125
Notes:
Teflon™ Fluoropolymer cable
is intended for crimp only.
Contact Samtec for solderable
cable applications.
LATCH
OPTION
–M
= Metal
Retention
Latch
= Screw
Down
(2.00)
.079
DIA
(2.03)
.080
(2.64)
.104
SERIES
CC81L
= Contact, Loose
CC81R
= Contact,
Full Reel
(17,000 Parts
per Reel)
For wiring option information
refer to drawings on web.
WIRE
GAUGE
- 01 -
–2426
= 24 to 26 AWG
–2830
PLATING
OPTION
–L
= 10 µ" (0.25 µm)
Gold on contact
= 28 to 30 AWG
(3.68)
.145
(1.78)
.070
–M
–NDX
= Notch down,
crossed
(Pin 1 to Pin 1)
(5.15)
.203
–S
(2.07) .081
–NUX
= Notch up, crossed
(Pin 1 to Pin N)
(7.52)
.296
View complete specifications at: samtec.com?S2SD & samtec.com?S2SDT
ISD2
–NDS
= Notch down,
straight
(Pin 1 to Pin 2)
= Retention Latch
(–SR mates with T2M-WT)
No. of positions x
(2.00) .0787 + (3.50) .138
SPECIFICATIONS
= Notch up, straight
(Pin 1 to Pin N-1)
–(X)R
–30
Insulator Material:
Black LCP
Contact Material:
BeCu
Plating:
Au over 50 µ" (1.27 µm) Ni
Wire:
24, 26, 28 or 30 AWG
Operating Temp Range:
-10 °C to +105 °C (PVC)
-40 °C to +125 °C
(*Teflon™ Fluoropolymer)
Current Rating
(S2SD-24/T2M):
3.8 A per pin
(2 pins powered)
Voltage Rating:
250 VAC
–NUS
–D
= Double End
–28
Board Mates:
T2M
END 2
OPTIONS
(Only available with
–D, –DR & –DS)
= Single End
–26
S2SD(T)
END
OPTIONS
(12.35)
.486
(3.17)
.125
–S
TOOLING
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
F-224
Hand Tool: CAT-HT-281-2430-13
Mini Applicator: CAT-MC-281-2426-XX-01 (24-26 AWG)
Extraction Tool: CAT-EX-169-01
Mini Applicator: CAT-MC-281-2830-XX-01 (28-30 AWG)
View complete specifications at: samtec.com?ISD2, samtec.com?CC81R & samtec.com?CC81L
samtec.com/2mm-TigerEye
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
S2SDT-05-24-S-05.20-DR-NDX 价格&库存
很抱歉,暂时无法提供与“S2SDT-05-24-S-05.20-DR-NDX”相匹配的价格&库存,您可以联系我们找货
