THROUGH-HOLE
.025" SQ POST SOCKET 8
G b p s
(2.54 mm) .100" PITCH • SSW/SSQ SERIES
SSW/SSQ
SERIES
Mates:
TSW, MTSW, MTLW,
DW, EW, ZW, TSS, ZSS,
TSM, TSSH, HTSS
-1
SSW
01 thru 50
= Solder
Tail
SPECIFICATIONS
SSQ
Insulator Material:
Black Liquid Crystal Polymer
(-S & -D) or
Black High Temperature
Thermoplastic (-T)
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating (SSW/TSM):
4.7 A per pin
(2 pins powered)
Current Rating (SSQ/TSW):
6.3 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
Insertion Depth:
(3.68 mm) .145" to
(6.35 mm) .250"
Max Cycles:
100 with 10 µ" (0.25 µm) Au
Voltage Rating:
465 VAC / 655 VDC
NO. PINS
PER ROW
= Square
Tail
LEAD
STYLE
Specify
LEAD
STYLE
from
chart
PLATING
OPTION
–F
–S
= Gold flash
on contact,
Matte Tin on tail
= Single Row
–P
= Single Row
(36 pins max
–L
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–D
–G
Lead–Free Solderable:
Yes:
-S and -D row option
No, Lead Wave only:
-P, -T and -Q row option
—T
= Locking
Lead
Available
on tails from
(2.29 mm)
.090" to
(7.87 mm)
.310" only.
Not Available
with single
row 1 or 2
positions)
–RA
= Rightangle
–Q
“XXX”
= Polarized
(Specify “XXX” as
position number)
THROUGH-HOLE
SINGLE
DOUBLE
Standard Low
OR TRIPLE
Insertion Insertion
A
Force
Force*
LEAD STYLE
–01
–21
(2.64) .104
–02
–22
(4.93) .194
–03
–23
(10.00) .394
–04
–24
(14.83) .584
–06**
N/A
(3.15) .124
(2.54)
.100
PROCESSING
–LL
Leave blank
for straight
pin version)
= Double Row
.200"
(5.08 mm)
row space
(outer rows
filled only)
(2.54) .100 x No. of Positions + (0.51) .020
(4.95)
.195
OTHER
OPTION
–T
= Matte Tin
(-T N/A on
LIF contacts)
—D
= Triple Row
–T
(2.41)
.095
TAIL
OPTION
= Double Row
= 20 µ" (0.51 µm)
Gold on contact,
Gold flash on tail
—S
ROW
OPTION
* LIF not available with Tin Plating
**Style –06 Not available with SSQ
(7.49)
.295
—S & —P
—D
—T
—Q
(8.51)
.335
—Q
(7.49)
.295
Through-hole
LEAD STYLE
A
A
SINGLE DOUBLE
TRIPLE
(–S )
(–D )
(–T & –Q )
B
B
B
(2.54) .100
–02
–22
(2.54) .100
(2.54) .100
–03
–23
(7.62) .300
(7.62) .300
N/A
–04
–24
(12.45) .490
N/A
N/A
A
Straight Pin Versions
Right-angle
RIGHT-ANGLE
Standard
Low
Insertion Insertion
Force
Force*
A
—S & —P
B
—D
B
—T
B
—Q
B
*LIF not available with Tin Plating
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
F-224
Right-angle Versions
samtec.com?SSW or samtec.com?SSQ
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(8.51)
.335
很抱歉,暂时无法提供与“SSQ-104-22-L-Q”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+23.245831+3.01689
