TCMD-13-T-16.00-01-N-R
    SAMTEC(申泰)
    2MM DOUBLE ROW MALE IDC ASSEMBLY
TCMD-13-T-16.00-01-N-R 数据手册
F-215 ™ TCMD–08–D–02.50–01–R UUUUUUUUUUUUUUUUUUU TCMD–20–D–02.50–01 (2,00 mm) .0787" TCMD SERIES HIGH RELIABILITY IDC HEADER CABLE Mates with: SMM*, MMS*, ESQT, PTF, SQT, SQW, TLE TYPE STRIP END OPTION NO. PINS PER ROW OVERALL LENGTH OTHER OPTION TRANSFER OPTION 01 SPECIFICATIONS For complete specifications see www.samtec.com?TCMD Insulator Material: Black Glass Filled Polyester Terminal: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27 µm) Ni Wire: 28 AWG 7/36 Stranded, Tinned, Copper with Gray PVC Insulator Operating Temp Range: -40°C to +105°C RoHS Compliant: Yes –“XX.XX” –04, –05, –06, –07, –08, –10, –12, –13, –15, –17, –20, –22, –25 = Assembled Length Leave blank for –S and –D End Options. For –T End Option Specify “–N” (Socket has notch polarization) Assembled Length in INCHES (±1/8") 2 inches minimum (Standard sizes) • Strain relief option –SR –P “XX” –S = Single End RECOGNITIONS –D = Double End For complete scope of recognitions see www.samtec.com/quality = Position Polarization 01 = Strain Relief No. of positions x (2,00) .0787 + (7,874) .3100 02 Not available with –O, –M, –R, –DXX or –BXX Specify “XX” as position number. Requires Transfer End. Only Socket is polarized. 1 –T=Transfer End ALSO AVAILABLE (MOQ Required) • Other sizes Contact Samtec. –D “XX” = Daisy Chain 2" min. “XX” ± 1/8" Double Row Connectors –B “XX” = Breakout Specify “XX” as number of conductors to be broken out. 4" minimum Outer Most (End of assembly) 4 –R TCMD =Terminal Strip = Reversed “XX” 5"max. 2"min. 01 Breakout starts with Number 1 lead indicated by brown wire or red stripe. Shown on top side. (4,00) .158 5 2 –M = Middle Reverse –RW No. of positions x (2,00) .0787 + (4,00) .158 = Reverse Wiring (1,00) .03937 Requires –DXX *Note: Standard TCMD callout will not mate with SMM, MMS. Must use gold plated callouts. (See drawing on web.) When mated with a socket, Wire 1 mates with Pin 2; Wire 2 mates with Pin 1, etc. (5,08) .200 5 –O = Outside Reverse 01 (3,05) .120 02 (0,50) .020 SQ (2,00) .0787 (2,00) .0787 Blue or black wire opposite position #1. Note: TCMD Series assemblies are non-standard, non-returnable. Requires –DXX 3 WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. 5
TCMD-13-T-16.00-01-N-R 价格&库存
很抱歉,暂时无法提供与“TCMD-13-T-16.00-01-N-R”相匹配的价格&库存,您可以联系我们找货
