TCSD-25-D-05.00-01-N-SR 数据手册
F-215
TCSD
TMM
.26" (6,6 mm)
TCSD–08–D–02.00–01–N–R
UUUUUUUUUUUUUUUUUUU
(2,00 mm) .0787"
TCSD SERIES
TIGER EYE IDC SOCKET CABLE
Mates with:
TMM, TMMH, STMM,
MMT, TW, MTMM, EHT,
ETMM (-SR), ZSTMM
TYPE
STRIP
END
OPTION
NO. PINS
PER ROW
01
LENGTH
PLATING
OPTION
OTHER
OPTION
N
SPECIFICATIONS
For complete specifications
see www.samtec.com?TCSD
–04, –05,
–06, –07,
–08, –10, –12,
–13, –15, –17,
–20, –22, –25
Insulator Material:
Black Glass Filled Polyester
Contact:
BeCu
Plating:
Au or Sn over 50µ" (1,27 µm) Ni
Wire:
28 AWG 7/36 Stranded,
Tinned, Copper with
Gray PVC Insulator
Current Rating (TCSD/STMM):
2.8 A per pin
(1 pin powered per row)
Operating Temp Range:
-40°C to +105°C
Lead Size Accepted:
(0,48 mm) .019" to
(0,53 mm) .021"
Contact Resistance:
15 mΩ
Insertion Depth:
(2,87 mm) .113" to
(3,17 mm) .125"
RoHS Compliant:
Yes
= Notch Polarization
= Assembled Length
Assembled Length
in INCHES (±1/8")
2 inches minimum
–F = Gold flash on contact
Leave blank for standard plating:
30µ" (0,76 µm) Gold on contact area
(Standard sizes)
–S
–D
= Single End
= Double End
–SR
–P “XX”
= Position Polarization
= Strain Relief
No. of positions x
(2,00) .0787 + (7,874) .3100
01
02
TCSD
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
–N
–“XX.XX”
= Socket Strip
(1,02)
.040
Not available with –O, –M,
–R, –DXX or –BXX
Specify “XX” as position
number. Same position
will be polarized on
both ends.
(3,17)
.125
–D “XX”
1
–B “XX”
01
2"
min.
= Breakout
(4,00)
.158
= Daisy Chain
“XX”
Double
Row
Connectors
Specify “XX” as number of
conductors to be broken out.
No. of positions x (2,00) .0787 + (4,00) .157
(1,00) .039
1/8"
4" minimum
Outer
Most
(End of
assembly)
4
ALSO AVAILABLE
(MOQ Required)
• Other sizes
• Other platings
Contact Samtec.
“XX”
(5,08)
.200
(2,00)
.0787
(2,00)
.0787
–R
= Reversed
5"max.
2"min.
Breakout starts with Number 1
lead indicated by brown wire or
red stripe. Shown on top side.
5
2
POLARIZING KEY
Specify PK-01-07 for
polarizing key (Available
in wheels of six each).
Also polarizes SMM
Series socket strips.
EJECTOR HEADERS &
LOCKING CLIPS
–M
–RW
= Middle Reverse
= Reverse Wiring
See TMM Series.
Requires –DXX
• Ejector headers
• Locking clips
5
–O
01
= Outside Reverse
• Strain relief option
02
Note: TCSD Series
assemblies are nonstandard, non-returnable.
See EHT Series.
Blue or black wire
opposite position #1.
3
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
Requires –DXX
5
TCSD-25-D-05.00-01-N-SR 价格&库存
很抱歉,暂时无法提供与“TCSD-25-D-05.00-01-N-SR”相匹配的价格&库存,您可以联系我们找货
