F-218
HTMS–110–03–L–D–RA
HTMS–107–01–G–S
TMS–110–02–G–D
TMS–132–51–G–S
(1.27 mm) .050"
TMS, HTMS, SNM SERIES
THROUGH-HOLE MICRO HEADER
Mates with:
SMS, SLM, RSM
SPECIFICATIONS
For complete specifications
see www.samtec.com?TMS,
www.samtec.com?HTMS
or www.samtec.com?SNM
MICRO SHUNT
Insulator Material (TMS):
Black Liquid Crystal Polymer
Insulator Material (SNM):
Black Glass Filled Polyester
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
5 A per pin
(2 pins powered)
TMS mated with SMS
Operating Temp Range:
-55 °C to +105 °C with Tin;
-55 °C to +125 °C with Gold
Lead Size accepted (SNM):
(0.46 mm) .018" SQ
Insertion Depth (SNM):
(3.43 mm) .135" minimum
Max Processing Temp (SNM):
Not recommended for IR/VP
RoHS Compliant:
Yes
SNM SERIES
Choice of
through-hole
and right-angle.
See FTR Series
for surface mount
(1.27)
.050
(2.54)
.100
(3.30)
.130
Part No.
Plating
SNM–100–BK–T
Tin
Thirteen
terminal
styles
10 µ"
SNM–100–BK–G (0.25 µm)
Gold
TYPE
STRIP
Important Note:
Style -02 does not mate
with SMS Series.
PROCESSING
1
(1.27 mm x 2.54 mm)
.050" x .100" pitch
NO. PINS
PER ROW
LEAD
STYLE
01
thru
50
Specify
LEAD
STYLE
from
chart
TMS
Lead-Free Solderable:
Yes
= Standard
HTMS
RECOGNITIONS
= High Temp
T/H
LEAD
STYLE
–01
–02
–21
–51
–52
–53
–54
–55
–56
–57
–58
–59
–60
For complete scope of
recognitions see
www.samtec.com/quality
(1.27) .050 x No. of Positions
50
FILE NO. E111594
01
(2.48)
.098
(1.27) .050 TYP
02
100
(2.54)
.100
(4.98)
.196
ALSO AVAILABLE
99
(MOQ Required)
01
• Other platings
Contact Samtec.
A
B
(11.43) .450 (5.84) .230
(8.13) .320 (2.54) .100
C
(3.05) .120
(12.83) .505 (5.84) .230 (4.45) .175
(10.41) .410 (4.83) .190
–“XXX”
–G
= Polarized
Position
(Specify
position of
omitted pin)
= 10 µ"
(0.25 µm)
Gold on post,
Gold flash
on tail
RA
LEAD
STYLE
–01
(3.05) .120
–02
(17.91) .705 (12.32) .485
–03
(19.18) .755 (13.59) .535
B
(5.84)
.230
(2.54)
.100
(3.18)
.125
(20.96) .825 (15.37) .605
(3.56)
.140
B
A
C
(3.56)
.140
B
(1.52)
.060
C
(0.51) .020 DIA
SINGLE
ROW
–D
= Double
Row
(16.51) .650 (10.92) .430
A
(0.51)
.020
= Rightangle
(14.10) .555 (8.51) .335
(15.88) .625 (10.29) .405
–RA
–S
(12.83) .505 (7.24) .285
(15.49) .610 (9.91) .390
OPTION
= Single
Row
(10.80) .425 (5.21) .205
B
Note: Some lengths, styles
and options are non-standard,
non-returnable.
–L
= 10 µ"
(0.25 µm)
Gold on post,
Matte Tin
on tail
(0.46)
.018
SQ
(2.54)
.100
ROW
OPTION
PLATING
OPTION
DOUBLE
ROW
HTMS
–D
Body
Design
(1.52)
.060
(0.51) .020
DIA
(2.54)
.100
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
B
很抱歉,暂时无法提供与“TMS-136-60-S-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+119.701781+15.51563
- 10+113.3564110+14.69315
- 25+111.0644925+14.39608
