TW-03-04-T-D-335-110 数据手册
F-218 (Rev 10OCT17)
TW–08–09–F–T–165–100
TW–16–06–T–D–500–100
(2.00 mm) .0787"
TW SERIES
TW–20–03–L–Q–400–085
THROUGH-HOLE BOARD STACKERS
SPECIFICATIONS
For complete specifications
see www.samtec.com?TW-TH
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over
50 µ" (1.27 µm) Ni
Current Rating:
5.2 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +105 °C with Tin;
-55 °C to +125 °C with Gold
RoHS Compliant:
Yes
Lead–Free Solderable:
Yes
Board Mates:
CLT, SQT, SQW, ESQT,
TLE, SMM, MMS
Cable Mates:
TCSD
OTHER SOLUTIONS
Choice of
one through
six rows
Paste In Hole (PIH) processing.
Contact Samtec ASP Group.
ALSO AVAILABLE
RECOGNITIONS
(2.00 mm)
.0787 pitch
(MOQ Required)
For complete scope
of recognitions see
www.samtec.com/quality
FILE NO. E111594
Specify stacker
height in (0.13 mm)
.005" increments
• Other platings
Contact Samtec.
Notes:
For added mechanical
stability, Samtec recommends
mechanical board spacers be
used in applications with gold or
selective gold plated connectors.
Contact ipg@samtec.com for
more information.
LEAD
STYLE
NO. PINS
PER ROW
TW
02 thru 50
This Series is non-standard,
non-returnable.
Other Solutions
PLATING
OPTION
–F
Specify
LEAD
STYLE
from
chart
below.
= Gold flash
on post,
Matte Tin on tail
–L
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
2 mm Shunt
See 2SN Series.
Surface
Mount
See previous page.
(2.00)
.0787
TYP
Shrouded
Double
Row
See ZLTMM
Series.
No. of
rows
x
(2.00)
.0787
01 –S, –D*, –Q
See TMM Series.
See TMM Series.
= Matte Tin
04
Low
Profile
Rightangle
–T
300
ROW
OPTION
STACKER
HEIGHT
–S
–“XXX”
= Single
Row
= Double
Row
–T
= Triple
Row
–“XXX”
–Q
LEAD
STYLE
= Four
Row
–5
= Five
Row
–6
= Six
Row
POST
STACKER
(1.27)
HEIGHT
See OAL .050
MIN
Chart
TAIL
(2.00) .0787
(0.00) .000 MIN
–S, –D*, –Q
–T, –5, –6
ROW OPTION
–S, –D*, & –Q
–T, –5, –6
–01
–02
–03
–04
–05
–06
–07
–08
–09
–10
–11
–12
OAL
(8.20) .323
(9.60) .377
= Polarized
Position
(Specify
position to
be removed)
(13.60) .535
(14.10) .555
(15.10) .594
(17.10) .673
(19.10) .751
(21.10) .830
(11.60) .456
(15.60) .614
(10.08) .397
(28.19) 1.110
* Style –08 & –12 = S & D only
STACKER HEIGHT
(3.05) .120 MIN
(4.06) .160 MIN
* –D with stacker height greater than (4.06 mm) .160"
will not have standoffs.
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
–“XXX”
= Tail Length
in inches
(0.13 mm) .005"
increments
Example: -150
Example: –250
= (3.81 mm)
= (6.35 mm)
.150"
.250"
–D
–T, –5, –6 295
(0.51) .020 SQ
= Stacker
Height
in inches
(0.13 mm)
.005"
increments
TAIL
SPEC
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
TW-03-04-T-D-335-110 价格&库存
很抱歉,暂时无法提供与“TW-03-04-T-D-335-110”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 15+8.3191615+1.07250
- 国内价格 香港价格
- 1+9.487981+1.22319
- 50+7.6392350+0.98485
- 100+6.03791100+0.77841
- 500+3.71513500+0.47896
- 1000+3.329291000+0.42921
- 国内价格 香港价格
- 17+6.6996317+0.86371
