WC-ACH2830
WC-ACH2830
    JST
    TOOL HAND CRIMPER 28-30AWG SIDE
WC-ACH2830 数据手册
Crimp 1.2mm ACH CONNECTOR Emboss Tape Disconnectable Crimp style connectors (.047") pitch Features –––––––––––––––––––––––– • Top entry but side feed type Wires come out from horizontal direction of connector a Low profile {height: 1.4mm (.055")} Socket is mated with header from vertical direction of connector a Excellent workability • Connector for DC power supply In spite of compact and low profile type connector, rated current is 2A for both 2-circuit and 3-circuit with wire size AWG #28. • Corresponding to sucking nozzle of pick and place machine A sucking area on bottom of inside header is available. This ACH connector is compact and low profile type, height: 1.4mm (.055") and width 4.3mm (.169"), 1.2mm (.047") pitch wire-to-board connector. Specifications ––––––––––––––––––– PU SH 3 3 • Current rating: 2A AC, DC (AWG #28) • Voltage rating: 50V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/10m Ω max. After environmental testing/20m Ω max. • Insulation resistance: 100M Ω min. • Withstanding voltage: 500V AC/minute • Applicable wire: AWG #30 to #28 Insulation O.D./0.5 to 0.63mm (.020" to .025") * Contact JST if Lead-Free product is required. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 Recognized E60389 18 ACH CONNECTOR Contact ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Model No. 2.95(.116) 1.45(.057) SACH-003G-P0.2 1.2(.047) 0.7(.028) Applicable wire mm2 AWG# 0.05 to 0.08 30 to 28 Insulation O.D. mm(in.) Q'ty / reel 0.5 to 0.63(.020 to .025) 30,000 0.8(.031) Material and Finish 0.6(.024) Copper alloy, nickel-undercoated, gold-plated Housing ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– B Q'ty / bag ACHR-02V-S 1.2(.047) 2.6(.102) 1,000 ACHR-03V-S 2.4(.094) 3.8(.150) 1,000 Model No. 2 3 PUSH 3 B A 1.2(.047) Circuit No.1 mark Material PBT, UL94V-0, natural (white) 0.3(.012) 1.2(.047) 3.5(.138) Dimensions mm(in.) A Circuits As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. ACHR-02V-00S…natural (white) K…black Shrouded header ––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Circuits Model No. Q'ty / reel 2 BM02B-ACHSS-GAN-TF BM03B-ACHSS-GAN-TF 4,500 Circuit No.1 mark 3 4,500 Material and Finish B A 1.2(.047) Contact: Copper alloy, nickel-undercoated, gold-plated (nickel-stripe) Housing: Heat resisting resin, UL94V-0, natural (ivory) Solder tab: Copper alloy, copper-undercoated, tin-plated 3 1.4(.055) 4.3(.169) As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. BM02B-ACHSS-GAN-TFS…natural (ivory) 19 ACH CONNECTOR Taping specifications –––––––––––––––––––––––––––––––––––––––––––––––––––––– Feeding direction 380±2.0(14.961±.079)dia. Feeding direction [13(.512)dia.] 2.5 +.098 (-.039 ) W1+-1.0 Carrier tape Cover tape leader Leader part 100(3.937)min. The end part Connector 160(6.299)min. mounting part 400(15.748)min. 2.0±0.5(.079±.020) F±0.1(.004) 8.0±0.1 (.315±.004) Circuits Dimensions mm(in.) F W Reel dimensions mm(in.) W1 W±0.3(.012) 2.0±0.1 1.55±0.05 (.079±.004) (.061±.002)dia. 1.75±0.1 (.069±.004) Feeding direction 4.0±0.1 (.157±.004) Cover tape Carrier tape Q'ty / reel 2 5.5(.217) 12.0(.472) 13.5(.531) 4,500 3 7.5(.295) 16.0(.630) 17.5(.689) 4,500 Note: 1. Specifications conform to JIS C 0806. The tape width, connector loading recess square hole dimensions, etc. are determined by the number of circuits and external shape of the connector to be loaded. 2. Specifications are subject to change without prior notice. 0.8±0.05(.031±.002) 3.75±0.05(.148±.002) 0.6(.024)min. 0.7(.028) min. 0.85(.033) min. Note: 1. Tolerances are non-cumulative: ±0.05mm (±.002") for all centers. Note: 2. The dimensions above should serve as a guideline. Contact JST for details. 20 4.3(.169) 1.4(.055) 0.8±0.05(.031±.002) Header outline 1.2±0.05 (.047±.002) 2 circuits: 1.2±0.05 (.047±.002) 3 circuits: 2.4±0.05 (.094±.002) PC board layout (viewed from component side) and Assembly layout –––––––––––––––––– ACH CONNECTOR Applicator for the semi-automatic press AP-K2N ––––––––––––––––––––––––––––––– Contact SACH-003G-P0.2 Crimp applicator MKS-L-10-3 with safety cover without safety cover APLMK SACH003-02 APLNC SACH003-02 Compact crimp applicator MKS-LS with safety cover without safety cover – – Strip-crimp applicator MKS-SC with safety cover – 21
WC-ACH2830 价格&库存
很抱歉,暂时无法提供与“WC-ACH2830”相匹配的价格&库存,您可以联系我们找货
