873-902/VE00-0500
873-902/VE00-0500
    WAGO(万可电子)
    固态照明连接器 2 位置 插座,推入式 板至电缆/导线 按进式
873-902/VE00-0500 数据手册
Up to 20Amps! Luminaire Disconnect Connector Series 873, LUMI-NUTS® PUSH WIRE® Connector for Luminaire Disconnect, 873 Series LUMI-NUTS® Cu Polyamide 6.6 Molded in color coding for circuit wiring: Black = L White = N Red = dimming and switching (3-pole) Green = Ground (3-pole) Inkjet marking for additional requirements Integrated locking latch - automatic locking with mating of connectors simple push down to disengage Copper (not brass) for electrical integrity. UL94V-0 rated housing for utmost in flame-retardation These PUSH WIRE® male connectors clamp the following copper conductors: solid These PUSH WIRE® female connectors clamp the following copper conductors: stranded solid Engineered two-piece construction: Copper current bar and stainless steel spring combine to provide optimal contact pressure independent of the housing Completely touch-proof in the unmated position 100% protected against mis-mating PUSH WIRE® Connector for Luminaire Disconnect, 873 Series LUMI-NUTS® Male Connector 1,5‑mm Female Connector Male Connector Female Connector 3‑x‑AWG‑18 8‑x‑AWG‑18 3‑x‑0.75‑–‑ 3‑x‑0,75‑–‑ 1.5‑mm2«r» „e“ “s” 8‑x‑0.75‑–‑ 8‑x‑0,75‑–‑ 1.5‑mm2«r» 1,5‑mm „e“ “s”‑   8‑x‑AWG‑18‑– ‑  2‑–‑16‑«s» x AWG 18-12 “sol.” per pole 1 x AWG 18 “sol.” per pole‑16‑“sol.” 2 x AWG 16-12 “sol.” per pole 1 x AWG 18 “sol.” per pole ‑–‑16‑„sol.“ ‑–‑16‑“sol.” ‑–‑16‑«s» ‑–‑16‑„sol.“ 2 25‑x‑0,75‑–‑ x AWG 16-121,5‑mm
873-902/VE00-0500 价格&库存
很抱歉,暂时无法提供与“873-902/VE00-0500”相匹配的价格&库存,您可以联系我们找货
