BHS-114-T-A
BHS-114-T-A
    SAMTEC(申泰)
BHS-114-T-A 数据手册
F-218 BDL–110–G–F BBL–112–T–E BBD–130–T–B BHS–125–G–A (2.54 mm) .100" BBS, BBL, BHS, BBD, BDL SERIES BBS–116–G–C MACHINED BOARD STACKING STRIPS Mates with: SS, SD, HSS, SL, SDL, ESS, ESD TYPE STRIP 1 NO. PINS PER ROW PLATING OPTION LEAD STYLE FEATURES • Low-profile design achieves (3.89 mm) .153" board spacings when mated with SL Series. • Approach the reliability of a permanent connection with the flexibility of a separable connection. SPECIFICATIONS For complete specifications see www.samtec.com?BBS, www.samtec.com?BBL, www.samtec.com?BHS www.samtec.com?BBD or www.samtec.com?BDL Insulator Material: Black Glass Filled Polyester (BBS, BBD, BBL) Black High Temp Nylon (BDL) Black Liquid Crystal Polymer (BHS) Temperature Range: -55 °C to +125 °C Terminal Material: Phosphor Bronze or Brass Plating: Au or Sn over 50 µ" (1.27 µm) Ni RoHS Compliant: Yes Lead-Free Solderable: Wave only (BBS, BBD, BBL, BDL) Wave, or reflow with all Au (BHS) BBS –G (2.54) .100 x No. of Positions =20 µ" (0.51 µm) Gold (2.54) .100 = Standard Single Row (2.54) .100 TYP BBL = Low-Profile Single Row (1.27) .050 –T (2.54) .100 =Tin BBL body available with Styles –E & –F only. BHS BBS BHS = High Temp Single Row BBL (2.54) .100 x No. of Positions BBD 01 thru 32 (2.54) .100 (5.08) .200 = Standard Double Row (2.54) .100 TYP = BBS & BBL (1.27) .050 01 thru 36 (2.54) .100 BDL BDL BBD –A Z = (5.33 mm) .210" = BBD, BDL & BHS BDL body available with Styles –E & –F only. = Low-Profile Double Row –B Z = (8.51 mm) .335" –C Z = (14.86 mm) .585" RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality –E –F Z = (1.78 mm) .070" Z = (2.16 mm) .085" Style E: (2.74) .108 (3.18) .125 (0.46) .018 DIA (0.46) .018 DIA Z (1.27) .050 FILE NO. E111594 (1.78) .070 DIA Z (1.78) .070 DIA (3.18) .125 (0.46) .018 DIA (3.18) .125 BBL Series (1.27) .050 DIA (0.46) .018 DIA Z BBS and BHS Series Note: Some lengths, styles and options are non-standard, non-returnable. Style F: (3.18) .125 BBD Series BDL Series Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
BHS-114-T-A 价格&库存
很抱歉,暂时无法提供与“BHS-114-T-A”相匹配的价格&库存,您可以联系我们找货
BHS-114-T-A
  • 16+29.8222616+3.82654
