F-218 (Rev 10OCT17)
HTSW–116–11–G–S
10 YEAR MFG
WITH 30 µ" GOLD
EXTENDED LIFE
PRODUCT
HIGH MATING
CYCLES
TSW–209–09–F–S–RA
HTSW–115–05–L–Q
(2.54 mm) .100"
THROUGH-HOLE .025" SQ POST HEADER
Board Mates:
SSW, SSQ, SSM, ESW, ESQ,
BCS, BSW, CES, SLW
TYPE STRIP
Cable Mates:
IDSD, IDSS, SMSD, SMSS
(2.54 mm) Centers,
–1 = .100"
All Positions Filled
TSW = Standard
Strip
SPECIFICATIONS
For complete specifications
see www.samtec.com?TSW
or www.samtec.com?HTSW
HTSW
Insulator Material:
TSW: Black Glass Filled Polyester
HTSW: Natural Liquid
Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over 50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
Voltage Rating:
550 VAC mated with SSW;
500 VAC mated with
BCS or ESQ;
450 VAC -RA/-RE mated with
BCS or SSM
400 VAC mated with CES
RoHS Compliant: Yes
Lead–Free Solderable:
HTSW: Yes
TSW: No, Lead Wave Only
(2.54)
.100
(5.08)
.200
02
(2.54)
.100
100
01
03
(2.54) (5.02)
.100 .198
–D
(5.08) (7.56)
.200 .298
–T
99
150
(2.54)
(7.62) .100
.300
01
03
148
150
(5.08) (7.56)
.200 .298
(7.62)
.300
–Q
ESW SSW SLW SSQ SSM BCS SNT
01
5.2 A 5.7 A 5.2 A 6.3 A 5.2 A 4.6 A 4.3 A
–S
01
(5.08)
.200
CURRENT RATING
(PER PIN)
TSW mated with
(2.54)
.100
(2.48)
.098
50
(5.08 mm) Centers,
– 2 = .200"
Every Other Position Filled
(2.54)
.100
= Hi-Temp
Strip
(2.54) .100 x No. of Positions
Straight
Pin
Versions
NO. PINS
PER ROW
PIN CENTERS
TSW
148
= .100" (2.54 mm)
Center Version
HTSW
2 POSITIONS POWERED
RightAngle
Versions
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
FILE NO. E111594
(3.02)
.119 (1.78)
.070
APPLICATIONS
BCS
TSW
HORIZONTAL
ALSO AVAILABLE
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
(2.54)
.100
100
50
(8.12)
.320
–S
01
(2.54)
.100
(6.10)
.240
(1.78)
.070
(5.56)
.219
(1.78)
.070
01
99
03
150
(2.54)
.100
(5.08)
.200
(8.10)
.319
–D
02
thru
25
= .200" (5.08 mm)
Center Version
–T
(1.78)
.070
(1.78)
.070
(MOQ Required)
• Other platings
Contact Samtec.
(3.09)
(1.78) .122
.070
02
01
thru
50
01
148
03
150
(5.08)
.200
(8.12)
.320
(8.10)
.319
–Q
(1.78)
.070
(1.78)
.070
01
TSW
HTSW
148
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
TSW–109–10–F–D–RA
TSW–114–16–G–S–RE
HTSW–120–13–T–D
TSW–112–07–G–T
TSW, HTSW SERIES
PLATING
OPTION
LEAD
STYLE
ROW
OPTION
–S
–F
–L
–G
–T
–T
OTHER SOLUTIONS
= Double
Row
(5.08 mm)
.200"
row
space
Straight Pin Versions
A
B
C
(3.30)
.130
(2.41)
.095
(2.54)
.100
(5.08)
.200
(10.16)
.400
(12.70)
.500
(15.24)
.600
(17.78)
.700
(22.86)
.900
(8.51)
.335
(7.62)
.300
(10.92)
.430
(13.46)
.530
(18.54)
.730
(21.08)
.830
(23.62)
.930
(26.16)
1.030
(31.24)
1.230
(13.46)
.530
(2.67)
.105
(2.67)
.105
– 06
– 07
– 08
– 09
–10
–11
–12
–13
–14
–15
–16
–17
(2.79)
.110
(7.87)
.310
(2.79)
.110
(18.54)
.730
(21.08)
.830
STYLE
(5.84)
.230
(8.13)
.320
(13.21)
.520
(8.13)
.320
(15.74)
.620
–19
– 20
– 22
– 23
– 24
– 25
– 26
– 28
– 29
– 30
(0.64) .025 SQ Post
(2.79)
.110
– 21
– 27
* Available with – LL
(Locking Lead) Option
A
–18
– 41
– 42
(7.62)
.300
(2.92)
.115
(5.33)
.210
(3.20)
.126
(25.40)
1.000
(20.32)
.800
(23.11)
.910
(18.03)
.710
(0.89)
.035
(1.27)
.050
B
= –RA Option
with –LL Option
Two leads per strip crimped in
opposite directions on or near
centerline. See charts for available
styles. N/A with single row 1 or 2
positions. Recommended hole size
(1.02 mm ± 0.03 mm) .040" ± .001"
–“XXX”
= Polarized Position
(Specify “LEAD STYLE” from chart and select –RA or –RE from other options)
B
C
(23.62)
.930
(26.16)
1.030
(31.24)
1.230
(36.32)
1.430
(16.00)
.630
(11.30)
.445
(12.15)
.480
(16.00)
.630
(11.58)
.456
(33.78)
1.330
(28.70)
1.130
(33.78)
1.330
(28.70)
1.130
(9.27)
.365
(11.94)
.470
(18.29)
.720
(20.83)
.820
(25.91)
1.020
(30.99)
1.220
(5.84)
.230
(8.13)
.320
(5.84)
.230
(8.13)
.320
A
(2.29)
.090
(7.37)
.290
(9.91)
.390
(12.45)
.490
(14.99)
.590
(20.07)
.790
(5.08)
.200
(25.15)
.990
(4.83)
.190
(2.54)
.100
(22.61)
.890
(17.53)
.690
(20.32)
.800
(15.24)
.600
– 08
– 09
–10
–11
(5.84)
.230
(6.73)
.265
(8.13)
.320
SINGLE (– S
–RA LEAD
STYLE
–12
–13
–16
– 21
– 22
– 25
– 27
– 28
– 29
– 30
C
(5.84)
.230
(8.13)
.320
(5.84)
.230
(8.13)
.320
(5.84)
.230
(8.13)
.320
DOUBLE (– D)
▲ Except: Style –26
A
(0.46) .018 DIA Tail
(2.54)
.100
LEAD
STYLE
A
B
– RA (1.52)
.060
(0.64) .025 SQ Tail ▲
Specify -07 for best mate with IDXX Series IDC Cable
TRIPLE (–T & – Q)
A
A
(2.29)
.090
(7.37)
.290
(9.91)
.390
(12.45)
.490
(14.99)
.590
(20.07)
.790
(5.08)
.200
(2.29)
.090
(7.37)
.290
(9.91)
.390
(12.45)
.490
(14.99)
.590
– 09
–10
–11
–12
–13
–16
(5.08)
.200
– 21
N/A
N/A
– 22
(4.83)
.190
(2.54)
.100
(4.83)
.190
(2.54)
.100
– 27
– 28
(17.53)
.690
N/A
N/A
(15.24)
.600
C
(4.83)
.190
(7.37)
.290
(9.91)
.390
(12.45)
.490
(17.53)
.690
(2.54)
.100
(22.61)
.890
(2.29)
.090
(20.07)
.790
(14.99)
.590
C
(5.84)
.230
(8.13)
.320
(5.84)
.230
*Available with – LA
N/A
(1.78)
.070
B
A
C
(2.54)
.100
(2.54)
.100
– RE (4.06)
.160
(2.54)
.100
WWW.SAMTEC.COM
–RE LEAD SINGLE
STYLE
A
N/A
+ Style –41 & –42 available
with HTSW only.
C
–LA
–LL
= Locking Lead
Right-Angle Versions
(Specify “LEAD STYLE” from chart)
– 05
.025" SQ
TERMINAL
STRIP (TSW)
Requires 4 pin minimum
(NA with -T,-Q,-RA or -RE)
(1.27)
.050
–Q
• Elevated Right-angle option
• Shunts
Contact Samtec
IDSS or IDSD
STRIP ASSEMBLY
LOCKING
CLIP
PC
BOARD
= Triple
Row
= Matte Tin
–NA
= Right-angle
(using straight body for coplanar
mating with SSW-RA series)
= Double
Row
= 10 µ" (0.25 µm) Gold on post, Gold flash on balance
= Locking Clip
(Styles –08 thru
–13 & –22 only)
= Right-angle
–D
= 10 µ" (0.25 µm) Gold on post, Matte Tin on tail
–LC
– RA or –RE
= Single
Row
= Gold flash on post, Matte Tin on tail
STYLE
OTHER OPTIONS
很抱歉,暂时无法提供与“HTSW-105-14-SM-D”相匹配的价格&库存,您可以联系我们找货
