HW-23-09-G-D-410-SM-A-001
    SAMTEC(申泰)
    CONN HDR 46POS 0.1 STACK SMD
HW-23-09-G-D-410-SM-A-001 数据手册
REVISION BA DO NOT SCALE FROM THIS PRINT NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. HW-XX-XX-XX-X-XXXX-SM-X-XXX 2. TUBE POSITIONS -05 THRU -36 ONLY; POSITIONS -02 THRU -04 TO BE LAYER PACKAGED. No OF POSITIONS OPTION #2 3. MAXIMUM CUT FLASH: .020 [0.51] CUT FLASH TO BE POLARIZED POSITION -02 THRU -36 IN A NON-CRITICAL AREA LOCATED BETWEEN BODIES. SPECIFY OMITTED PIN 4. FOR ADDED MECHANICAL STABILITY, SAMTEC RECOMMENDS LEAD STYLE MECHANICAL BOARD SPACERS BE USED IN APPLICATIONS WITH OPTION #1 (SEE TABLE 1) GOLD OR SELECTIVE GOLD PLATED CONNECTORS. CONTACT -LC: LOCKING CLIP (SEE FIG 2, SHT 2) IPG@SAMTEC.COM FOR MORE INFORMATION. (-D: USE RTSM-50-DVU, USE LC-05-TM) PLATING SPECIFICATION 36 02 .195 4.95 REF 35 01 2 MAX SWAY .100 2.54 REF (EITHER DIRECTION) -S: SINGLE ROW 02 72 .295 7.49 REF 01 .200 5.08 REF 71 2 MAX SWAY (EITHER DIRECTION) (-S: USE TSM-50-SV BODY, USE LC-08-TM-02) -A: ALIGNMENT PIN (SEE FIG 3, SHT 2) (-S: 3 POSITION USE TSM-03-SV-A, MUST BE MOLDED TO POSITION) (4-50 POSITIONS USE TSM-XX-SV-XX, 2 POSITIONS TO USE TSM-48-SV-04) (-D: FOR MOLDED TO POSITION, USE RTSM-50-DVU-XX BODY, AVAILABLE ON POS -02 THRU -36) (-D: FOR STAKED, USE RTSM-50-DVU BODY, 3 POS MIN) -TR: TAPE & REEL (4 THRU 27 POSITIONS ONLY) (MAX HEIGHT: .6875) LEAVE BLANK FOR NO HOLD DOWN OPTION (-D: USE RTSM-50-DVU, CAN BE CUT TO POSITION, SEE FIG 1) (-S: USE TSM-50-SV, CAN BE CUT TO POSITION, SEE FIG 1) -T: MATTE TIN ON CONTACT AND TAIL. -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -G: 10µ" SELECTIVE GOLD IN CONTACT AREA, 3µ" SELECTIVE GOLD ON TAIL. -L: 10µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -TL: 250µ" TIN/LEAD ON CONTACT AND TAIL. -H: 30µ" SELECTIVE GOLD IN CONTACT AREA, 3µ" SELECTIVE GOLD ON TAIL. -F: 3µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -TM: MATTE TIN ON CONTACT AND TAIL. -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -LM: 10µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -FM: 3µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. FIG 1 HW-XX-10-XX-X-675-SM SHOWN (NO OF POS x .100[2.54]) +.000[0.00] - .015[0.38] SURFACE MOUNT ROW OPTION -D: DOUBLE ROW (USE RTSM-50-DVU FOR BOTTOM INSULATOR) (USE WRTSM-50-DVU FOR TOP INSULATOR) -S: SINGLE ROW (USE TSM-XX-S BODY FOR BOTTOM INSULATOR) (USE WTSM-50-SV FOR TOP INSULATOR) (NO OF POS -1) x .100[2.54] C .025 0.64 SQ REF (TYP) BOARD SPACE "A" = -XXX (SEE FIG 1 & TABLE 1) MAX= C + .150 "B" .000[0.00] MIN [("C" + .150[3.81]) -A] .050 1.27 .100 2.54 WTSM-50-SV .100 2.54 REF T-1S6-XX-XX-2 C WRTSM-50-DVU "A"±.008[0.20] BOARD OPTION (.250[6.35] MIN) (SEE TABLE 1) (MAX = "C" + .150[3.81]) +5° .100 2.54 REF 90° - 0° C .006[0.15] TSM-50-SV .050 1.27 RTSM-50-DVU UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [0.3] 2 .XXX: .005 [0.13] .XXXX: .0020 [0.051] MATERIAL: "H" REF * PROPRIETARY NOTE -S: SINGLE ROW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 INSULATOR: LCP, UL 94 V0, COLOR: BLACK TERMINAL: PHOS BRONZE DESCRIPTION: HW BOARD TO BOARD ASSEMBLY DWG. NO. HW-XX-XX-XX-X-XXXX-SM-X-XXX F:\DWG\MISC\MKTG\HW-XX-XX-XX-X-XXXX-SM-X-XXX-MKT.SLDDRW BY: G PURVIS 03/12/1993 SHEET 1 OF 3 REVISION BA +.000[0.00] "C" -.005[0.13] OAL REF .045 1.14 REF .055 1.40 .100 2.54 .110 2.79 LC-05-TM (NO OF POS -2) x.100[2.54] -D: DOUBLE ROW IN-PROCESS TSM-XX-SV-XX .063 1.59 REF SM-AH STAKED ALIGNMENT PINS -S: SINGLE ROW -LC: LOCKING CLIP (SAME AS FIG 1, DIFFERENT AS SHOWN) SEE TABLE 3 (NO OF POS -2) x.100[2.54] LC-08-TM-02 FIG 2 -S: SINGLE ROW -D: DOUBLE ROW TSM-XX-SV-XX SEE TABLE 3 "D" "A" .040 1.02 REF (NO OF POS -2) x.100[2.54] MOLDED ALIGNMENT PINS FIG 3 "B" "A" "B" -S: SINGLE ROW -D: DOUBLE ROW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, .062 1.57 REF .062 1.57 INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REF 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. .025 0.64 -A: ALIGNMENT PIN REF (TYP) (SAME AS FIG 1, DIFFERENT AS SHOWN) SECTION "A"-"A" (2 POS USE 1 PER STRIP, 3-36 POS USE 2 PER STRIP) SCALE 4 : 1 .045 1.14 REF SECTION "B"-"B" SCALE 4 : 1 DO NOT SCALE DRAWING SHEET SCALE: 2:1 DESCRIPTION: HW BOARD TO BOARD ASSEMBLY DWG. NO. HW-XX-XX-XX-X-XXXX-SM-X-XXX BY: G PURVIS 03/12/1993 F:\DWG\MISC\MKTG\HW-XX-XX-XX-X-XXXX-SM-X-XXX-MKT.SLDDRW SHEET 2 OF 3 REVISION BA FIG 4 PACKAGING VIEW (TUBE PLUG LOCATED AS SHOWN) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 DESCRIPTION: HW BOARD TO BOARD ASSEMBLY DWG. NO. HW-XX-XX-XX-X-XXXX-SM-X-XXX BY: G PURVIS 03/12/1993 F:\DWG\MISC\MKTG\HW-XX-XX-XX-X-XXXX-SM-X-XXX-MKT.SLDDRW SHEET 3 OF 3
HW-23-09-G-D-410-SM-A-001 价格&库存
很抱歉,暂时无法提供与“HW-23-09-G-D-410-SM-A-001”相匹配的价格&库存,您可以联系我们找货
