IDSD-20-S-10.00-T-G
IDSD-20-S-10.00-T-G
    SAMTEC(申泰)
    INSULATION DISPLACEMENT TERMINAL
IDSD-20-S-10.00-T-G 数据手册
SLIM BODY FLAT RIBBON IDC CABLES (2.54 mm) .100" PITCH • IDSS/IDSD/IDMS/IDMD SERIES IDSS/IDMS/IDMD Mates: TSW, MTSW, TSM, EJH, PHT, HMTSW, HTSW, HW, DW, EW, ZW, MTLW IDSD SERIES IDM = Standard Tail Male Plug IDS Mates: TST, HTST, ZST, EJH = Socket SPECIFICATIONS Insulator Material: Black Glass Filled Polyester Contact (IDSS/IDSD): BeCu Terminal (IDMS/IDMD): Phosphor Bronze Plating: Au over 50 µ" (1.27 µm) Ni or Sn over 100 µ" (2.54 µm) Cu or 50 µ" (1.27 µm) Ni Wire: 28 AWG 7/36 stranded Tinned CopperWeb footer Current Rating (IDMD): 3 A per pin (2 pins powered) Temperature Range: -20 °C to +105 °C (Rainbow Cable) -40 °C to +105 °C (Gray Cable) Voltage Rating: 425 VAC/600 VDC Lead Size Range: (0.56 mm) .022" SQ to (0.71 mm) .028" SQ Lead Insertion Depth: (5.59 mm) .220" to (6.22 mm) .245" - ROW OPTION NO. PINS PER ROW S –02 thru –32 D –02 thru –36 = Single = IDMS/IDMD = Double (Color coded cable Not available for 31 thru 36 pins/row. See –G option.) DOUBLE Full size (64 positions): (82.55) 3.250 Less than 64 positions: No. Positions/row X (2.54) .100 + (1.68) .066 SINGLE Full size (32 positions): (81.53) 3.210 Less than 32 positions: No. Positions/row X (2.54) .100 + (0.71) .028 = IDSS/IDSD IDMS (Single) IDMD (Double) (2.54) .100 (5.08) .200 (For square or long tail see HCMX Series) IDMX shown DOUBLE Full size (72 positions): (92.71) 3.650 Less than 72 positions: No. Positions/row x (2.54) .100 + (1.50) .059 SINGLE Full size (36 positions): (91.69) 3.610 Less than 36 positions: No. Positions/row x (2.54) .100 + (0.48) .019 IDSS (Single) IDSD (Double) (5.08) .200 (2.54) .100 (9.27) .365 REF IDSX shown ALSO AVAILABLE Molded-To-Position IDC Assembles Low Profile Skinny side locks Dual beam contacts Single and double row (6.35mm) .025" square and (5.84mm) .230" length tail available Visit samtec.com?HCSD, samtec.com?HCSS, samtec.com?HCMD or samtec.com?HCMS for more detailed information. Single End (—S) Double End (—D) Transfer End (—T) Note: This Series is non-standard, non-returnable. F-224 samtec.com?IDSS, samtec.com?IDSD, samtec.com?IDMS or samtec.com?IDMD Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. - - END ASSEMBLY - –S ASSEMBLED LENGHTH - OPTION –“XX.XX” = Single End (Socket or Male Plug on one end) –T = Assembled Length –B “XX” = Tin Plating (Both Ends) –D = Breakout (Specify “XX” as number of conductors to be broken out) (Breakout starts with Number 1 lead indicated by brown wire or red stripe. Shown on top side) –C = Double End (Socket or Male Plug on each end) = Tin IDM, 10 µ" (0.25 µm) Gold IDS (-T End Assembly Required) –T –RW –A = Transfer End (Male Plug on one end with socket on other. Begin part number with IDM) = Reverse Wiring (#1 wire opposite position #1) = Tin IDS, 10 µ"(0.25 µm) Gold IDM (-T End Assembly Required) –S “XX” –P “XX” =Polarized Specify “XX” as position. For Double the same position will be polarized on both ends. (Not available on IDM unless transfer, then only the socket is polarized.) = Daisy Chain, Single (When mating double row connector with two single row connectors, the outer most single will be connected to Conductor #1 and the inside single to Conductor #2) –D “XX” = Daisy Chain, Double –G Assembled Length in INCHES (±1/8" ) (2 inches minimum) Assembled Length (—“XX.XX”) 72 04 02 71 03 01 Polarized (—P “XX”) = Gray Cable Specify –G for Gray cable. Gray cable has one red edge. IDSS and IDMS uses (2.54 mm) .100" centerline cable. IDSD and IDMD uses (1.27 mm) .050" centerline cable. Cable is 28 AWG 7/36 copper wire. Standard cable is same as above except color –W “XX” = Wiring Reverse Daisy Chain, Single (Same as –S “XX” except outer strip connected to Conductor #2 and inside strip connected to Conductor #1) –R = Reversed –M = Middle Reversed (Requires –SXX, –WXX or –DXX) –ST “X” = Stripped & Tinned (Specify Suffix from table) (All dimensions are ± 1/16" (1.59 mm) (Not available in 28 positions and higher) –O = Outside Reversed (Requires –SXX, –WXX or –DXX) “XX” ± 1⁄8" 2" min. “XX” –ST8 1 –ST4 1 –ST2 –ST3 Outer Most /8" (3.18) /4" (6.35) /2" (12.70) 1 3 /8" (9.53) Stripped & Tinned (—ST “X”) Reversed (—R) Double Row Connectors (IDSD or IDMD) 5"max. 2"min. Breakout starts with Number 1 lead indicated by brown wire or red stripe. Shown on top side. 4" minimum Daisy Chain SIngle (—S “XX”) Breakout (—B “X”) Middle Reversed (—M) Outside Reversed (—O) samtec.com?IDSS, samtec.com?IDSD, samtec.com?IDMS or samtec.com?IDMD Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
IDSD-20-S-10.00-T-G 价格&库存
很抱歉,暂时无法提供与“IDSD-20-S-10.00-T-G”相匹配的价格&库存,您可以联系我们找货
IDSD-20-S-10.00-T-G
  • 1+93.085151+11.94388
