MOLC-140-M1-L-Q-LC
MOLC-140-M1-L-Q-LC
    SAMTEC(申泰)
    针座连接器 表面安装,通孔 160 位置 0.050"(1.27mm)
MOLC-140-M1-L-Q-LC 数据手册
MOLC–120–01–L–Q–LC F-215 MOLC–150–02–L–Q MOLC–135–02–L–Q–LC (1,27 mm) .050" MOLC SERIES QUAD ROW TERMINAL STRIP SPECIFICATIONS Ultra-high density four row design Mates with: FOLC APPLICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?MOLC FOLC Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27 µm) Ni Current Rating: 2.6 A per pin (1 pin powered per row) Operating Temp Range: -55°C to +125°C RoHS Compliant: Yes MATED HEIGHT MOLC LEAD STYLE MATED MOLC FOLC HEIGHT* (5,97) –01 .235 –11 –01 (7,75) .305 (11,43) –31 .450 *Processing conditions will affect mated height. Choice of through-hole or surface mount Processing: Lead-Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max (20-25) (0,15 mm) .006" max (30-50) Locking clip option RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality NO. PINS PER ROW 1 MOLC 20, 25, 30, 35, 40, 45, 50 OTHER SOLUTIONS (Standard sizes) PLATING OPTION LEAD STYLE –L = Through-hole (Specify from chart) = 10µ" (0,25 µm) Gold on post, Matte Tin on tail –P –M1 = Pick & Place Pad (–02 only) = Mixed Technology ALSO AVAILABLE MIXED TECHNOLOGY (MOQ Required) • Other sizes • Alignment pins • Other platings Contact Samtec. LEAD STYLE – 01 –11 –31 A B (0,25) .010 THROUGHHOLE Note: Some sizes, styles and options are non-standard, non-returnable. (3,05) .120 (1,90) .075 (1,40) .055 (6,35) .250 (1,27) .050 TYP (8,13) .320 (2,59) .102 No. of positions x (1,27) .050 + (2,54) .100 No. of positions x (1,27) .050 + (0,76) .030 A1 B1 C1 D1 B (5,59) (3,38) .220 .133 (7,34) .289 (3,66) (11,05) .144 .435 = Locking Clip (Manual placement required) = Surface Mount (3,38) .133 (5,59) .220 OPTION –LC –‘X’1 –02 • Surface mount design with Tiger Buy™ contacts (see TOLC/SOLC Series) Q (0,46) .018 DIA TYP (1,27) .050 TYP (5,59) .220 A (0,64) (0,25) .025 .010 (0,36) .014 TYP TYP Through-Hole = No. of positions x (1,27) .050 + (1,65) .065 Surface Mount = No. of positions x (1,27) .050 + (1,52) .060 WWW.SAMTEC.COM (1,42) .056 –LC OPTION (8,26) .325 (2,59) .102 Optional Locking Clip (–LC) Due to technical progress, all designs, specifications and components are subject to change without notice. –TR = Tape & Reel (–02 only) (3,30) .130 SURFACE MOUNT
MOLC-140-M1-L-Q-LC 价格&库存
很抱歉,暂时无法提供与“MOLC-140-M1-L-Q-LC”相匹配的价格&库存,您可以联系我们找货
MOLC-140-M1-L-Q-LC
  • 1+393.672941+50.93211
  • 10+372.7058110+48.21945
  • 25+358.7099525+46.40871
  • 50+349.9647150+45.27728
  • 100+345.97724100+44.76139
库存:62
