F-218
MTMS–130–02–G–D–100
MTMS–110–02–G–D–100
MTMS–125–51–G–S–200
(1.27 mm) .050"
MTMS, HMTMS SERIES
MODIFIED MICRO TERMINAL
Mates with:
SMS, SLM, RSM
SPECIFICATIONS
For complete specifications
see www.samtec.com?MTMS
or www.samtec.com?HMTMS
Insulator Material:
Black Liquid Crystal
Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +105 °C with Tin
-55 °C to +125 °C with Gold
RoHS Compliant:
Yes
Position anywhere
in the body with
(3.05 mm) .120"
minimum tail
PROCESSING
Ideal for board
stacking
applications
Single row
and double row
Lead-Free Solderable:
Yes
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
TYPE
STRIP
1
NO. PINS
PER ROW
LEAD
STYLE
01
thru
50
Specify
LEAD
STYLE
from
chart
PLATING
OPTION
ROW
OPTION
POST
HEIGHT
OPTION
–S
–“XXX”
–“XXX”
FILE NO. E111594
ALSO AVAILABLE
(MOQ Required)
• Other platings
Contact Samtec.
–L
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
MTMS
–G
= Modified Standard
= Single
Row
–D
= Double
Row
= 10 µ" (0.25 µm)
Gold on post,
Gold flash on tail
HMTMS
= Modified High Temp
(1.27) .050 x No. of Positions
LEAD
STYLE
(2.48)
.098
50
01
02
100
(2.54)
.100
(4.98)
.196
01
HMTMS –D
BODY DESIGN
99
(1.27) .050 TYP
(0.46) .018 SQ
B
(0.00) .000
MIN
(2.54)
.100
OAL
(3.05)
C .120
MIN*
(0.51)
.020
(0.51) .020 DIA
SINGLE ROW
Note: This Series is
non-standard, non-returnable.
DOUBLE ROW
–01
–02
–25*
–51
–52
–53
–54
–55
–56
–57
–58
–59
–60
= “B”
Dimension
(Specify Post
Height in
inches
(0.13 mm)
.005"
increments)
B
OAL
(Maximum
when C =
(3.05 mm) .120")
(11.43) .450
(5.84) .230
(8.13) .320
(2.54) .100
(8.38) .330
(3.18) .125
(10.41) .410
(4.83) .190
(10.80) .425
(5.21) .205
(12.83) .505
(7.24) .285
(14.10) .555
(8.51) .335
(15.49) .610
(9.91) .390
(15.88) .625
(10.29) .405
(16.51) .650
(10.92) .430
(17.91) .705
(12.32) .485
(19.18) .755
(13.59) .535
(20.96) .825
(15.37) .605
*Style -25 tail C = (2.67 mm) .105" min
is available.
Tail DIA is .020" (0.51 mm) for min .120" (3.05 mm).
Balance of tail is .018" (0.46 mm) SQ.
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
= Polarized
Position
(Specify
position of
omitted pin)
MTMS-120-55-S-S-365 价格&库存
很抱歉,暂时无法提供与“MTMS-120-55-S-S-365”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 23+43.5096423+5.64534
