QMS-026-01-SL-D-RA
QMS-026-01-SL-D-RA
    SAMTEC(申泰)
    .635MM DOUBLE ROW TERMINAL STRIP
QMS-026-01-SL-D-RA 数据手册
F-214 QMS–052–01–SL–D–RA–MG TM QMS–016–01–SL–D–DP–RA–MG (0,635 mm) .025" QMS-RA SERIES RIGHT ANGLE GROUND PLANE HEADER SPECIFICATIONS Board Mates: QFS Integral metal plane for power or ground For complete specifications and recommended PCB layouts see www.samtec.com?QMS-RA Insulator Material: Liquid Crystal Polymer Terminal & Ground Plane Material: Phosphor Bronze Plating: Au over 50µ" (1,27 µm) Ni (Tin on Ground Plane Tail) Current Rating (-RA to -RA): Signal Contact: 4.1 A per pin (1 pin powered per row) Ground Plane: Testing Now Voltage Rating: 300 VAC Operating Temp: -55°C to +125°C RoHS Compliant: Yes Processing: Lead–Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max (026-052) (0,15 mm) .006" max (078) Rated @ 3dB Insertion Loss* with PCB w/o PCB effects* effects** 8 GHz / 10 GHz / Single-Ended Signaling –D 16 Gbps 20 Gbps 5.5 GHz / 11 GHz / Differential Pair Signaling –D 11 Gbps 22 Gbps Rated @ 3dB QMS-RA/QFS-RA Type Insertion Loss* Single-Ended Signaling –D 6 GHz / 12 Gbps Differential Pair Signaling –D 5.5 GHz / 11 Gbps *Performance data includes effects of a non-optimized PCB. **Test board losses de-embedded from performance data. Complete test data available at www.samtec.com?QMS-RA or contact sig@samtec.com QMS-RA/QFS QMS RECOGNITIONS Type PINS PER ROW NO. OF PAIRS 01 • Increased insertion depth Metal guide post option PLATING OPTION TYPE RA • Integral guide post • PCB mounting pins MG OTHER OPTION For complete scope of recognitions see www.samtec.com/quality –026, –052, –078 (52 total pins per bank = –D) –016, –032, –048 (16 pairs per bank = –D–DP) –SL –D –MG –K = 10µ" (0,25 µm) Gold on Signal Pins and Ground Plane, Matte Tin on tails = Single-Ended = Metal Guide Post = Polyimide film Pick & Place Pad –D–DP = Differential Pair –TR OTHER SOLUTIONS Combination Signal/Power See QMS-RA-PC Series or QFS-RA-PC Series = Tape & Reel (–016, –026, –032 & –052 positions only) No. of Banks x (21,34) .840 + (12,45) .490 (11,87) .467 ALSO AVAILABLE (5,72) .225 (MOQ Required) No. of Banks x (21,34) .840 + (5,33) .210 01 (1,40) .055 (8,13) .320 02 (0,30) .012 No. of Banks x (21,34) .840 + (6,10) .240 (0,64) .025 SQ (0,89) .035 DIA (1,57) .062 DIA • Other platings • Plastic Guide Post option • –02 lead style for (2,36 mm) .093" thick board • 64 (-DP) and 104 positions per row Contact Samtec. Note: Some lengths, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM
QMS-026-01-SL-D-RA 价格&库存
很抱歉,暂时无法提供与“QMS-026-01-SL-D-RA”相匹配的价格&库存,您可以联系我们找货
