SM09B-HCHK-TB(LF)(SN)
    JST
    插件
    线对板针座
SM09B-HCHK-TB(LF)(SN) 数据手册
HCHCONNECTOR Board-to-wire Features ●Miniaturization Using the short length female terminal, the miniaturization is realized. ●Surface mounting Corresponding to the surface mounting (lead-free), mounting workability is improved. ●Reliability High reliability ensures by using proven female terminal in the automotive electrical equipment. 2.54mm pitch, 0.64 unsealed connector for automotive corresponding to the surface mounting. Specifications ¡Current rating: 5A AC, DC (0.5mm2, Single circuit) ¡Voltage rating: 50V AC, DC ¡Temperature range: -40°C to +120°C (including temperature rise in applying electrical current) ¡Contact resistance: Initial value/10mΩ max. After environmental testing/20mΩ max. ¡Applicable wire: AVSS 0.3mm2 to 0.5mm2 ∗ Compliant with ELV/RoHS. ∗ Contact JST for details. 1 HCH CONNECTOR Female terminal Applicable wire range 11.6 Model No. Conductor (mm2) Insulation O.D. (mm) Q’ty/reel SHCM-A03T-P025 0.3 to 0.5 1.4 to 1.8 5,000 Material and Finish 2.5 Copper alloy, tin-plated (reflow treatment) Female connector ¡4 circuits 12.46 Circuits Model No. Q’ty/box 4 HCMPB-04-K 600 9 HCHFB-09-KE 300 14.8 Material Housing: PBT, black Retainer: PBT, blue 11 7.95 Housing 2.54 Retainer 3×2.54=7.62 ¡9 circuits (1.3) 7.95 (11.25) 14.8 25.2 2 HCH CONNECTOR Male connector ¡4 circuits ¡9 circuits 2.54×8= 20.32 3×2.54=7.62 2.54 (8.65) (8.65) 15 21 21.8 21 15 32.3 8.2 1.95 10.9 8.2 10.7 1.95 10.9 19.6 10.7 21.8 2.54 12.65 25.4 15.9 28.6 Circuits Model No. Q’ty/reel 4 SM04B-HCHK-TB 220 9 SM09B-HCHK-TB 220 Material and Finish Housing: Glass-filled LCP, black Terminal: Brass, nickel-undercoated, tin-plated Reinforcing tab: Brass, nickel-undercoated, tin-plated Note: This product displays (LF)(SN) on a label. Taping Specifications ¡4 circuits ¡9 circuits 45+2.5 -1 57+2.5 -1 2±0.5 2±0.5 φ380±2 Feeding direction φ380±2 Feeding direction 3 (φ1 ) ) 3 (φ1 Feeding direction 28±0.1 1.75±0.1 1.75±0.1 Feeding direction ±0.1 4 2±0.1 φ1.5+0.1 0 28±0.1 φ1.5+0.1 0 4±0.1 2±0.1 Carrier tape 26.2±0.1 52.4±0.1 56±0.3 44±0.3 40.4±0.1 20.2±0.1 Carrier tape Cover tape Cover tape Feeding direction Feeding direction Carrier tape The end part Connector 160min. mounting part 3 Cover tape leader Leader part 100min. 400min. Carrier tape The end part Connector 160min. mounting part Cover tape leader Leader part 100min. 400min. HCH CONNECTOR PC board layout, Assembly layout ¡4 circuits ¡9 circuits 2.54×8=20.32 4.3±0.05 4.3±0.05 2.54×3=7.62 1.04±0.05 2.54±0.05 1.04±0.05 2.54±0.05 (25.9) (11.45) 11.2 10 1(PCB Edge) 1(PCB Edge) 10 11.2 (19.1) 3.6 3.6 21.2 33.9 Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. The dimensions above should serve as guideline. Contact JST for details. Crimping machine, Applicator Crimp applicator MKS-L Strip terminal Crimping machine Dies Crimp applicator with dies SHCM-A03T-P025 AP-K2N MK/SHCM-A03-025 APLMK SHCM-A03-025 Note: When crimping operation is conducted using an applicator and die set other than the above, JST cannot guarantee the performance of the terminal. 4
SM09B-HCHK-TB(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“SM09B-HCHK-TB(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
库存:38
