STMM-117-02-G-D-RA
STMM-117-02-G-D-RA
    SAMTEC(申泰)
    针座连接器 通孔,直角 34 位置 0.079"(2.00mm)
STMM-117-02-G-D-RA 数据手册
SHROUDED IDC HEADER & STACKER (2.00 mm) .0787" PITCH • STMM/ZSTMM SERIES STMM/ZSTMM Mates: TCSD (except –SR) STMM -1 04, 05, 06, 07, 08, 10, 12, 13, 14, 15, 17, 20, 22, 25 SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +105 °C with Tin; -55 °C to +125 °C with Gold - 02 - NO. PINS PER ROW -D- PLATING OPTION –F = Gold flash on post, Matte Tin on tail –L (Standard sizes) - TAIL OPTION –RA = Locking Clip (-SM only) (Manual placement required) –SM = Surface Mount –K = (7.50 mm) .295" DIA Film Pick & Place Pad (-SM only) = Matte Tin –TR   = Tape & Reel (–SM only) –FR T/H ZSTMM —SM -1   —RA 04, 05, 06, 07, 08, 10, 12, 13, 14, 15, 17, 20, 22, 25 (Standard sizes) - LEAD STYLE Specify LEAD STYLE from chart - PLATING OPTION –F BODY HEIGHT –“XXX” = Body Height - OTHER OPTION –“XX” = Polarized Position –L –T = Matte Tin (6.00) .237 (4.80) .190 -D- = Gold flash on post, Matte Tin on tail = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail (2.00) .0787 x No. of positions + (6.17) .243 = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (–SM only) —RA —SM NO. PINS PER ROW       Notes: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@samtec.com for more information. –LC = Right-angle   Other sizes Other platings = Polarized Position –T PROCESSING MOQ Required –“XX” Leave blank for Through-hole = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail  [ 1RRISRVLWLRQV   Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max ALSO AVAILABLE OTHER OPTION BODY HEIGHT (6.35) A .250 (OAL) MIN (2.29) .090 MIN LEAD STYLE A (OAL) MAX BODY HEIGHT –75 (9.58) 0.377 (7.42) 0.292 –62 (10.08) 0.397 (7.92) 0.312 –65 (10.49) 0.413 (8.33) 0.328 –73 (12.09) 0.476 (9.93) 0.391 –63 (14.10) 0.555 (11.94) 0.470 –66 (15.09) 0.594 (12.93) 0.509 –69 (15.60) 0.614 (13.44) 0.529 –74 (17.09) 0.673 (14.94) 0.588 –70 (17.60) 0.693 (15.44) 0.608 –71 (21.08) 0.830 (18.92) 0.745 –72 (21.62) 0.851 (19.46) 0.766 This Series is non-standard, non-returnable. samtec.com?STMM or samtec.com?ZSTMM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
STMM-117-02-G-D-RA 价格&库存
很抱歉,暂时无法提供与“STMM-117-02-G-D-RA”相匹配的价格&库存,您可以联系我们找货
