TS-117-T-A-1
TS-117-T-A-1
    SAMTEC(申泰)
    排针
TS-117-T-A-1 数据手册
F-215 TD –108–G–AA HTS–115–T–C–2 TS –119–G–A–1 (2,54 mm) .100" TS, TD, HTS SERIES PRECISION MACHINED TERMINAL STRIPS SPECIFICATIONS For complete specifications see www.samtec.com?TS, www.samtec.com?TD or www.samtec.com?HTS Insulator Material: Black G.F. Polyester (TS, TD) Black Liquid Crystal Polymer (HTS) Terminal Material: Brass, except Style G is Phosphor Bronze Plating: Au over 50µ" (1,27 µm) Ni or Sn over 100µ" (2,54 µm) Cu or 50µ" (1,27 µm) Ni Operating Temp Range: -55°C to +125°C with Gold -55°C to +105°C with Tin RoHS Compliant: Yes Lead-Free Solderable: Wave only Mates with: SS, SD, HSS, SL, SDL, ESS, ESD 1 PLATING OPTION NO. PINS PER ROW Note: Some lengths, styles and options are non-standard, non-returnable. TS = Single Row Terminal Strip LEAD STYLE –G = 20µ" (0,51 µm) Gold Except –J & –L are 10µ" (0,25 µm) Gold (2,54) .100 x No. of Positions (2,54) .100 (2,54) .100 TYP –T = Tin HTS = Single Row High Temp Terminal Strip (2,54) .100 01 thru 32 =TS Series (2,54) .100 x No. of Positions RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality TYPE STRIP (5,08) .200 01 thru 36 (2,54) .100 TD = HTS & TD Series (2,54) .100 TYP = Double Row Terminal Strip (2,54) .100 –AA (0,46) .018 DIA (1,78) .070 DIA (0,46) .018 DIA (4,22) .166 (0,64) .025 DIA -A (1,32) .052 (1,32) .052 Y X (1,32) .052 DIA (0,46) .018 DIA (1,83) .072 DIA (4,47) .176 (4,75) .187 Component No. = T-1R5- (1,83) .072 DIA Y (3,18) .125 ± .010 LEAD STYLE (3,99) .157 X Y (DIA) (±.015) (0,46) (3,96) .018 .156 (0,64) .025 (5,33) (0,89) .210 .035 -C (2,54) .100 -C-1 -C-2 X Y -C Component No. =T-1R2-C-X Component No. =T-1R9- –L–1, –L–2, –L–3 (1,07) .042 DIA (1,07) .042 (1,83) .072 DIA LEAD STYLE -L-1 (3,81) .150 (7,62) .300 ± .015 (0,89) .035 (DIA) (±.015) (0,46) (3,96) .018 .156 (0,64) .025 (5,33) (0,89) .210 .035 –J (0,51) .020 DIA (12,90) (1,02) .508 .040 ± .015 X -A Component No. =T-1R0-A-X Component No. =T-1R7 –G–1 (0,51) .020 -A-1 -A-2 Component No. = T-1R5- (1,78) .070 DIA LEAD STYLE (4,22) .166 (1,78) .070 DIA (3,96) .156 ±.015 –C, –C–1, –C–2 –A, –A–1, –A–2 (1,32) .052 DIA (0,51) .020 DIA Component No. = S-1P1- (0,76) .030 -L-2 Z (1,32) .052 DIA -L-3 Y (0,64) .025 SQ Component No. = S-1W1 WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. Y Z (DIA) (±.015) (12,95) .510 (9,14) .360 (6,60) .260 (17,86) .703 (14,05) .553 (11,51) .453
TS-117-T-A-1 价格&库存
很抱歉,暂时无法提供与“TS-117-T-A-1”相匹配的价格&库存,您可以联系我们找货
TS-117-T-A-1
  • 13+31.6059113+4.08504
TS-117-T-A-1
  • 4+27.003654+3.49020
库存:220
TS-117-T-A-1
  • 1+29.980901+3.87510
  • 52+24.5549052+3.17370
  • 104+21.04530104+2.72010
库存:37
