TSM-104-01-S-SV-A-TR 数据手册
SURFACE MOUNT
.025" SQ POST HEADER 8
G b p s
(2.54 mm) .100" PITCH • TSM SERIES
TSM
Board Mates:
SSW, SSQ, SSM, BSW, ESW,
ESQ, BCS, SLW, CES, HLE
Cable Mates:
IDSS, IDSD
TSM
1
NO. PINS PER ROW
LEAD STYLE
02 thru 36
Specify
LEAD STYLE
from chart
SPECIFICATIONS
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +105 °C with Tin;
-55 °C to +125 °C with Gold
Voltage Rating:
495 VAC -SV/-DV
mated with the BCS
475 VAC -SV/-DV
mated with the SSM
(2.54) .100 x No. of positions
(2.54)
.100
Post
Height
(2.54)
.100
MATES
TSM/SSW
(3.05)
.120
TSM/HLE
4.1 A
TSM/BCS
5.0 A
2 POSITIONS POWERED
–01
(5.84)
.230
SSW, BCS,
SSM, IDSS, IDSD
–02
(8.13)
.320
SSM -DH
–03
(10.67)
.420
Bottom Mount &
Pass Through
–04
(3.05)
.120
SLW, CES, HLE
Post
Height
4.7 A
5.4 A
MATES
WITH
(No. of positions x (2.54) .100) – (5.08) .200
CURRENT RATING
(PER PIN)
TSM/SSM
LEAD
POST
STYLE HEIGHT
—SV Row Option
PROCESSING
Lead–Free Solderable:
Yes
-DH/-SH/-SV Lead Coplanarity:
(0.15 mm) .006" max (02-36)*
-DV Lead Coplanarity:
(0.10 mm) .004" max (02-05)
(0.13 mm) .005" max (06-10)*
(0.15 mm) .006" max (11-36)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
(3.81)
.150
(2.54)
.100
–01= (4.57) .180
–02, –03, –04 = (4.82) .190
—SH Row Option
(5.08)
.200
Post
Height
Notes:
Severe Environment
Testing qualified; aligns
with MIL-DTL-55302.
Visit samtec.com/set
Some sizes, styles and
options are non-standard,
non-returnable.
F-224 (Rev 26APR24)
(2.54)
.100
(3.81)
.150
(No. of positions -2) x (2.54) .100)
—DV Row Option
samtec.com?TSM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
PLATING OPTION
ROW OPTION
–F
–SV
= Gold flash on post, Matte Tin on tail
= Single Row Vertical Pin
–L
–DV
= 10 µ" (0.25 µm) Gold on post,
Matte Tin on tail
= Double Row Vertical Pin
–S
= Single Row Horizontal Pin
–SH
= 30 µ" (0.76 µm) Gold on post,
Matte Tin on tail
–DH
= Double Row Horizontal Pin
–T
–TM
= Matte Tin
= Triple Row Vertical Mixed Technology
(Style –01 only)
(02 thru 30 positions only)
–MT
= Mixed Technology Pin
(Style –01, –02 or –03 only)
–“XXX”
= Polarized Position
–A
= Alignment Pin
metal or plastic at Samtec discretion
(Not available with –TM or –MT)
(02 positions minimum)
(Not available with –LC)
–LC
= Locking Clip
(Not available with –TM)
(3 positions minimum)
(Not available with –A)
(Manual placement required)
–K
= (6.50 mm) .256" DIA
Polyimide Film Pick & Place Pad
(–SH: 4 positions minimum without –TR;
2 & 3 positions available with –TR)
(–DH: 4 positions minimum without –TR)
–P
= Plastic Pick & Place Pad
(–DV: 4 positions minimum without –TR;
(–DH: 5 positions minimum without –TR)
(–SV: 4 positions minimum without –TR;
(6.10)
.240
(No. of positions x
–TR
Post
Height
= Tape & Reel
–SV: 02-22 positions, –DV: 02-28 positions,
–SH: 02-30 positions, –DH: 02-29 positions
(Not available with –MT or –TM)
(2.54)
.100
(3.68)
.145
(7.87)
.310
OTHER OPTIONS
–FR
(1.16) .046
= Full Reel Tape & Reel
(must order maximum quantity per reel;
contact Samtec for quantity breaks)
—DH Row Option
[1RRISRVLWLRQV
(6.10)
.240
(1.52)
.060
(2.54)
.100
3RVW
+HLJKW
Post
Height
(7.87)
.310
—TM Row Option
(1.16) .046
—MT Row Option
samtec.com?TSM
F-224 (Rev 26APR24)
TSM-104-01-S-SV-A-TR 价格&库存
很抱歉,暂时无法提供与“TSM-104-01-S-SV-A-TR”相匹配的价格&库存,您可以联系我们找货
