TW-10-03-L-D-340-SM-P-TR 数据手册
SMT & THROUGH-HOLE
BOARD STACKERS 8 4
CLT or MMS
SQT
G b p s
G b p s
(2.00 mm) .0787" PITCH • TW SERIES
TW
Board Mates:
CLT, SQT, SQW, ESQT,
TLE, SMM, MMS
Cable Mates:
TCSD
TW
02
thru
36
SPECIFICATIONS
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over
50 µ" (1.27 µm) Ni
Current Rating:
TW-SM = 4.9 A per pin
(2 pins powered)
TW-TH = 5.2 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +105 °C with Tin;
-55 °C to +125 °C with Gold
NO. PINS
PER ROW
LEAD
STYLE
1RRISRVLWLRQV
ALSO AVAILABLE
PLATING
OPTION
MOQ Required
NO. PINS
PER ROW
02 thru 50
Other Platings
End shrouds with or
without guide post
—S, —D*, —Q
Notes:
For added mechanical
stability, Samtec recommends
mechanical board spacers be
used in applications with gold or
selective gold plated connectors.
Contact ipg@samtec.com for
more information.
This Series is non-standard,
non-returnable.
F-224
–S
(5.08) .200
–D
(6.35) .250
–02
(7.85) .309
–03
(11.86) .467
–04
(12.37) .487
–06
(15.37) .605
–07
(17.35) .683
–09
(9.86) .388
= Gold flash
on post,
Matte Tin
on tail
–L
—A OPTION
ROW
OPTION
–S
= Single Row
–D
= Double Row
–T
= 10 µ"
(0.25 µm)
Gold on
post,
Matte Tin
on tail
= Triple Row
–T
= Five Row
–Q
= Four Row
–5
–6
= Six Row
(1.27)
.050
MIN
POST
STACKER
HEIGHT
See OAL
Chart
ROW
OPTION
(0.00) .000 MIN
—S, —D*, —Q
—T, —5, —6
STACKER
HEIGHT
–S, –D*, –Q (3.05) .120 MIN
–T, –5, –6
TAIL
–P
A
= Matte Tin
—T, —5, —6
Example:
–250
= (6.35 mm)
.250"
= Pick & Place Pad
(1.91 mm) .075" min.
post height
(04-36 only)
–“X”R
OAL
PLATING
OPTION
No. of
rows
x
(2.00)
.0787
–A
= Alignment Pin
(Metal or plastic
at Samtec discretion)
(4.83 mm) .190" min.
board space
(–D only)
ROW OPTION
–F
Specify
LEAD
STYLE
from
chart
= Polarized Position
LEAD
STYLE
OTHER
OPTION
–“XXX”
= Stacker
Height
in inches
(0.13 mm)
.005"
increments
–D
–T
LEAD
STYLE
- SM -
STACKER
HEIGHT
–“XXX”
= Double
Row
= Matte
Tin
–S
–L
0,1
= Single
Row
= 10 µ"
(0.25 µm)
Gold on
post,
Matte Tin
on tail
67$&.(5
+(,*+7 2$/
0,1
TW
ROW
OPTION
= Gold
flash
on post,
Matte Tin
on tail
–F
Specify
LEAD
STYLE
from
chart
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.15 mm) .006" max*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
(4.06) .160 MIN
*–D with stacker height
greater than (4.06 mm) .160"
will not have standoffs.
—P OPTION
Specify “T” for
Tape & Reel
Specify “F” for
Full Reel Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
(–07 lead style N/A)
(–06 lead style with
–P option N/A
as standard)
STACKER
HEIGHT
–“XXX”
= Stacker Height
in inches
(0.13 mm) .005"
increments
Example: –250
= (6.35 mm)
.250"
LEAD
STYLE
OAL
–01
(8.20) .323
–02
(9.60) .377
–03
(13.60) .535
–04
(14.10) .555
–05
(15.10) .594
–06
(17.10) .673
–07
(19.10) .751
–08*
(21.10) .830
–09
(11.60) .456
–10
(15.60) .614
–11
(10.08) .397
–12*
(28.19)1.110
TAIL
SPEC
–“XXX”
= Tail Length
in inches
(0.13 mm) .005"
increments
Example: -150
= (3.81 mm)
.150"
–“XXX”
= Polarized
Position
(Specify
position to
be removed)
*Style –08 & –12 = S & D only
samtec.com?TW-SM or samtec.com?TW-TH
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
TW-10-03-L-D-340-SM-P-TR 价格&库存
很抱歉,暂时无法提供与“TW-10-03-L-D-340-SM-P-TR”相匹配的价格&库存,您可以联系我们找货
