U.FL-2LP-5016-A-(150)
    HRS(广濑)
U.FL-2LP-5016-A-(150) 数据手册
Ultra Small Surface Mount Coaxial Connectors - 1.9mm or 2.3mm, 2.4mm Mated Height U.FL Series Up to 6GHz (MAX 3.2) U.FL-LP-040HF U.FL-LP-066HF U.FL-LP-068HF E.FL-LP-040 E.FL-LP-066 3 2.4 (MAX 2.5) 2.3 (MAX 2.4) U.FL-LP(V)-040HF U.FL-LP-062HF U.FL-LP-088HF U.FL E.FL Fig.1 ■Features 1. Nominal mated height of 1.9 or 2.3mm, 2.4mm (Max. 2.0 or 2.4mm, 2.5mm)(Fig.1) 2. Small mounting area (2.5 Max) ●Space Factor of Mated Connector U.FL-LP-040HF Plug Dia 0.81 The receptacle occupies an area of 7.7mm . 3. Light weight 2.4 2 Receptacle : 15.7mg U.FL-R-SMT-1 5. Automatic board placement U.FL-LP-066HF U.FL-LP-068HF Plug Dia 1.32 Dia 1.13 2.4 To meet the frequency requirements of a wide variety of miniature devices, the connectors offer high frequency performance from DC to 6GHz, with a V.S.W.R. of 1.3 to 1.5 max. (2.5 Max) 4. Supports high frequency up to 6GHz Packaged on tape-and-reel the receptacles can be placed with vacuum nozzles of the automatic placement equipment. Standard ultra-fine coaxial cable of 0.81mm diameter (single braid shielding) is used for the plug termination, assuring secure and stable connections. (2 Max) Plug U.FL-LP(V)-040HF Dia 0.81 1.9 6. Plugs are terminated with ultra-fine coaxial (fluorinated resin insulated) cable U.FL-R-SMT-1 U.FL-R-SMT-1 Tactile click sensation confir ms fully mated condition, assur ing complete electr ical and mechanical connection. 9. Halogen-free*(Receptacle,plug(HF type)) *As defined by IEC61249-2-21 Br-900 ppm maximum, Cl-900 ppm maximum, Cl+Br combined-1,500 ppm maximum Plug U.FL-LP-062HF Dia 0.95 2.3 8. Verification of the fully mated condition U.FL-R-SMT-1 (2.4 Max) Use of available extraction tool assures correct disconnection of the plug and receptacle. (2.4 Max) 7. Simple connector mating / unmating Plug U.FL-LP-088HF Dia 1.37 2.3 Jul.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.9 (MAX 2.0) Mated height comparison (with E.FL series) U.FL-R-SMT-1 In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2018.6④ Fig.2 1 U.FL Series●Ultra Small Surface Mount Coaxial Connectors - 1.9mm or 2.3mm, 2.4mm Mated Height ■Product Specifications Nominal characteristic impedance Frequency range Ratings 50ø DC to 6GHz Item 1. Contact resistance 2. Insulation resistance Jul.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3. Withstanding voltage Operating temperature range -40˚C to +90˚C Operating humidity 90%RH max. Storage temperature range Storage humidity Specification -30˚C to +70˚C 90%RH max. Conditions Center : 20mø max. Outer : 10mø max. 500Mø min. 10mA max. No flashover or insulation breakdown. 200V AC / 1 minute 100V DC 4. V.S.W.R.* Part No. U.FL-LP-040HF dia.0.81mm Coaxial Cable Assembly U.FL-LP(V)-040HF dia.0.81mm Coaxial Cable Assembly U.FL-LP-068HF dia.1.13mm Coaxial Cable Assembly U.FL-LP-066HF dia.1.32mm Coaxial Cable Assembly U.FL-LP-062HF dia.0.95mm Coaxial Cable Assembly U.FL-LP-088HF dia.1.37mm Coaxial Cable Assembly 5. Durability (mating / un-mating, with corresponding plug) Contact resistance Center : 25mø max. Outer : 15mø max. 30 cycles No electrical discontinuity of 1µs min. No damage, cracks or parts dislocation. Frequency : 10 to 100Hz, single amplitude of 1.5mm, acceleration of 59m/s2, for 5 cycles in the direction of each of the 3 axis. Acceleration of 735m/s2, 11ms duration, sine halfwave waveform, 3 cycles in each of 3 axes. 6. Vibration 7. Shock 8. Humidity (Steady state) 9. Temperature cycle 10. Salt spray No damage, cracks or parts dislocation. Insulation resistance 10Mø min.(humidity high) Insulation resistance 500Mø min.(dry) No damage, cracks or parts dislocation. Contact resistance : 25mø max. (Center) 15mø max. (Outer) No excessive corrosion Up to 3GHz 1.3 Max 1.3 Max 1.3 Max 1.3 Max 1.3 Max 1.3 Max 3 to 6GHz 1.35 Max 1.3 Max 1.4 Max 1.5 Max 1.3 Max 1.4 Max 96 hours at temperature of 40ç and humidity of 95%. Temperature : -40˚C/+5 to +35˚C/+90˚C/+5 to +35˚C Time : 30min. / 3min. / 30min. / 3min. 5 cycles 5% salt water solution, 48 hours *V.S.W.R. Measurement System The above V.S.W.R. standard values were measured using the measurement connection shown below. Note 1 : Cable type connectors were measured with SMA conversion adapters attached to both ends of the harness product of a suitable 100cm cable. Note 2 : Board type connectors were mounted to a 50ø glass epoxy board and measurements were conducted with SMA conversion adapters attached. ■Material / Finish ●Plug-right angle Part Shell Insulator Female center contact Material Phosphor bronze PBT, Color : Gray LCP, Color : Milky-white Phosphor bronze Finish/Remarks Silver plated UL94HB (LP (V) -040HF) UL94V-0(040HF,066HF, 068HF, 062HF, 088HF) Gold plated Material Phosphor bronze LCP, Color : Milky-white Brass Finish/Remarks Silver plated UL94V-0 Gold plated ●Receptacle Part Shell Insulator Male center contact 2 U.FL Series●Ultra Small Surface Mount Coaxial Connectors - 1.9mm or 2.3mm, 2.4mm Mated Height ■Receptacles GND GND No conductive traces in this area 1.2Max(Note) 4±0.05 1.9±0.05 1±0.05 2.2±0.05 GND GND SIG 1±0.05 1.05±0.05 (3.1) 2.6 1.8 3 2.6 0.6 SIG U.FL-R-SMT-1 Part No. U.FL-R-SMT-1(01) U.FL-R-SMT-1(60) U.FL-R-SMT-1(80) HRS No. 331-0472-2 01 331-0472-2 60 331-0472-2 80 Packaging 100 pcs/pack 4,000 pcs/reel 10,000 pcs/reel Weight / EA 15.7/mg Note : This area may be covered by insulating material. Embossed Carrier Tape Dimensions(IEC 60286-3 compliant) Embossed Carrier Tape Dimensions Reel Dimensions Center contact .5 4 Ø1 2 13.5 φ330 12 5.5 1.75 Material:PS(Black) 8 4 .5 2 Ø1 1.75 U.FL-R-SMT-1(60): 8mm pitch A Center contact A(SCALE FREE) 2 3 5.5 φ1 12 Jul.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.35 1.25 Ø2 BRecommended PCB Mounting Pattern φ2 1 4 Unreeling direction U.FL-R-SMT-1(80): 4mm pitch 3 U.FL Series●Ultra Small Surface Mount Coaxial Connectors - 1.9mm or 2.3mm, 2.4mm Mated Height Mated Height 4 1.8 1.5 5 1.85 3.4 4 1.93 1.93 4 U.FL-LP-088HF(06) 3 3 3 Part No. Size U.FL-LP(V)-040HF(06) U.FL-LP-062HF(06) 2.8 U.FL-LP-066HF U.FL-LP-068HF U.FL-LP-040HF 2.8 Jul.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Cable Assembly (Plug) 2.5mm Max. 2.5mm Max. 2.0mm Max. 2.4mm Max. 2.4mm Max. (2.4mm Nom.) (2.4mm Nom.) (1.9mm Nom.) (2.3mm Nom.) (2.3mm Nom.) Dia. 0.81mm Dia. 0.95mm Dia. 1.37mm 35 45.5 72 Applicable cable Dia. 0.81mm Weight (mg) 54 Dia. 1.13mm and Dia. 1.32mm 59 Environmental compliant Halogen-free, RoHS2 compliant ●Cable Guide Description Dia.0.81mm Coaxial Cable Dia.1.13mm Coaxial Cable Dia.1.32mm Coaxial Cable Dia.0.95mm Coaxial Cable Dia.1.37mm Coaxial Cable Dia.1.37mm Coaxial Cable Cable Specification Cable Type 04 068 066 062 088 088 Inner Conductor* Dielectric Diameter Outer Conductor* Jacket Diameter 7/0.05 SA Dia.0.4mm Single Dia.0.81mm (AWG#36) FEP Shield TA FEP 7/0.08 SA Dia.0.68mm Single Dia.1.13mm (AWG#32) FEP Shield TA FEP 7/0.08 SA Dia.0.66mm Double Dia.1.32mm (AWG#32) FEP Shield TA FEP 7/0.071 SA Dia.0.62mm Tape, single Dia.0.95mm (AWG#33) FEP Shield TA FEP 7/0.102 SA Dia.0.88mm Single Dia.1.37mm (AWG#30) FEP Shield TA FEP 7/0.102 SA Dia.0.88mm Tape, Single Dia.1.37mm (AWG#30) FEP/PTEE Shield TA FEP (data as provided by cable suppliers, for reference only) * SA : Silver plated annealed copper wire, TA : Tin plated annealed copper wire [Plugs can be ordered only as terminated cable assemblies.] 4 Flame Retardant Grade Nominal attenuation At 3GHz At 6GHz 5.4dB/m 8.0dB/m 3.73dB/m 5.44dB/m 3.8dB/m 5.6dB/m 3.1dB/m 4.4dB/m 2.8dB/m 4.3dB/m 2.5dB/m 3.4dB/m VW-1 U.FL Series●Ultra Small Surface Mount Coaxial Connectors - 1.9mm or 2.3mm, 2.4mm Mated Height How To Specify Cable Assembly [Single-ended cable assembly] [Double-ended cable assembly] L L Ordering information ●Product Number Structure Jul.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Used plug : U.FL-LP(V)-040HF(06) U.FL-LP-040HF(Dia.0.81mm) DoubleEnded SingleEnded Used plug : U.FL-LP-062HF(06)(Dia.0.95mm) U.FL - 2LP HF6 - 04N 「」TV - A - L 1 2 3 4 5 6 7 U.FL - LP HF6 - 04N 「」TV - A - L 1 2 q Series name w Assembly type e Environmental compliant r Cable type t Cable color y Cable outer conductor u Total length(mm) 3 4 5 6 7 U.FL, UFL LP : Single ended LPV : Plug(V) Single ended 2, 2LP : Double ended 2LPV plug(V) Double ended HF6 : Halogen-free 04N : Dia.0.81mm Ultra-fine coaxial cable 1 : White, 2 : Black TV : Tin plated braided wire Length(L) Used plug : U.FL-LP-068HF(Dia.1.13mm) DoubleEnded SingleEnded 2 3 4 5 6 7 U.FL - LP HF6 - 068N「」 T - A - L 1 2 q Series name w Assembly type 3 4 5 6 7 t Cable color y Cable outer conductor u Total length(mm) 1 2 3 4 5 6 7 U.FL - LP HF6 - 062N「」D - A - L 1 2 q Series name w Assembly type e Environmental compliant r Cable type t Cable color y Cable outer conductor u Total length(mm) DoubleEnded 3 4 5 6 7 U.FL, UFL LP : Single ended 2, 2LP : Double ended HF6 : Halogen-free 062N : Dia.0.95mm Ultra-fine coaxial cable 1 : Gray, 2 : Black D : Copper tape + Tin plated braided wire Length(L) SingleEnded U.FL - 2LP HF6 - 088N「」 T - A - L 1 2 068Y : Dia.1.13mm Ultra-fine coaxial cable 068N : 1 : Gray, 2 : Black T : Tin plated braided wire Length(L) 3 4 5 6 7 U.FL - LP HF6 - 088N「」 T - A - L 1 2 q Series name w Assembly type U.FL, UFL LP : Single ended 2, 2LP : Double ended HF6 : Halogen-free e Environmental compliant r Cable type SingleEnded U.FL - 2LP HF6 - 062N「」D - A - L Used plug : U.FL-LP-088HF(06)(Dia.1.37mm) U.FL - 2LP HF6 - 068N「」 T - A - L 1 DoubleEnded e Environmental compliant r Cable type t Cable color y Cable outer conductor u Total length(mm) 3 4 5 6 7 U.FL, UFL LP : Single ended 2, 2LP : Double ended HF6 : Halogen-free 088Y : Dia.1.37mm Ultra-fine coaxial cable 088N : 1 : Gray, 2 : Black T : Tin plated braided wire PD : Copper tape + Tin plated braided wire Length(L) Used plug : U.FL-LP-066HF(Dia.1.32mm) DoubleEnded SingleEnded U.FL - 2LP HF6 - 066N「」- A - L 1 2 3 4 5 6 U.FL - LP HF6 - 066N「」- A - L 1 2 q Series name w Assembly type e Environmental compliant r Cable type t Cable color y Total length(mm) 3 4 5 6 U.FL, UFL LP : Single ended 2, 2LP : Double ended HF6 : Halogen-free ●Standard tolerances for (L) (L)(mm) Standard Tolera(mm) *L=35 to 200 ±4 L=200 to 500 ±8 L=500 to 1000 ±12 L=Longer than 1000 ±1.5% of (L) Note : Minimum available length(L) is 35mm 066N : Dia.1.32mm Ultra-fine coaxial cable 1 : Gray, 2 : Black Length(L) 5 U.FL Series●Ultra Small Surface Mount Coaxial Connectors - 1.9mm or 2.3mm, 2.4mm Mated Height ■Conversion Adapters ●SMA Conversion Adapter (Mating portion: U.FL side jack - SMA side plug) (10.7) Note : The U.FL side mating portions has a lower lock retention force than the regular product, therefore, cannot be used for purposes other than performance measurements. Part No. HRMP-U.FLJ(40) ●SMA Conversion Adapter (Mating portion: U.FL side plug - SMA side jack) HRS No. 311-0300-2 40 14.05 (4.05) 6 5.6 Ø6.35 Jul.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 8HEX 1/4-36UNS-2A Part No. HRMJ-U.FLP(40) Note : The U.FL side mating portions has a lower lock retention force than the regular product, therefore, cannot be used for purposes other than performance measurements. HRS No. 311-0301-5 40 (18.6) ●SMA Conversion Adapter (Mating portion: U.FL side plug - SMA side jack) (4) 6 5.5 1/4-36UNS-2A Part No. HRMJ-U.FLP-ST1(40) Note : This connector is used by compressing the mated portion of U.FL side onto the U.FL-R-SMT-1 portion. HRS No. 311-0385-5 40 12.9 ■Receptacle to Inspection (7.9) (4.4) 7HEX 5 1 M5∞0.5 This receptacle is used for inspecting the continuity, withstand voltage, and other aspects of the harness product. Part No. U.FL-R-1 HRS No. 331-0466-0 (90) Plug Extraction Tool 5 This tool is used for extraction from a mating condition. Ø15 50 U.FL 2.1 MARKING U.FL U.FL/V Part No. U.FL-LP-N-2 U.FL-LP(V)-N-2 Plug Insertion Tool HRS No. 331-0494-5 331-0493-2 (12.9) This tool is for mating U.FL series plug into receptacle. Ø10 Note : Part No. U.FL-LP-N-2 for U.FL-LP-040HF/066HF/088HF/068HF. Part No. U.FL-LP(V)-N-2 for U.FL-LP(V)-040HF/U.FL-LP-062HF. JAPAN 8 For distinction with W.FL-LP-IN. Part No. U.FL-LP-IN 6 HRS No. 331-0334-9 U.FL Series●Ultra Small Surface Mount Coaxial Connectors - 1.9mm or 2.3mm, 2.4mm Mated Height Usage Precautions 1. Plugs (1) Mating / unmating 1) To disconnect connectors, insert the end portion of U.FL-LP-N-2 and U.FL-LP(V)-N-2 under the connector flanges and pull off vertically, in the direction of the connector mating axis. Extraction Tool 2) To mate the connectors, the mating axes of both connectors U.FL Cable must be aligned and the connectors can be mated. The Assembly "click" will confirm fully mated connection.Do not attempt to insert on an extreme angle. Jul.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. U.FL-R-SMT-1 After the connectors are mating, do not apply a load to the cable in excess of the values indicated in the diagram below. U.FL-LP Cable Assembly (2) Pull forces on the cable after connectors are mated. 1N max (U.FL-LP(V)-040HF, U.FL-LP-062HF) 2N max (U.FL-LP-040HF, U.FL-LP-066HF, U.FL-LP-068HF, U.FL-LP-088HF) U.FL-R-SMT-1 3N max (U.FL-LP(V)-040HF, U.FL-LP-062HF) 4N max (U.FL-LP-040HF, U.FL-LP-066HF, U.FL-LP-068HF, U.FL-LP-088HF) 1N max (U.FL-LP(V)-040HF, U.FL-LP-062HF) 2N max (U.FL-LP-040HF, U.FL-LP-066HF, U.FL-LP-068HF, U.FL-LP-088HF) (3) Precautions Do NOT forcefully twist or deform wires. 2. Receptacles 250 ç max. for 10 seconds [ç] (1) Recommended reflow temperature profile 260 240 220 200 180 160 140 120 100 80 Preheat (130 to 180ç) 120 seconds max. 230ç 220ç 50 seconds max. 60 seconds max. Time q The temperature of the printed circuit board surface temperature at the points of contact with the terminals. w Reflow soldering should be performed at a printed circuit surface temperature of 250°C max. e In individual applications the actual temperature may vary, depending on the solder paste type, volume / thickness and board size / thickness. Consuly your solder paste and equipment manufacturer for specific recommendations. (2) Recommended manual Manual soldering : 350˚C for 5 seconds soldering (3) Recommended metal mask thickness 0.1 to 0.12mm (4) Reflow cycles 2 times 3. Operating environment and storage conditions (1) Operating environment (2) Storage conditions Receptacle The connectors are not designed to operate in the following environments : • Exposed to a excessive amounts of fine particles and dust • Regions and places having a high density of sulfur dioxide, hydrogen sulfide, nitrogen dioxide or other corrosive gasses. • Environments having large rapid variations in temperature. Store in the Hirose Electric packaging. Temperature : -10 to +40ç, Humidity : 85% max. Use within 6 months of delivery. Receptacles for which the storage period has elapsed must be tested for solderability to the PC board mounting surface. 7 U.FL Series●Ultra Small Surface Mount Coaxial Connectors - 1.9mm or 2.3mm, 2.4mm Mated Height ■SMA cable type SMA Straight Plug 8HEX Jul.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1/4-36UNS-2B 15 Part No. HRS No. Applicable cable HRM-200-040PBN(40) HRM-200-066PBN(40) HRM-200-088PBN(40) 323-0790-3 40 323-0791-6 40 323-0800-5 40 Dia. 0.81 type Dia. 1.13, Dia.1.32 type Dia. 1.37 type 17 4.5 8 8HEX 1/4-36UNS-2A Straight Jack Part No. HRS No. Applicable cable HRM-200-040JBN(40) HRM-200-066JBN(40) HRM-200-088JBN(40) 323-0792-9 40 323-0793-1 40 323-0801-8 40 Dia. 0.81 type Dia. 1.13, Dia.1.32 type Dia. 1.37 type 17 12.7 9.55 1.7 Ø6.4 1/4-36UNS-2A Panel mount Jack (Four Screws) 8.64 4∞Ø2.6 Part No. HRM-200-040PJ4BN(40) HRM-200-066PJ4BN(40) HRM-200-088PJ4BN(40) HRS No. 323-0795-7 40 323-0796-0 40 323-0803-3 40 Applicable cable Dia. 0.81 type Dia. 1.13, Dia.1.32 type Dia. 1.37 type 17 9.55 8 1.7 Ø6.4 1/4-36UNS-2A Panel mount Jack (Two Screws) Part No. HRS No. Applicable cable HRM-200-040PJ2BN(40) HRM-200-066PJ2BN(40) HRM-200-088PJ2BN(40) 323-0794-4 40 323-0788-1 40 323-0802-0 40 Dia. 0.81 type Dia. 1.13, Dia.1.32 type Dia. 1.37 type 17 Ø10 1.5 8HEX 11 5.85 5.9 +0.1 0 1/4-36UNS-2A Panel mount Jack (Bulkhead) 8 2ר2.6 Ø6.4 +0.1 0 Part No. HRS No. Applicable cable HRM-200-040BPJBN(40) HRM-200-066BPJBN(40) HRM-200-088BPJBN(40) 323-0797-2 40 323-0798-5 40 323-0804-6 40 Dia. 0.81 type Dia. 1.13, Dia.1.32 type Dia. 1.37 type U.FL Series●Ultra Small Surface Mount Coaxial Connectors - 1.9mm or 2.3mm, 2.4mm Mated Height Reverse polarity SMA Straight Jack 17 4.5 8 8 HEX Part No. HRS No. Applicable cable SMA(R)-200-040JBN SMA(R)-200-066JBN SMA(R)-200-088JBN 323-0926-3 323-0931-3 323-0904-0 Dia. 0.81 type Dia. 1.13, Dia.1.32 type Dia. 1.37 type 17 Panel mount Jack (Four Screws) 12.7 9.55 1.7 8.64 1/4-36UNS-2A .6 Ø2 4∞ Part No. HRS No. Applicable cable SMA(R)-200-040PJ4BN SMA(R)-200-066PJ4BN SMA(R)-200-088PJ4BN 323-0928-9 323-0932-6 323-0934-1 Dia. 0.81 type Dia. 1.13, Dia.1.32 type Dia. 1.37 type 17 9.55 Panel mount Jack (Two Screws) 8 1/4-36UNS-2A 12.2 1.7 6 Ø2. 2∞ Part No. HRS No. Applicable cable SMA(R)-200-040PJ2BN SMA(R)-200-066PJ2BN SMA(R)-200-088PJ2BN 323-0929-1 323-0933-9 323-0935-4 Dia. 0.81 type Dia. 1.13, Dia.1.32 type Dia. 1.37 type Panel mount Jack (Bulkhead) 17 1.5 8 HEX 11 5.85 ●Panel cut-out 5.9+0.1 0 1/4-36UNS-2A Ø6 .4 + 0 0 .1 Ø10 Jul.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1/4-36UNS-2A Part No. HRS No. Applicable cable SMA(R)-200-040BPJBN SMA(R)-200-066BPJBN SMA(R)-200-088BPJBN 323-0927-6 323-0902-5 323-0901-2 Dia. 0.81 type Dia. 1.13, Dia.1.32 type Dia. 1.37 type 9 U.FL Series●Ultra Small Surface Mount Coaxial Connectors - 1.9mm or 2.3mm, 2.4mm Mated Height ■How To Specify Cable Assembly Ordering information P : Plug L mm HRM P - UFLHF6 - 04「※」2「※」-A- L q w q Series name w Connector type Jul.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. J : Jack L mm e Cable type r Cable color PJ : Panel mount Jack (Four Screws) L mm PJ2 : Panel mount Jack (Two Screws) L mm BPJ : Panel mount Jack (Bulkhead) L mm Note : Minimum available length(L) is 50mm 10 t Total length(mm) e r t HRM : SMA type SMAR : Reverse polarity SMA P : Plug J : Jack PJ : Panel mount Jack(Four screws) PJ2 : Panel mount Jack(Two screws) BPJ : Panel mount Jack(Bulkhead) 04 : Dia. 0.81mm Coaxial cable 066 : Dia. 1.32mm Coaxial cable 068 : Dia. 1.13mm Coaxial cable 088 : Dia. 1.37mm Coaxial cable 04 2 : Black 066 068 2 : Black 088 Length(L) U.FL Series●Ultra Small Surface Mount Coaxial Connectors - 1.9mm or 2.3mm, 2.4mm Mated Height ■SMA conversion adapter SMA Panel mount adapter (Four Screws) 17.9 12.7 9.55 1.7 8.64 1/4-36UNS-2A .6 Part No. HRS No. HRMJ-U.FLJ-PA4 311-0465-2 Panel mount adapter (Two Screws) 17.9 9.55 8 1.7 12.2 1/4-36UNS-2A 2∞ Part No. HRS No. HRMJ-U.FLJ-PA2 311-0467-8 Ø2. 6 Panel mount adapter (Bulkhead) 17.9 1.5 8 HEX 11 ●Panel cut-out 5.85 5.9+0.1 0 1/4-36UNS-2A Ø6 .4 + 0 0 .1 Ø10 Part No. HRS No. HRMJ-U.FLJ-BPA-4 311-0463-7 PCB mount adapter 6 16 ●Panel cut-out 1/4-36UNS-2A 0.1 + .5 0 4∞Ø1 5.08±0.05 5.08±0.05 12.7 9.7 6.4 Jul.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Ø2 4∞ 5.08 Part No. HRS No. HRMJ-U.FLJ-PC 311-0411-3 HRMJ-U.FLJ-PC(01) 311-0411-3 01 Finish Nickel plated Gold plated 11 U.FL Series●Ultra Small Surface Mount Coaxial Connectors - 1.9mm or 2.3mm, 2.4mm Mated Height Reverse polarity SMA Panel mount adapter (Four Screws) 17.9 12.7 9.55 1.7 8.64 1/4-36UNS-2A 4∞ Jul.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Ø2 Powered by TCPDF (www.tcpdf.org) Part No. HRS No. SMA(R)J-U.FLJ-PA4 311-0466-5 .6 Panel mount adapter (Two Screws) 17.9 8 9.55 1.7 12.2 1/4-36UNS-2A 2∞ Part No. HRS No. SMA(R)J-U.FLJ-PA2 311-0468-0 Ø2. 6 Panel mount adapter (Bulkhead) 8 HEX 17.9 1.5 5.85 9.55 ●Mounting pattern 5.9 +0.1 0 Ø6 . 4 + 0 0 .1 Ø10 1/4-36UNS-2A ® 12 Part No. HRS No. SMA(R)J-U.FLJ-BPA-4 311-0464-0 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 06/2018. Contents are subject to change without notice for the purpose of improvements.
U.FL-2LP-5016-A-(150) 价格&库存
很抱歉,暂时无法提供与“U.FL-2LP-5016-A-(150)”相匹配的价格&库存,您可以联系我们找货
