21 03 311 1402
21 03 311 1402
    HARTING(浩亭)
    HARTING - 21 03 311 1402 - Sensor Cable, M12 Plug, Free End, 4 Positions, 500 mm, 19.6 "
21 03 311 1402 数据手册
HARTING M8 / M12 Circular Connectors People | Power | Partnership ® HARAX Circular connector Technical characteristics Specifications Approval IEC 60 352-4 IEC 61 076-2-101 IEC 61 076-2-104 HARAX ® M8-S/ HARAX ® M8-S (0.08 mm²) M12-S 32 V 32 V HARAX ® M12 angled 32 V HARAX ® M12-L 3 poles, 4 poles 50 V HARAX ® M12-L 5 poles 50 V 2A 4A 4A 6A 4A Conductor cross section 0.08 - 0.14 mm² AWG 28 - 26 0.14 - 0.34 mm² AWG 26 - 22 0.25 - 0.5 mm² AWG 24/7 - 20 0.34 - 0.75 mm² AWG 22 - 18 Diameter of individual strands Conductor insulation material ≥ 0.05 mm PVC / PP / TPE ≥ 0.1 mm PVC / PP / TPE ≥ 0.1 mm PVC Conductor diameter 0.6 - 1.0 mm 1.0 - 1.6 mm 1.2 - 1.6 mm ≥ 0.1 mm PVC 1.6 - 2.0 mm 2.0 - 2.6 mm Construction type Rated voltage Rated current (see current carrying capacity) Cable diameter Limiting temperatures Temperature during connection Degree of protection Termination cycles with the same cross section Recommended tightening torque / Hexagonal wrench Page M8-S: 2.5 - 5.1 mm 1.9 - 2.5 mm (transp.) M12-S: 4 - 5.1 mm 2.5 - 3.5 mm (grey) 2.9 - 4.0 mm (transp.) 4.0 - 5.1 mm (black) - 25 °C / + 85 °C - 25 °C / + 85 °C - 25 °C / + 85 °C 0.25 - 0.34 mm² AWG 24 - 22 0.34 - 0.5 mm² AWG 22 - 20 ≥ 0.1 mm PVC 1.2 - 2.0 mm 3 poles: 5.5 - 7.2 mm 4.7 - 6 mm 4 poles: 6 - 8 mm 6 - 8 mm - 25 °C / + 85 °C - 40 °C / + 85 °C - 5 °C … + 50 °C - 5 °C … + 50 °C - 5 °C … + 50 °C - 5 °C … + 50 °C - 5 °C … + 50 °C IP 67 IP 67 IP 67 IP 65 / IP 67 IP 65 / IP 67 10 10 10 10 10 0.4 Nm / SW 9 M8-S: 0.4 Nm / SW 9 0.6 Nm / SW 13 M12-S: 0.6 Nm / SW 13 8 / 13 13 0.6 Nm / SW 17 0.6 Nm / SW 17 17 17 8 Current carrying capacity The current carrying capacity is limited by maximum temperature of materials for inserts and contacts including terminals. The current capacity-curve is valid for continuous, not interruptet current-loaded contacts of connectors when simultaneous power on all contacts is given, without exceeding the maximum temperature. Control and test procedures according to DIN IEC 60 512-5. M8-S, 4 poles 1 = wire gauge 0.25 mm² M12-S, 4 poles 2 = wire gauge 0.34 mm² Rated current [A] Rated current [A] M8-S, 3 poles wire gauge 0.14 mm² Ambient temperature [oC] Rated current [A] 2 M12, 4 poles, angled 1 = wire gauge 0.25 mm² 2 = wire gauge 0.5 mm² Rated current [A] M12-L 1 = wire gauge 0.34 mm² 3 poles, 4 poles 2 = wire gauge 0.75 mm² Ambient temperature [oC] Ambient temperature [oC] Ambient temperature [oC] ® HARAX Circular connector Technical characteristics Specifications Approval IEC 60 352-4 IEC 61 076-2-101 IEC 61 076-2-104 HARAX ® M12-L screened version HARAX ® M12-L screened version, A-coded PROFIBUS Ethernet 50 V 32 V 50 V Han ® M12 Crimp 50 V Han ® 7/8“ 4A 4A 4A 10 A Conductor cross section 0.14 - 0.34 mm² AWG 26 - 22 0.25 - 0.34 mm² AWG 24- 22 0.34 - 0.5 mm² AWG 22 - 20 0.75 - 1.5 mm² AWG 18 - 16 Diameter of individual strands Conductor insulation material ≥ 0.1 mm PVC ≥ 0.1 mm PVC, Zell-PE À 0.14 - 0.34 mm² AWG 26 - 22 Á 0.34 - 0.5 mm² AWG 22-20 ≥ 0.1 mm PVC / PE Conductor diameter 1.2 - 1.6 mm 2 - 2.6 mm 1.2 - 2.0 mm 2.0 - 2.3 mm ≤ 2.8 mm 4.5 - 5.4 mm (transparent) 7 - 8.8 mm (lightgrey) - 40 °C / + 85 °C 6.8 - 9.5 mm (black) 9 - 12.5 mm (grey) - 40 °C / + 85 °C Construction type Rated voltage Rated current (see current carrying capacity) 4A 230 V / 400 V ≥ 0.15 mm PVC, PP, TPE Cable diameter 7 - 8.8 mm 7 - 8.8 mm Limiting temperatures Temperature during connection Degree of protection Termination cycles with the same cross section Recommended tightening torque / Hexagonal wrench Page - 25 °C / + 85 °C - 25 °C / + 85 °C À5  .5 - 7.2 mm (black) Á7  - 8.8 mm (lightgrey) - 25 °C / + 85 °C - 5 °C … + 50 °C - 5 °C … + 50 °C - 5 °C … + 50 °C - 5 °C … + 50 °C - 5 °C … + 50 °C IP 67 IP 67 IP 67 IP 67 IP 65 / IP 67 10 10 10 0.6 Nm / SW 17 0.6 Nm / SW 17 0.6 Nm / SW 17 0.6 Nm / SW 17 1.5 Nm / SW 22 20 22 26 21 / 27 32 M12L, 5 poles 1 = wire gauge 0.25 mm² 2 = wire gauge 0.34 mm² Rated current [A] Rated current [A] 7/8“ 1 = wire gauge 0.75 mm² / 1.5 mm² 10 Ambient temperature [oC] M12, Crimp 1 = wire gauge 0.34 mm² / 0.5 mm² Ambient temperature [oC] M12L, 5 poles 1 = wire gauge 0.34 mm² 2 = wire gauge 0.5 mm² Rated current [A] Rated current [A] Ambient temperature [oC] Ambient temperature [oC] 3 HARAX ® Circular connector Assembly manual HARAX® , M8-S / M12-S unshielded 1. 1. strip cable 2. assemble HARAX ® elements Nut Strain relief Insert 2. 3. 3. cut off cable ends Screw the nut onto the insert until a stop is noticeable. 4. screw the connector Note! For reconnection cut off the used cable ends and repeat steps 1 to 4. 4. The seal has to be replaced when worn. Assembly manual HARAX ®, M12-L shielded 1. 1. strip cable 2. assemble HARAX ® elements twist screening braid ans push it into the sealing slot Nut Strain relief Insert 2. 3. Slide ring over the sealing cut off cable ends and the screening braid 3. 4. screw the connector Note! For reconnection cut off the used cable ends and repeat steps 1 to 4. 4. 4 The seal has to be replaced when worn. HARAX ® Circular connector Assembly manual Han® M12 Crimp 1. 1. Remove cable jacket and strip cores. Twist screening braid as shown and crimp contacts. 2. 2. Slide screw cap, ring and sealing onto the cable. Push screening braid into the sealing slot. 3. 3. Insert contacts into locator from the side. Fix contacts with the aid of asssembly aid. Slide locator into connector, pay attention to the coding. 4. 4. Sealing has to be flush with connector. Slide ring over the sealing and cut off screening braid. 5. 5. Tighten screw cap. Remove asssembly aid. The seal has to be replaced when worn. 5 HARAX ® Circular connector Assembly manual HARAX  ® Pg 9 panel feed-through 1. 2. 1. Strip cable jecket 2. Assemble HARAX ® elements Nut Strain relief Insert 3. 3. Cut off cable ends 4. 4. Twist the nut onto the insert until a stop is noticeable Note! For reconnection cut off the used cable ends and repeat steps 1 to 4. The seal has to be replaced when worn. 6 HARAX ® Circular connector Assembly manual HARAX  ® Pg 13.5 / M20 panel feed-through 1. 1. Connection and disconnection of the cable must only be performed by ­suitably qualified persons when supply is isolated. 2. HARAX ® Pg 13.5 – 3 contacts – is supplied with either faston blades or solder t­erminals. 2. 3. 4. Nut Strain relief Insert 3. HARAX ® Pg 13.5 / M20 – 4 contacts – is supplied only with solder termination. 4. The nut must be tightened completely down so that the notches engage on the ­contact carrier. The opening of the gland always requires a wrench. Note: For reconnection cut off the used cable ends and repeat steps 1 to 4. 7 HARAX ® Circular connector M8 Identification HARAX  ® Part No. Male Female Drawing Dimensions in mm M8-S straight version, 3 poles for 0,14 - 0,34 mm² 21 02 151 1305 straight version, 4 poles for 0,14 - 0,34 mm² 21 02 151 1405 straight version, 3 poles for 0.08 - 0.14 mm² 21 02 159 1305 straight version, 3 poles for 0,14 - 0,34 mm² 21 02 151 2305 straight version, 4 poles for 0,14 - 0,34 mm² 21 02 151 2405 View mating side: 3 poles, male version View mating side: 4 poles, male version 8 Stock items in bold type Han® M8 System cables, A-coded System cables with Han® M8 Circular connector Technical characteristics Han® M8 Circular connector, without PE Rated voltage max. 60 V AC/DC Rated current/contact max. 4 A Locking Screw locking M8x1, self securing Recommended torque 0.4 Nm Temperature range (dependant on connected conductor) -25 °C … +85 °C Degree of protection IP 67 Number of wires / wire gauge 3 x 0.25 mm² Conductor insulation PP (br, bl, sw) Arrangement of insulated strands 32 x 0.1 mm Sheath PUR (UL, CSA) Outer diameter appr. 4.1 mm Bending radius 10 x outer diameter Temperature range (working and storage) -5 °C … + 80 °C 9 Han® M8 System cables Identification Part No. Drawing Dimensions in mm Han® M8 Circular connector Female angled, Male straight Cable sleeve Length: 0.3 m 0.6 m 1.0 m 1.5 m 2.0 m 21 02 454 5301 21 02 454 5302 21 02 454 5303 21 02 454 5304 21 02 454 5305 Cable imprint View mating side Schematic diagram Han® M8 Circular connector Female angled, with LED Male straight Cable sleeve Length: 0.3 m 0.6 m 1.0 m 1.5 m 2.0 m Cable imprint View mating side 21 02 454 7301 21 02 454 7302 21 02 454 7303 21 02 454 7304 21 02 454 7305 Schematic diagram 10 Stock items in bold type Han® M8 System cables Identification Part No. Drawing Dimensions in mm Han® M8 Circular connector Female angled pre-assembled on one end Cable sleeve Length: 1.5 m 3.0 m 5.0 m 7.5 m 10.0 m 21 02 554 4301 21 02 554 4302 21 02 554 4303 21 02 554 4304 21 02 554 4305 Cable imprint Schematic diagram View mating side Han® M8 Circular connector Female angled, with LED pre-assembled on one end Cable sleeve Cable imprint Schematic diagram Length: 1.5 m 3.0 m 5.0 m 7.5 m 10.0 m View mating side 21 02 554 7301 21 02 554 7302 21 02 554 7303 21 02 554 7304 21 02 554 7305 HARAX® M8 cable-Set without LED Delivery range: Han® M8 connector with individually adaptable cable and HARAX® M8-S Length: 1.5 m 3.0 m 5.0 m 7.5 m 10.0 m Cable sleeve 21 82 554 4301 21 82 554 4302 21 82 554 4303 21 82 554 4304 21 82 554 4305 Cable imprint HARAX ® M8-S (21 02 151 1305) View mating side HARAX® M8 cable-Set with LED Delivery range: Han® M8 connector with individually adaptable cable and HARAX® M8-S Length: 1.5 m 3.0 m 5.0 m 7.5 m 10.0 m Cable sleeve 21 82 554 7301 21 82 554 7302 21 82 554 7303 21 82 554 7304 21 82 554 7305 Cable imprint HARAX ® M8-S (21 02 151 1305) View mating side 11 Stock items in bold type Accessories Circular Connectors M8 Identification Part No. Drawing Dimensions in mm Seal M8 for 2.5 - 3.5 mm cable Ø for 3.2 - 4.4 mm cable Ø for 4.2 - 5.4 mm cable Ø 21 01 010 2008 21 01 010 2004 21 01 010 2005 Set of 3 seals for HARAX ® M8-S for 2.5 - 3.2 mm cable Ø for 3.2 - 4.0 mm cable Ø for 4.0 - 5.1 mm cable Ø 21 01 010 2013 Han® M8 dynamometric screwdriver SW 9 09 99 000 0380 12 Stock items in bold type HARAX ® Circular connector Identification HARAX  ® Part No. Male Female Drawing Dimensions in mm M12-S straight version, 4 poles 21 03 111 1405 View mating side: 21 03 111 2405 View mating side: HARAX  ® M12 angled version, 4 poles 21 01 140 5081 View mating side: angled version, 4 poles 21 01 140 5091 View mating side: 13 Stock items in bold type Han® M12 System cables, A-coded System cables with Han® M12 Circular connector, A-coded Technical characteristics Han® M12 Circular connector, without PE 14 Rated voltage max. 250 V AC/DC, max. 30 V DC (with LED) Rated current/contact max. 4 A Locking Screw locking M12x1, self securing Recommended torque 0.6 Nm Temperature range (dependant on connected conductor) - 25 °C … +85 °C Degree of protection IP 67 Number of wires / wire gauge 4 x 0.34 mm² Conductor insulation PP (br, ws, bl, sw) Arrangement of insulated strands 42 x 0.1 mm Sheath PUR (UL, CSA) Outer diameter appr. 4.7 mm Bending radius 10 x outer diameter Temperature range (working and storage) -25 °C … + 80 °C Han® M12 System cables, A-coded Identification Part No. Drawing Dimensions in mm Han® M12 Circular connector Female straight, Male straight Cable sleeve Cable imprint View mating side Length: 0.3 m 0.6 m 1.0 m 1.5 m 2.0 m 21 03 415 2401 21 03 415 2402 21 03 415 2403 21 03 415 2404 21 03 415 2405 Schematic diagram Han® M12 Circular connector Female angled, Male straight Cable sleeve Length: 0.3 m 0.6 m 1.0 m 1.5 m 2.0 m 21 03 415 5401 21 03 415 5402 21 03 415 5403 21 03 415 5404 21 03 415 5405 Cable imprint View mating side Schematic diagram Han® M12 Circular connector Female angled, with LED, Male straight Cable sleeve Length: 0.3 m 0.6 m 1.0 m 1.5 m 2.0 m 21 03 415 7401 21 03 415 7402 21 03 415 7403 21 03 415 7404 21 03 415 7405 Cable imprint View mating side Schematic diagram 15 Stock items in bold type Han® M12 System cables, A-coded Identification Part No. Drawing Dimensions in mm Han® M12 Circular connector Female angled pre-assembled on one end Cable sleeve Length: 1.5 m 3.0 m 5.0 m 7.5 m 10.0 m 21 03 515 4401 21 03 515 4402 21 03 515 4403 21 03 515 4404 21 03 515 4405 Cable imprint View mating side Schematic diagram Han® M12 Circular connector Female angled, with LED pre-assembled on one end Cable sleeve Length: 1,5 m 3,0 m 5,0 m 7,5 m 10,0 m Cable imprint View mating side Schematic diagram 21 03 515 7401 21 03 515 7402 21 03 515 7403 21 03 515 7404 21 03 515 7405 HARAX® M12 cable-Set without LED Delivery range: Han® M12 connector with individually adaptable cable and HARAX® M12-S Length: 1,5 m 3,0 m 5,0 m 7,5 m 10,0 m Cable sleeve 21 83 515 4401 21 83 515 4402 21 83 515 4403 21 83 515 4404 21 83 515 4405 Cable imprint HARAX ® M12-S (21 03 111 1405) View mating side HARAX® M12 cable-Set with LED Delivery range: Han® M12 connector with individually adaptable cable and HARAX® M12-S Cable sleeve Cable imprint HARAX ® Length: 16 1,5 m 3,0 m 5,0 m 7,5 m 10,0 m 21 83 515 7401 21 83 515 7402 21 83 515 7403 21 83 515 7404 21 83 515 7405 M12-S (21 03 111 1405) View mating side Stock items in bold type HARAX ® Circular connector Part No. Identification HARAX  ® Male Female Drawing Dimensions in mm M12-L 3 poles, A-coded, with pre-leading contact (assignment 3, 4, 5) 3 poles, A-coded (assignment 1, 3, 4) 4 poles, A-coded (assignment 1, 2, 3, 4) 4 poles, A-coded, to 2.6 mm core diameter (assignment 1, 2, 3, 4) 21 03 212 1400 21 03 212 1306 21 03 212 1305 21 03 212 1407 21 03 212 2400 21 03 212 2306 21 03 212 2305 21 03 212 2407 3 poles, A-coded (assignment 3, 4, 5) 3 poles, A-coded (assignment 1, 3, 4) 4 poles, A-coded (assignment 1, 2, 3, 4) 4 poles, A-coded, to 2.6 mm core diameter (assignment 1, 2, 3, 4) View mating side, male version: HARAX ® M12-L 3 poles with pre-leading contact 3 poles 4 poles 5 poles, A-coded, 0.25 - 0.34 mm², AWG 24 - 22 Cable diameter: 4.7 - 6 mm 21 03 271 1505 21 03 271 2505 5 poles, A-coded, 0.34 - 0.5 mm², AWG 22 - 20 Cable diameter: 6 - 8 mm 21 03 272 1505 21 03 272 2505 17 Stock items in bold type Han® M12 panel feed-through, A-coded Technical characteristics: Han ® M12 panel feed-through Degree of protection IP 67 when mated and screwed Rated current max. 4 A (each contact) Rated voltage 50 V Mating cycles max. 100 Limiting temperature -25 °C … +85 °C Identification Part No. Drawing Dimensions in mm Han® M12 panel feed-through Male, A-coded, 50 cm conductors, 0.5 mm² 21 03 311 1402 Han® M12 panel feed-through Female, A-coded, 50 cm conductors, 0.5 mm² 21 03 311 2400 Han® M12 panel feed-through Male, A-coded, 50 cm conductors, 0.5 mm², 5 poles 21 03 311 1501 Han® M12 panel feed-through Female, A-coded, 50 cm conductors, 0.5 mm², 5 poles 21 03 311 2501 18 Stock items in bold type Accessories Circular Connectors M12 Identification Part No. Drawing Dimensions in mm Seal M12 2.9 - 4.0 mm 4 - 5.1 mm 21 01 010 2011 21 01 010 2001 Seal M12-L 3 poles: 5.5 - 7.2 mm 4 + 5 poles: 6 - 8 mm 21 01 010 2003 21 01 010 2007 Cap M12 21 01 000 0003 Han® M8 dynamometric screwdriver for M12-S SW 13 09 99 000 0382 for M12-L SW 17 09 99 000 0384 19 Stock items in bold type Circular connector M12 shielded, A-coded Part No. Identification HARAX ® Male Female Drawing Dimensions in mm M12-L, screened version 4 poles, A-coded 0.14 - 0.34 mm² / AWG 26 - 22 21 03 221 1405 4 poles, A-coded 0.14 - 0.34 mm² / AWG 26 - 22 21 03 221 2405 View mating side, male version: HARAX ® M12-L, screened version 4 poles A-coded HARAX ® panel feed-through 4 poles, A-coded 0.14 - 0.34 mm² / AWG 26 - 22 5.5 - 7.2 mm 21 03 321 1425 4 poles, A-coded 0.14 - 0.34 mm² / AWG 26 - 22 5.5 - 7.2 mm 21 03 321 2425 20 Stock items in bold type Circular connector M12 shielded, A-coded Part No. Identification Han ® Male Female Drawing Dimensions in mm M12 Crimp 4 poles, A-coded 4.5 - 5.4 mm / 7 - 8.8 mm 21 03 812 1405 4 poles, A-coded 4.5 - 5.4 mm / 7 - 8.8 mm 21 03 812 2405 Han ® M12 panel feed-through Crimp 4 poles, A-coded 5.5 - 7.2 / 7 - 8.8 mm 21 03 822 1425 4 poles, A-coded 5.5 - 7.2 / 7 - 8.8 mm 21 03 822 2425 21 Circular connector M12 shielded, B-coded Part No. Identification Male Female Drawing Dimensions in mm M12-L, screened version HARAX ® 2 poles, B-coded 2 poles and shield, B-coded 21 03 241 1301 21 03 241 1300 2 poles, B-coded 2 poles and shield, B-coded 21 03 241 2301 21 03 241 2300 View mating side, male version: HARAX ® M12-L, screened version 2 poles 2 poles 21 03 241 1301 21 03 241 2301 B-coded B-coded 3 poles PROFIBUS B-coded HARAX ® panel feed-through 2 poles and shield, B-coded 5.5 - 7.2 mm 21 03 341 1425 2 poles and shield, B-coded 5.5 - 7.2 mm 21 03 341 2425 22 Stock items in bold type Han® M12 System cables, B-coded Technical characteristics Rated voltage max. 125 V AC/ DC Rated current/contact max. 4 A Locking Screw locking M12 x 1 mm, self securing Recommended torque 0.6 Nm Temperature range (male) °C -25 °C … +85 °C (dependant on connected conductor) Degree of protection IP 67 Number of wires / wire gauge 4 x 0.64 mm² Conductor insulation PUR (rt, gn) Arrangement of insulated strands 19 x 0.13 mm Sheath PUR (UL/CSA) Outer diameter appr. 7.8 mm Bending radius 65 x outer diameter Temperature range °C (applicate with fixed cable) -30 °C … + 80 °C Identification Part No. Drawing Han® M12 Circular connector, Male, straight pre-assembled on one end, useable as trailing cable Length: 1.5 m 3.0 m 5.0 m 7.5 m 10.0 m 21 03 549 1301 21 03 549 1302 21 03 549 1303 21 03 549 1304 21 03 549 1305 Schematic diagram 2 4 green grün red rot shielding Schirm Han® M12 Circular connector, Male, angled pre-assembled on one end, useable as trailing cable Length: 1.5 m 3.0 m 5.0 m 7.5 m 10.0 m 21 03 549 3301 21 03 549 3302 21 03 549 3303 21 03 549 3304 21 03 549 3305 Schematic diagram 2 4 green grün red rot shielding Schirm Stock items in bold type 23 Han® M12 System cables, B-coded Identification Part No. Drawing Han® M12 Circular connector, Female, straight pre-assembled on one end, useable as trailing cable Length: 1.5 m 3.0 m 5.0 m 7.5 m 10.0 m 21 03 549 2301 21 03 549 2302 21 03 549 2303 21 03 549 2304 21 03 549 2305 Schematic diagram grün green rot red 2 4 shielding Schirm Han® M12 Circular connector, Female, angled pre-assembled on one end, useable as trailing cable Length: 1.5 m 3.0 m 5.0 m 7.5 m 10.0 m 21 03 549 4301 21 03 549 4302 21 03 549 4303 21 03 549 4304 21 03 549 4305 Schematic diagram grün green rot red 2 4 shielding Schirm Han® M12 Circular connector, Male, straight Female, straight pre-assembled on one end, useable as trailing cable Length: 0.3 m 0.6 m 1.0 m 1.5 m 2.0 m 21 03 449 4301 21 03 449 4302 21 03 449 4303 21 03 449 4304 21 03 449 4305 Schematic diagram 2 2 4 4 shielding Schirm Han® M12 Circular connector, Male, angled Female, angled pre-assembled on one end, useable as trailing cable Length: 24 0.3 m 0.6 m 1.0 m 1.5 m 2.0 m 21 03 449 6301 21 03 449 6302 21 03 449 6303 21 03 449 6304 21 03 449 6305 Schematic diagram 2 2 4 4 shielding Schirm Stock items in bold type Han® M12 Accessories, B-coded Technical characteristics: Han ® M12 panel feed-through Degree of protection IP 67 in locked position Rated current max. 4 A (each contact) Rated voltage 250 V AC/DC Mating cycles max. 100 Limiting temperatures -25 °C … +85 °C Termination solder, with pigtails (TPE insulation) assembled Identification Male Part No. Female Drawing Dimensions in mm Han® M12-panel feed-through Male, B-coded, 20 cm conductor, 0.25 mm² 21 03 339 1301 Han® M12-panel feed-through Female, B-coded, 20 cm conductor, 0.25 mm² 21 03 339 2301 Han® M12-male moving load B-coded 21 03 030 1300 Han® M12-male/female panel feed-through B-coded 21 03 330 1300 Rated voltage 24 V AC/DC Thread M16 x 1,5 Stock items in bold type 25 Circular connector M12 shielded, D-coded Part No. Identification Male Female Drawing Dimensions in mm M12-L, screened version HARAX ® 4 poles, D  -coded, 0.14 - 0.34 mm², AWG 26-22 0.34 - 0.5  mm², AWG 22-20 21 03 281 1405 21 03 282 1405 4 poles, D  -coded, 0.14 - 0.34 mm², AWG 26-22 0.34 - 0.5  mm², AWG 22-20 21 03 281 2405 21 03 282 2405 View mating side, male version: HARAX ® M12-L, screened version 4 poles Ethernet D-coded HARAX ® panel feed-through D-coded 5.5 - 7.2 mm 21 03 381 1425 D-coded 5.5 - 7.2 mm 21 03 381 2425 26 Stock items in bold type Circular connector M12 shielded, D-coded Identification Han ® Male Part No. Female Drawing Dimensions in mm M12 Crimp D-coded 5.5 - 7.2 mm / 7 - 8.8 mm 21 03 882 1405 21 03 882 2405 Han ® M12 panel feed-through Crimp D-coded 5.5 - 7.2 / 7 - 8.8 mm 21 03 882 1425 Han ® M12 panel feed-through Crimp D-coded 5.5 - 7.2 / 7 - 8.8 mm 21 03 882 2425 27 Han® M12 System cables, D-coded Technical characteristics Pre-assembled and tested system cables Cable type: Shielded Twisted Pair Standard Cable for structured cabling of industrial Ethernet networks, ­based on Han® M12 Circular connectors, D-coded Mating interface: M12 D-coded acc. to IEC 61 076-2-101 Transmission performance acc. to ISO/IEC 11801:2002: Class D, 100% tested Degree of protection IP 65 / IP 67 (when mated) Pin assignment Conductor colour EIA/TIA 568B Contact assignment Signal Function Conductor colour PROFInet® TD+ Transmission Data+ Yellow White/ Orange 1 TD- Transmission Data- Orange Orange 3 RD+ Receiver Data+ White White/Green 2 RD- Receiver Data- Blue Green 4 28 Stock items in bold type Han® M12 System cables, D-coded Identification Part No. 2 x Han® M12 Circular connector, D-coded, straight Length: 1 m 3m 5m 10 m 15 m 25 m 40 m Drawing Dimensions in mm 21 03 483 1401 21 03 483 1403 21 03 483 1405 21 03 483 1410 21 03 483 1415 21 03 483 1425 21 03 483 1440 cable: AWG 26 / 0.14 mm² 21 03 485 1401 21 03 485 1403 21 03 485 1405 21 03 485 1410 21 03 485 1415 21 03 485 1425 21 03 485 1440 cable: AWG 22 / 0.34 mm² 21 03 583 1401 21 03 583 1403 21 03 583 1405 21 03 583 1410 21 03 583 1425 21 03 583 1440 cable: AWG 26 / 0.14 mm² 21 03 585 1401 21 03 585 1403 21 03 585 1405 21 03 585 1410 21 03 585 1425 21 03 585 1440 cable: AWG 22 / 0.34 mm² other length on request 2 x Han® M12 Circular connector, D-coded, straight Length: 1 m 3m 5m 10 m 15 m 25 m 40 m other length on request 1 x Han® M12 Circular connector, D-coded, straight Length: 1 m 3m 5m 10 m 25 m 40 m other length on request 1 x Han® M12 Circular connector, D-coded, straight Length: 1 m 3m 5m 10 m 25 m 40 m other length on request 29 Stock items in bold type Han® M12 panel feed-through, D-coded Identification Part No. Drawing Dimensions in mm Han® M12 panel feed-through Male, D-coded, 50 cm conductors, AWG 22, 4 poles 21 03 371 1403 Han® M12 panel feed-through Female, D-coded, 50 cm conductors, AWG 22, 4 poles 21 03 371 2403 Han® M12-RJ45 panel feed-through 4 poles, D-coded, angled 21 03 381 4400 Han® M12-RJ45 panel feed-through 4 poles, D-coded, straight 21 03 381 2400 Han® M12 Gender Changer 4 poles, D-coded 21 03 381 6405 30 Stock items in bold type Han® M12 Accessories Identification Part No. Technical characteristics Crimping tool 09 99 000 0501 Locator 61 03 600 0023 Single contacts turned male contacts* AWG 22-20 / 0.33-0.52 AWG 26-22 / 0.13-0.33 61 03 000 0073 61 03 000 0094 AWG 22-20 AWG 26-22 turned female contacts* AWG 22-20 / 0.33-0.52 AWG 26-22 / 0.13-0.33 a 8.10 8.10 b 4.0 4.0 c 14.8 14.8 d 1.12 0.90 e 1.66 1.66 f 14.4 14.4 61 03 000 0074 61 03 000 0096 31 Stock items in bold type Han® 7/8“ Circular connector Identification HARAX ® Part No. Drawing Dimensions in mm 7/8“ Male 21 04 116 1505 HARAX ® 7/8“ Female 21 04 116 2505 32 Stock items in bold type Circular connector 7/8’’ Overmolded cordsets 7/8’’ Technical characteristics Degree of protection IP 67 Temperature range applies to moved cable cables permanently installed -20 °C … +80 °C -50 °C … +80 °C Rated current max. 8 A every contact (+40 °C) Rated voltage 230 / 400 V Rated impulse voltage 3 kV Pollution degree 3 Material group Category I acc. to IEC 60 664-1 Cable data Jacket material PUR Jacket colour grey Wire isolation TPM Wire colours brown, white, blue, black, green/yellow Wire gauge 5 x 1.5 mm² Standards UL / CSA 33 Han® 7/8’’ System cables Overmolded cordsets 7/8’’ Identification Part No. Drawing Dimensions in mm Overmolded cordsets 7/8’’ Female straight 5 pin Length: 1.5 m 3.0 m 5.0 m 7.5 m 10.0 m 21 04 516 2501 21 04 516 2502 21 04 516 2503 21 04 516 2504 21 04 516 2505 Schematic diagram View mating side Schematic diagram View mating side Overmolded cordsets 7/8’’ Female angled 5 pin Length: 1.5 m 3.0 m 5.0 m 7.5 m 10.0 m 21 04 516 4501 21 04 516 4502 21 04 516 4503 21 04 516 4504 21 04 516 4505 Overmolded cordsets 7/8’’ Male-Female straight 5 pin Length: 0.3 m 0.6 m 1.0 m 1.5 m 2.0 m 21 04 416 1501 21 04 416 1502 21 04 416 1503 21 04 416 1504 21 04 416 1505 Schematic diagram View mating side Overmolded cordsets 7/8’’ Male-Female angled 5 pin Length: 0.3 m 0.6 m 1.0 m 1.5 m 2.0 m 21 04 416 3501 21 04 416 3502 21 04 416 3503 21 04 416 3504 21 04 416 3505 Schematic diagram View mating side 34 Stock items in bold type Han® 7/8“ Panel feed through + Accessories Identification Part No. Drawing Dimensions in mm Han® 7/8“ panel feed-through 30 cm conductors, 0.75 mm², 5 poles Male 21 04 316 1505 Han® 7/8“ panel feed-through 30 cm conductors, 0.75 mm², 5 poles Female 21 04 316 2505 Lock nut Pg 13.5 nickel plated 21 01 000 0020 Han ® 7/8“ dynamometric screwdriver for 7/8“ SW 23 09 99 000 0395 35 Stock items in bold type Han® M12 pcb adapter Technical characteristics: Han® M12 pcb Degree of protection IP 20 Rated current max. 4 A (dependant on pcb layout) Rated voltage 50 V mating cycles max. 100 Limiting temperatures - 25 °C / + 85 °C Temperature during connection - 5 °C / + 50 °C Current carrying capacity The current carrying capacity is limited by maximum temperature of materials for inserts and contacts including terminals. The current capacity-curve is valid for continuous, not interruptet current-loaded contacts of connectors when simultaneous power on all contacts is given, without exceeding the maximum temperature. Control and test procedures according to DIN IEC 60 512-5. wire gauge 0.75 mm² Rated current [A] M12, A-Kodierung, straight, female, 4 poles wire gauge 0.5 mm² Rated current [A] M12, A-Kodierung, straight, male, 4 poles Ambient temperature [°C] Ambient temperature [°C] wire gauge 0.5 mm² Rated current [A] M12, A-Kodierung, straight, male, 5 poles wire gauge 0.5 mm² Rated current [A] M12, A-Kodierung, straight, female, 5 poles Ambient temperature [°C] M12, D-Kodierung, gewinkelt, female, 4 poles wire gauge 0.5 mm² wire gauge AWG 22 Rated current [A] M12, D-Kodierung, straight, female, 4 poles Rated current [A] 36 Ambient temperature [°C] Ambient temperature [°C] Ambient temperature [°C] Han® M12 pcb adapter A-coded Identification Part No. Drawing Dimensions in mm Han® M12 Male, A-coded, straight 4 poles 21 03 321 1410 5 poles 21 03 321 1510 4 poles 21 03 321 6410 5 poles 21 03 321 6510 Han® M12 Female, A-coded, straight 37 Stock items in bold type Han® M12 pcb adapter D-coded Identification Part No. Drawing Dimensions in mm Han® M12 Male, D-coded, straight, 4 poles 21 03 371 1400 Han® M12 Female, D-coded, straight, 4 poles 21 03 371 2415 21 03 381 6410 Han® M12 Female, D-coded, angled, 4 poles without fixing hole 21 03 381 4410 with fixing hole 21 03 381 4412 38 Stock items in bold type Notes 39 HARAX  ® Pg 9 panel feed-through Technical characteristics: HARAX  ® Pg 9 panel feed-through Rated voltage 32 V Rated current 4A Wire gauge 0.25 - 0.5 mm² / 24/7 AWG - 22 AWG Diameter of individual strands ≥ 0.1 mm Conductor insulation material PVC Conductor diameter 1.2 - 1.6 mm Cable diameter 4.0 - 5.1 mm Working temperature - 25 °C … + 85 °C Temperature during connection - 5 °C … + 50 °C Degree of protection IP 67 Termination cycles with the same cross section 10 40 Fettdruck: Vorzugstypen HARAX  ® Pg 9 panel feed-through Identification Part No. Drawing Dimensions in mm HARAX ® Pg 9 panel feed-through 3 contacts, with pre-assembled 0.5 m / 0.5 mm² pigtail cable 21 01 130 4241 View: Termination side HARAX ® Pg 9 panel feed-through 4 contacts, with pre-assembled 0.5 m / 0.5 mm² pigtail cable 21 01 140 4341 View: Termination side HARAX ® Pg 9 panel feed-through 3 contacts with faston blades 21 01 130 4011 View: Termination side Termination element M12 HARAX ® 3 contacts Screw cap, splice ring, seal 21 01 010 0001 Termination element M12 HARAX ® 4 contacts Screw cap, splice ring, seal 21 01 010 0006 41 Stock items in bold type HARAX ® Pg 13.5 / M20 panel feed-through Technical characteristics 1 = wire gauge 0.75 mm² Construction type Working voltage acc. to UL / CSA Working current (see current carrying capacity) Testing voltage Conductor cross section Diameter of individual strands Outer cable diameter Termination cycles with the same cross section Limiting temperature Temperature during connection Degree of protection Conductor insulation material Max. tightening torque Pg 13,5 3 poles 250 V 4 kV 3 with faston terminals with insulation cap 600 V 16 A Pg 13,5 / M20 4 poles 230/400 V 4 kV 3 600 V 16 A 4 kV (1.2 / 50) 0.75 - 1.5 mm² 4 kV (1.2 / 50) 0.75 - 1.5 mm² ≥ 0.2 mm 6.0 - 9.0 mm ≥ 0.2 mm 6.0 - 9.0 mm 10 - 25 / + 85 oC 10 - 25 / + 85 oC - 5 … + 50 oC IP 67 PVC 8 Nm - 5 … + 50 oC IP 67 PVC 8 Nm 2 = wire gauge 1.5 mm² Working current [A] Approval Pg 13,5 3 contacts IEC 60 352-4 DIN 61 984 , VDE Ambient temperature [oC] Pg 13,5 / M20 4 contacts 1 = wire gauge 0.75 mm² 2 = wire gauge 1.5 mm² Working current [A] Specifications Current carrying capacity The current carrying capacity is limited by maximum temperature of materials for inserts and contacts including terminals. The current capacity-curve is valid for continuous, not interrupted ­current-loaded contacts of connectors when simultaneous power on all contacts is given, without exceeding the maximum temperature. Control and test procedures according to DIN IEC 60 512-3. 42 Ambient temperature [oC] HARAX ® Pg 13.5 / M20 panel feed-through Identification Part No. Drawing Dimensions in mm HARAX ® Pg 13.5 / 3 contacts with faston blades 21 01 130 1013 HARAX ® Pg 13.5 / 3 contacts with solder termination 21 01 130 1023 HARAX ® Pg 13.5 / 3 contacts with pre-assembled pigtail cable. I = 500 mm, 1.5 mm² 21 01 130 1223 View: Mating side HARAX ® Pg 13.5 / 2 + PE with faston blades 21 01 130 3013 HARAX ® Pg 13.5 / 2 + PE with solder termination 21 01 130 3023 HARAX ® Pg 13.5 / 2 + PE with pre-assembled pigtail cable, I = 500 mm, 1.5 mm² 21 01 130 3233 View: Mating side HARAX ® Pg 13.5 / 4 contacts with solder termination 21 01 140 1023 HARAX ® Pg 13.5 / 3 + PE with solder termination 21 01 140 3023 HARAX ® Pg 13.5 / 4 contacts with pre-assembled strand, I = 500 mm, 1.5 mm² 21 01 140 1323 View: Mating side HARAX ® Pg 13.5 / 3 + PE with pre-assembled strand, l = 500 mm, 1.5 mm² 21 01 140 3333 HARAX ® M20 / 4 contacts with solder termination 21 01 141 1023 HARAX ® M20 / 3 + PE with solder termination 21 01 141 3023 HARAX ® M20 / 4 contacts with pre-assembled strand, l = 500 mm, 1.5 mm² 21 01 141 1323 View: Mating side HARAX ® M20 / 3 + PE with pre-assembled strand, l = 500 mm, 1.5 mm² 21 01 141 3333 43 Other length on request Stock items in bold type Catalogue order information CD-Rom HARKIS ® Please send me further information: HARTING Interface Connectors HARTING Telecom Outdoor Solutions People | Power | Partnership People | Power | Partnership HARTING DIN 41 612 Interface Connectors DVD HARKIS ® HARTING Industrial Connectors Han® People | Power | Partnership )"35*/( Ethernet Network Solutions Automation IT Telecom Outdoor Solutions Industrial ­Connectors Han® People | Power | Partnership 1FPQMF]1PXFS]1BSUOFSTIJQ HARTING Coaxial and Metric Connectors Connectors DIN 41 612 Ethernet N ­ etwork ­Solutions Automation IT 05 1 35 2 People | Power | Partnership HARTING TCA Connectors Coaxial and Metric Connectors HARTING Device Connectivity DeviceCon HARTING Technologies meet Markets HARTING Application ­brochure 08_9761+9762_HA_Applikationsbros1 1 People | Power | Partnership TCA Connectors Sender: 05.03.2008 12:05:45 People | Power | Partnership Device Connectivity DeviceCon Company: Street: Department: Postcode/Town: Name: Country: Prename: Phone: Function: Fax: Please send it by post or fax to your local HARTING representatives (see page addresses) or visit us under www.HARTING.com. E-Mail: Backplanes and Integrated Systems Backplanes and ­Integrated Systems People | Power | Partnership Production plants – worldwide Sales partner – worldwide Argentina Condelectric S.A. Hipólito Yrigoyen 2591 (B1640HFY) Martínez, Buenos Aires Phone + Fax +54 11 4836-1053 E-Mail: info@condelectric.com.ar Espelkamp / Germany – Plant 1 Espelkamp / Germany – Plant 2 Canada Chartwell Electronics Inc. 140 Duffield Drive Markham, Ontario L6G 1B5 Phone 905-513-7100 Toll Free 877-513-7769 Fax 905-513-7101 Internet: www.chartwell.ca Denmark Knud Wexøe A/S Skaettekaeret 11, P.O. Box 152 DK-2840 Holte Phone +4545465800 Fax +4545465801 E-Mail: wexoe@wexoe.dk Internet: www.wexoe.dk Estonia SKS Tehnika OÜ Liimi 1, EE-10621 Tallinn Phone +372 699 0171 Fax +372 699 0170 E-Mail: tehnika@sks.fi Internet: www.sks.fi Finland SKS Automaatio Oy Martinkyläntie 50, FI-01720 Vantaa Phone +358 (0) 20 764 61 Fax +358 (0) 20 764 6820 E-Mail: automaatio@sks.fi Internet: www.sks.fi Island Smith & Norland, Nóatún 4 IS – 105 Reykjavík Phone +354 520 3000 Fax +354 520 3011 E-Mail: olaf@sminor.is Internet: www.sminor.is Israel COMTEL Israel Electronics Solutions Ltd. Bet Hapamon, 20 Hataas st., P.O.Box 66, Kefar-Saba 44425 Phone +972-9-7677240 Fax +972-9-7677243 E-Mail: sales@comtel.co.il Internet: www.comtel.co.il Espelkamp / Germany – Plant 3 Zhuhai / China Espelkamp / Germany – Plant 4 Northampton / Great Britain Biel / Switzerland Espelkamp / Germany – Plant 5 Sibiu / Romania Elgin / USA Sales partner – worldwide South Africa HellermannTyton Pty Ltd. Private Bag X158 Rivonia 2128 34 Milky Way Avenue Linbro Business Park 2065 Johannesburg, South Africa Phone +27(0)11879-6600 Fax +27(0)11879-6606 E-Mail: sales.jhb@hellermann.co.za Turkey Gökhan Elektrik San. Tic. Ltd. Sti. Perpa Elektrikçiler Is Merkezi A Blok Kat:7-8-9 No.694 TR – 80270 Okmeydani/Istanbul Phone +90(212) 2213236 (pbx) Fax +90(212) 2213240 E-Mail:gokhan@gokhanelektrik.com.tr Internet: www.gokhanelektrik.com.tr Subsidiary companies – worldwide Australia HARTING Pty Ltd. Suite 11/2 Enterprise Drive Bundoora 3083, Victoria Phone +61 (3) 9466 7088 Fax +61 (3) 9466 7099 Austria HARTING Ges. m. b. H. Deutschstraße 19, A-1230 Wien Phone +431/6162121 Fax +431/6162121-21 E-Mail: at@HARTING.com Belgium HARTING N.V./S.A. Z.3 Doornveld 23, B-1731 Zellik Phone +322/4660190 Fax +322/4667855 E-Mail: be@HARTING.com Brazil HARTING Ltda. Av. Dr. Lino de Moraes Pq. Jabaquara, 255 CEP 04360-001 – São Paulo – SP – Brazil Phone +5511/5035-0073 Fax +5511/5034-4743 E-Mail: br@HARTING.com Internet: www.HARTING.com.br China Zhuhai HARTING Limited Shanghai branch Room 5403, 300 Huaihai Zhong Road Hong Kong New World Tower Luwan District, P.R.C Shanghai 200021, China Phone +86 21 – 63 86 22 00 Fax +86 21 – 63 86 86 36 E-Mail: cn@HARTING.com Czech Republic HARTING spol. s.r.o. Ml´ynská 2, 16000 Praha 6 Phone +420 220 380 460 Fax +420 220 380 461 E-Mail: cz@HARTING.com Internet: www.HARTING.cz Great Britain HARTING Ltd., Caswell Road Brackmills Industrial Estate GB-Northampton, NN4 7PW Phone +441604/766686, 827500 Fax +441604/706777 E-Mail: gb@HARTING.com Internet: www.HARTING.co.uk Finland HARTING Oy Teknobulevardi 3-5, PL 35 FI-01530 Vantaa Phone +358 9 350 873 00 Fax +358 9 350 873 20 E-Mail: fi@HARTING.com Hong Kong HARTING (HK) Limited Regional Office Asia Pacific 3512 Metroplaza Tower 1 223 Hing Fong Road Kwai Fong, N. T., Hong Kong Phone +852/2423-7338 Fax +852/2480-4378 E-Mail: ap@HARTING.com Internet: www.HARTING.com.hk France HARTING France 181 avenue des Nations Paris Nord 2 BP 66058 Tremblay en France F-95972 Roissy Charles de Gaulle Cédex Phone +33149383400 Fax +33148632306 E-Mail: fr@HARTING.com Hungary HARTING Magyarországi Kft. 1119 Budapest, Fehérvári út 89-95. II. emelet 217/A. Phone +36-1-205 3464 Fax +36-1-205 3465 E-Mail: hu@HARTING.com Internet: www.HARTING.hu Germany HARTING Deutschland GmbH & Co. KG Postfach 2451, D-32381 Minden Simeonscarré 1, D-32427 Minden Phone (0571) 8896-0 Fax (0571) 8896-282 E-Mail: de@HARTING.com Internet: www.HARTING.com India HARTING India Private Limited No. D, 4th Floor, 'Doshi Towers' No. 156 Poonamallee High Road, Kilpauk, Chennai 600 010, Tamil Nadu, Chennai Phone +91-44-4356 0415/6 Fax +91-44-4356 0417 E-Mail: in@HARTING.com Internet: www.HARTING.com Office Germany HARTING Deutschland GmbH & Co. KG Blankenauer Straße 99 D-09113 Chemnitz Phone +49 0371 429211 Fax +49 0371 429222 E-Mail: de.sales@HARTING.com Italy HARTING SpA Via Dell' Industria 7 I-20090 Vimodrone (Milano) Phone +3902/250801 Fax +3902/2650597 E-Mail: it@HARTING.com Subsidiary companies – worldwide Japan HARTING K. K. Yusen Shin-Yokohama 1 Chome Bldg., 2F, 1-7-9, Shin-Yokohama Kohoku-ku, Yokohama, 222-0033 Japan Phone +81 45 476 3456 Fax +81 45 476 3466 E-Mail: jp@HARTING.com Internet: www.HARTING.co.jp Singapore HARTING Singapore Pte Ltd. 25 International Business Park #02-06 German Centre Singapore 609916 Phone +6562255285, Fax +6562259947 E-Mail: sg@HARTING.com Spain HARTING Iberia S.A. Korea Josep Tarradellas 20-30 4o 6a HARTING Korea Limited E-08029 Barcelona #308 Leaders Bldg., 342-1, Yatap-dong Phone +34 933 638 475 ­Bundang-gu, Sungnam-City, Kyunggi-do Fax +34 934 199 585 463-828, Korea E-Mail: es@HARTING.com Phone +82-31-781-4615 Fax +82-31-781-4616 Sweden E-Mail: kr@HARTING.com HARTING AB Gustavslundsvägen 141 B 4tr Netherlands 167 51 Bromma HARTING B.V. Phone +468/4457171 Larenweg 44 Fax +468/4457170 NL-5234 KA 's-Hertogenbosch E-Mail: se@HARTING.com Postbus 3526 NL-5203 DM 's-Hertogenbosch Phone +3173/6410404 Fax +3173/6440699 E-Mail: nl@HARTING.com Norway HARTING A/S Østensjøveien 36, N-0667 Oslo Phone +4722/700555 Fax +4722/700570 E-Mail: no@HARTING.com Poland HARTING Polska Sp. z o. o. ul. Kamieńskiego 201-219 51-126 Wrocław Phone +48 71-352 81 71 Phone +48 71-352 81 74 Fax +48 71-320 74 44 E-Mail: pl@HARTING.com Internet: www.HARTING.pl Portugal HARTING Iberia, S. A. Avda. Josep Tarradellas, 20-30, 4o 6a E-08029 Barcelona Phone +351.219.673.177 Fax +351.219.678.457 E-Mail: es@HARTING.com Russia HARTING ZAO, ul. Tobolskaja 12 Saint Petersburg, 194044 Russia Phone +7/812/3276477 Fax +7/812/3276478 E-Mail: ru@HARTING.com Internet: www.HARTING.ru MO/??.??.08/4.0 98 41 103 0201 Switzerland HARTING AG Industriestrasse 26 CH-8604 Volketswil Phone +4144 9082060 Fax +4144 9082069 E-Mail: ch@HARTING.com Taiwan HARTING R.O.C. Limited Room 1, 5th Floor, No. 495 GuangFu South Road Taiwan – Taipei 110 Phone +886 02-2758-6177 Fax +886 02-2758-7177 E-Mail: tw@HARTING.com Internet: www.HARTING.com.tw USA HARTING Inc. of North America 1370 Bowes Road Elgin, Illinois 60123 Phone +1 (877) 741-1500 (toll free) Fax +1 (866) 278-0307 (Inside Sales) Fax +1 (847) 717-9430 (Sales and Marketing) E-Mail: us@HARTING.com Internet: www.HARTING-USA.com Eastern-Europe HARTING Eastern Europe GmbH Bamberger Straße 7, D-01187 Dresden Phone +49 351 / 4361760 Fax +49 351 / 4361770 E-Mail: Eastern.Europe@HARTING.com Distributor – Switzerland Distrelec AG Grabenstrasse 6 CH-8606 Nänikon Phone +41 1 944 99 11 Fax +41 1 944 99 88 E-Mail: info@distrelec.com Internet: www.distrelec.com Distributors – worldwide Farnell InOne www.farnellinone.com; in US: Newark InOne: www.newarkinone.com RS Components www.rs-components.com; in US: Allied Electronics: www.alliedelec.com Other countries HARTING Electric GmbH & Co. KG P.O. Box 1473, D-32328 Espelkamp Phone +495772/47-97100 Fax + 495772/47-495 E-Mail: electric@HARTING.com Global Business Unit Electric HARTING Electric GmbH & Co. KG P.O. Box 14 73 D-32328 Espelkamp Phone Fax +49 57 72 / 47-97 100 +49 57 72 / 47- 4 95 E-Mail: electric@HARTING.com Internet: www.HARTING.com www.HARTING.com
21 03 311 1402 价格&库存
很抱歉,暂时无法提供与“21 03 311 1402”相匹配的价格&库存,您可以联系我们找货
  • 1+164.22621
  • 50+159.55040
  • 100+156.04094
  • 250+153.63534
库存:70
