Printview: Compact splicing connector; 5-conductor terminal block; with operating levers; max. continuous
service temperature 85°C - Item No.: 222-415
operating levers; max. continuous service temperature 85°C
Item No.: 222-415
Compact splicing connector; 5-conductor terminal block; with operating levers; max. continuous service temperature
85°C
Marking
Business data
Supplier
WAGO
Item no.
222-415
GTIN / EAN
4044918464956
Content
1
Order amount
40
Customer item number
Notes
Technical data
Miscellaneous
Total number of connection points
5
Total number of potentials
1
Color
gray
Pollution degree (1)
2
Rated voltage EN (1) [V]
400 [V]
Rated surge voltage (1) [kV]
4 [kV]
Nominal current [A]
32 [A]
Connection technology (1)
CAGE CLAMP®
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Solid sizes 1
0.08 … 2.5 mm² / 28 … 12 AWG
stranded, connectable 1
Fine-stranded wires 1
0.08 … 4 mm² / 28 … 12 AWG
Strip length 1
9 … 10 mm / 0.35 … 0.39 in
Type of wiring
Side-entry wiring
Fire load [MJ]
0.13 [MJ]
Weight [g]
6.58 [g]
Width
26.6 mm / 1.047 in
Height
14.5 mm / 0.571 in
Length
20.5 mm / 0.807 in
Safety information 1
In grounded power lines
2
Images & drawings
3
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
4
很抱歉,暂时无法提供与“222-415/K194-4045”相匹配的价格&库存,您可以联系我们找货
