10
Connectors for KNX/EIB Bus Coupler Units
243 Series
544
Compact, 4-conductor KNX connectors with PUSH WIRE®
Simple push-in termination for solid conductors
-conductor entries allow devices to be replaced without disrupting
4
the KNX bus connection
Technical data:
Ratings per
Overvoltage category
Pollution degree
Rated voltage
Rated surge voltage
Nominal current
Approvals per
Use group UL 1059
Rated voltage
Nominal current UL
Nominal current CSA
IEC/EN 60664-1
III
III
II
3
2
2
250 V 320 V 630 V
4 kV
4 kV
4 kV
6A
6A
6A
UL/CSA
B
C
D
Conductor data:
Connection technology
Conductor size: solid
AWG
Strip length
PUSH WIRE®
4 x 0.6 … 0.8 mm or 4 x 1.0 mm Ø
4 x 22 … 20 “sol.” or 4 x 18 “sol.”
5 … 6 mm / 0.20 … 0.24 in.
Material data:
Material group
Insulating material
Flammability class per UL 94
Lower/Upper limit temperature
Clamping spring material
Contact material
Contact plating
I
Polyamide 66 (PA 66)
V0
-60 °C / +105 °C
Chrome nickel spring steel (CrNi)
Electrolytic copper (ECu)
tin-plated
Additional approvals and corresponding ratings can be found at www.wago.com.
For additional technical information, see Section 13.
很抱歉,暂时无法提供与“243-212”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.901931+1.15386
- 10+7.5735710+0.98168
- 25+7.1023625+0.92060
- 50+6.7620650+0.87649
- 100+6.43764100+0.83444
- 250+6.03451250+0.78219
- 500+5.74604500+0.74480
- 1000+5.471691000+0.70924
- 2500+5.129172500+0.66484
- 国内价格
- 10+4.01662
- 100+3.93539
- 500+3.85625
