745-112
745-112
    WAGO(万可电子)
    插件
    接线端子
745-112 数据手册
Printview: Terminal strip with jumper slot; 2 solder pins/pole; 12-pole; pin spacing 5 mm / 0.197 in; without fixing flange - Item No.: 745-112 . Terminal strip with jumper slot; 2 solder pins/pole; 12-pole; pin spacing 5 mm / 0.197 in; without fixing flange Item No.: 745-112 . Terminal strip with jumper slot; 2 solder pins/pole; 12-pole; pin spacing 5 mm / 0.197 in; without fixing flange . Marking . Business data Supplier WAGO Item no. 745-112 GTIN / EAN 4044918671149 Content 1 Order amount 40 Customer item number . Notes Terminal strips with screwdriver-actuated CAGE CLAMP®Also available with Ex e approvalComb-style jumper bars for commoning and distributing potentialsCustom color combinationsDouble solder pins for high mechanical stabilitySaves spaces thanks to positioning of terminal strips behind one anotherIntegrated testing tapMarker slot for miniature WSB markers Technical data Miscellaneous No. of poles 12 Pin Spacing 5 mm (0.197 in %) Total number of connection points 12 Total number of potentials 12 Color gray Ratings according to 1 IEC/EN 60664-1 WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Terminal strip with jumper slot; 2 solder pins/pole; 12-pole; pin spacing 5 mm / 0.197 in; without fixing flange - Item No.: 745-112 Technical data Overvoltage category EN 1 III Pollution degree (1) 2 Rated voltage EN (1) [V] 320 [V] Rated surge voltage (1) [kV] 4 [kV] Nominal current [A] 32 [A] Overvoltage category EN 2 II Degree of pollution (2) 2 Rated voltage EN (2) [V] 630 [V] Rated surge voltage (2) [kV] 4 [kV] Nominal current (2) [A] 32 [A] Overvoltage category EN 3 III Degree of pollution (3) 3 Rated voltage EN (3) [V] 320 [V] Rated surge voltage (3) [kV] 4 [kV] Nominal current (3) [A] 32 [A] Number of individual connection objects at the product 1 Connection technology (1) CAGE CLAMP® Solid sizes 1 0.08 … 4 mm² / 28 … 12 AWG Fine-stranded wires 1 0.08 … 4 mm² / 28 … 12 AWG Fine-stranded wires with insulated ferrule 1 0.25 … 2.5 mm² / … Fine-stranded wires with uninsulated ferrule 1 0.25 … 2.5 mm² / … Strip length 1 8 … 9 mm / 0.31 … 0.35 in Conductor entry angle to the PCB 1 [°] 45 [°] Solder pin arrangement in-line solder pin Solder pin length [mm] 4 [mm] Solder pin width A [mm] 0.8 [mm] Solder pin width B [mm] 1.2 [mm] Tolerance of drilled hole [mm] 1.5(+ 0.1) [mm] Material group I Insulating material Polyamide 66 (PA 66) Flammability rating per UL 94 V0 Limit temperature range -60 C … 105 C Clamping spring material Chrome-nickel spring steel (CrNi) Contact material Electrolytic copper (Ecu) WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Terminal strip with jumper slot; 2 solder pins/pole; 12-pole; pin spacing 5 mm / 0.197 in; without fixing flange - Item No.: 745-112 Technical data Contact plating tin-plated Fire load [MJ] 0.398 [MJ] Weight [g] 24.512 [g] Width 61.5 mm / 2.421 in Height 23 mm / 0.906 in Height from the surface 19 mm / 0.748 in Length 22.9 mm / 0.902 in WAGO Kontakttechnik GmbH & Co. KG 3 Printview: Terminal strip with jumper slot; 2 solder pins/pole; 12-pole; pin spacing 5 mm / 0.197 in; without fixing flange - Item No.: 745-112 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 4 Printview: Terminal strip with jumper slot; 2 solder pins/pole; 12-pole; pin spacing 5 mm / 0.197 in; without fixing flange - Item No.: 745-112 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 5
745-112 价格&库存
很抱歉,暂时无法提供与“745-112”相匹配的价格&库存,您可以联系我们找货
