ESD-132-G-05
ESD-132-G-05
    SAMTEC(申泰)
    插件,P=2.54mm
    排母 间距:2.54mm 2x32P 直插
ESD-132-G-05 数据手册
F-215 SS–132–G–2 ESD–115–TT–05 (2,54 mm) .100" SS, SD, ESD, ESS, HSS SERIES PRECISION MACHINED SOCKET STRIPS Mates with: TS, TD, HTS, BBS, BBD, BBL, BDL, BHS TYPE STRIP NO. PINS PER ROW 1 PLATING OPTION LEAD STYLE OTHER OPTION OPTION SPECIFICATIONS –N For complete specifications see www.samtec.com?SS, www.samtec.com?ESS, www.samtec.com?SD, www.samtec.com?ESD or www.samtec.com?HSS Insulator Material: SS, SD, ESS, ESD= Black G.F. Polyester HSS= Black Liquid Crystal Polymer Contact: BeCu Shell: Brass except Style 5A Phosphor Bronze Plating: Au over 50µ" (1,27 µm) Ni or Sn over 50µ" (1,27 µm) Ni Operating Temp Range: -55°C to +125°C Contact Resistance: 10 mΩ Lead Size Range: (0,38 mm to 0,56 mm) .015" to .022" DIA and most IC leads Insertion Force: (Single contact only) Standard= 9 oz (2,50 N) avg., 16 oz (4,45 N) max Low Insertion Force= 2.5 oz (0,70 N) avg., 5.5 oz (1,53 N) max Withdrawal Force: (Single contact only) Standard= 2.5 oz (0,70 N) avg., 1.5 oz (0,42 N) min Low Insertion Force= 2.0 oz (0,56 N) avg., 0.35 oz (0,10 N) min Insertion Depth: (-05, -1X & -21X, -5A) (3,18 mm) .125" to (3,99 mm) .157" Insertion Depth: (-2, -22, -38) (2,41 mm) .095" to (3,68 mm) .145" RoHS Compliant: Yes Lead-Free Solderable: Wave only RECOGNITIONS –S 01 thru 32 = SS, ESS Series 01 thru 36 Add –L suffix for locking lead socket in end positions. Requires Style -2 or -22 and .035" ± .003 DIA board hole. = 30µ" (0,76 µm) Gold contact, Tin shell SS = Non Flush Locking Socket –T = HSS, SD & ESD Series (0,76) .030 REF (7,62) .300 (3,43) .135 –G HSS = Standard = High Temp Single Row Socket Single Row Socket = 30µ" (0,76 µm) Gold contact, 10µ" (0,25 µm) Gold shell ALSO AVAILABLE (MOQ Required) = Tin contact and shell (Styles 1, 2, 4, and 05 except LIF N/A) = Elevated Single Row Socket N/A Style –5A Requires -T Plating Option –TT ESS • Locking lead option on ESS and ESD series Contact Samtec. Styles – 5A & –05 socket heads not countersunk. (2,54) .100 x No. of Positions (2,54) .100 (2,54) .100 TYP –1A, –1B or –1C –03, –04, –05 For LIF specify –21A, –21B or –21C (SS, HSS, SD) For LIF specify –23 (ESS, ESD) (1,83) .072 DIA (2,54) .100 (4,90) .193 (1,32) .052 DIA ESD = Standard Double Row Socket = Elevated Double Row Socket (0,64) .025 SQ Style – 5A not available. Styles –5A & –05 socket heads not countersunk. LEAD STYLE Y –1A or –21A (9,14) .360 –1B or –21B (12,95) .510 –1C or –21C (6,60) .260 (0,76) .030 B A C (0,64) .025 SQ –2, –22*,–5A, or –38* *For LIF specify –22 or –38 (SS, HSS, SD) (2,54) .100 x No. of Positions (2,54) .100 (5,08) .200 (0,76) .030 Y SD For complete scope of recognitions see www.samtec.com/quality (1,83) .072 DIA (2,54) .100 TYP (2,54) .100 (0,76) .030 (1,32) .052 DIA Note: Some lengths, styles and options are non-standard, non-returnable. –L = 10µ" (0,25 µm) Gold contact, Tin shell (Styles 2 & 22 only) = X LIF= Low Insertion Force X LEAD STYLE DIA Z Y Y Z LEAD STYLE –2 or –22 (0,51) (3,18) (7,62) .020 .125 .300 05 –38 (0,51) (4,57) (8,89) .020 .180 .350 03 or 23 –5A (0,89) (12,95) (17,86) .035 .510 .703 04 Locking lead available. See OPTION. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. A B C (17,86) (13,46) (4,39) .703 .530 .173 (11,51) (8,38) (3,12) .453 .330 .123 (14,05) (10,92) (3,12) .553 .430 .123
ESD-132-G-05 价格&库存
很抱歉,暂时无法提供与“ESD-132-G-05”相匹配的价格&库存,您可以联系我们找货
ESD-132-G-05
  • 1+397.010991+51.52478
