SLIM BODY FLAT
RIBBON IDC CABLES
(2.54 mm) .100" PITCH • IDSS/IDSD/IDMS/IDMD SERIES
IDSS/IDMS/IDMD
Mates:
TSW, MTSW, TSM, EJH,
PHT, HMTSW, HTSW,
HW, DW, EW, ZW, MTLW
IDSD
SERIES
IDM
= Standard Tail Male Plug
IDS
Mates:
TST, HTST, ZST, EJH
= Socket
SPECIFICATIONS
Insulator Material:
Black Glass Filled Polyester
Contact (IDSS/IDSD):
BeCu
Terminal (IDMS/IDMD):
Phosphor Bronze
Plating:
Au over 50 µ" (1.27 µm) Ni or
Sn over 100 µ" (2.54 µm) Cu or
50 µ" (1.27 µm) Ni
Wire:
28 AWG 7/36 stranded
Tinned CopperWeb footer
Current Rating (IDMD):
3 A per pin
(2 pins powered)
Temperature Range:
-20 °C to +105 °C
(Rainbow Cable)
-40 °C to +105 °C
(Gray Cable)
Voltage Rating:
425 VAC/600 VDC
Lead Size Range:
(0.56 mm) .022" SQ to
(0.71 mm) .028" SQ
Lead Insertion Depth:
(5.59 mm) .220" to
(6.22 mm) .245"
ROW OPTION
NO. PINS PER ROW
S
–02 thru –32
D
–02 thru –36
= Single
= IDMS/IDMD
= Double
(Color coded cable Not available
for 31 thru 36 pins/row. See –G option.)
DOUBLE
Full size (64 positions): (82.55) 3.250
Less than 64 positions: No. Positions/row X (2.54) .100 + (1.68) .066
SINGLE
Full size (32 positions): (81.53) 3.210
Less than 32 positions: No. Positions/row X (2.54) .100 + (0.71) .028
= IDSS/IDSD
IDMS
(Single)
IDMD
(Double)
(2.54)
.100
(5.08)
.200
(For square or long tail see HCMX Series)
IDMX shown
DOUBLE
Full size (72 positions): (92.71) 3.650
Less than 72 positions: No. Positions/row x (2.54) .100 + (1.50) .059
SINGLE
Full size (36 positions): (91.69) 3.610
Less than 36 positions: No. Positions/row x (2.54) .100 + (0.48) .019
IDSS
(Single)
IDSD
(Double)
(5.08)
.200
(2.54)
.100
(9.27)
.365
REF
IDSX shown
ALSO AVAILABLE
Molded-To-Position
IDC Assembles
Low Profile
Skinny side locks
Dual beam contacts
Single and double row
(6.35mm) .025" square and
(5.84mm) .230" length tail available
Visit samtec.com?HCSD, samtec.com?HCSS,
samtec.com?HCMD or samtec.com?HCMS
for more detailed information.
Single End (—S)
Double End (—D)
Transfer End (—T)
Note:
This Series is non-standard,
non-returnable.
F-224
samtec.com?IDSS, samtec.com?IDSD, samtec.com?IDMS or samtec.com?IDMD
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
END ASSEMBLY
–S
ASSEMBLED LENGHTH
OPTION
–“XX.XX”
= Single End
(Socket or Male Plug on one end)
–T
= Assembled Length
–B “XX”
= Tin Plating
(Both Ends)
–D
= Breakout
(Specify “XX” as number of
conductors to be broken out)
(Breakout starts with Number 1 lead
indicated by brown wire or red stripe.
Shown on top side)
–C
= Double End
(Socket or Male Plug on each end)
= Tin IDM,
10 µ" (0.25 µm) Gold IDS
(-T End Assembly Required)
–T
–RW
–A
= Transfer End
(Male Plug on one end with socket on other.
Begin part number with IDM)
= Reverse Wiring
(#1 wire opposite position #1)
= Tin IDS,
10 µ"(0.25 µm) Gold IDM
–S “XX”
–P “XX”
=Polarized
Specify “XX” as position.
For Double the same position
will be polarized on both ends.
(Not available on IDM unless transfer,
then only the socket is polarized.)
= Daisy Chain, Single
(When mating double row
connector with two single row
connectors, the outer most single will
be connected to Conductor #1 and
the inside single to Conductor #2)
–D “XX”
= Daisy Chain, Double
–G
Assembled Length in
INCHES (±1/8" )
(2 inches minimum)
Assembled Length (—“XX.XX”)
72
04
02
71
03
01
Polarized (—P “XX”)
= Gray Cable
Specify –G for Gray cable.
Gray cable has one red edge.
IDSS and IDMS uses
(2.54 mm) .100" centerline cable.
IDSD and IDMD uses
(1.27 mm) .050" centerline cable.
Cable is 28 AWG 7/36 copper wire.
Standard cable is same as
above except color
–W “XX”
= Wiring Reverse Daisy Chain, Single
(Same as –S “XX” except outer strip
connected to Conductor #2 and inside
strip connected to Conductor #1)
–R
= Reversed
–M
= Middle Reversed
(Requires –SXX, –WXX or –DXX)
–ST “X”
= Stripped & Tinned
(Specify Suffix from table)
(All dimensions are ± 1/16" (1.59 mm)
(Not available in 28 positions and higher)
–O
= Outside Reversed
“XX” ± 1⁄8"
2"
min.
“XX”
–ST8
1
–ST4
1
–ST2
–ST3
Outer Most
/8" (3.18)
/4" (6.35)
/2" (12.70)
1
3
/8" (9.53)
Stripped & Tinned (—ST “X”)
Reversed (—R)
Double Row
Connectors
(IDSD or
IDMD)
5"max.
2"min.
Number 1 lead indicated
Shown on top side.
4" minimum
Daisy Chain SIngle (—S “XX”)
Breakout (—B “X”)
Middle Reversed (—M)
Outside Reversed (—O)
F-224
IDSS-06-D-12.00-T-R 价格&库存
很抱歉,暂时无法提供与“IDSS-06-D-12.00-T-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+46.303111+5.79146
