IDSS-14-S-06.00-T-ST8 数据手册
F-215
IDMD–24–D–12.00–G
(2,54 mm) .100"
SLIM BODY FLAT RIBBON IDC CABLES
SPECIFICATIONS
For complete specifications
see www.samtec.com?IDSS,
www.samtec.com?IDSD,
www.samtec.com?IDMS or
www.samtec.com?IDMD
Insulator Material:
Black Glass Filled Polyester
Plating:
Au over 50µ" (1,27 µm) Ni or
Sn over 100µ" (2,54 µm) Cu
or 50µ" (1,27 µm) Ni
Wire:
28 AWG 7/36 stranded
Tinned Copper
Temperature Range:
-20°C to +105°C
(Rainbow Cable)
-40°C to +105°C
(Gray Cable)
Contact (IDSS/IDSD):
BeCu
Terminal (IDMS/IDMD):
Phosphor Bronze
Current Rating (IDSD/TST):
3.4 A per pin
(1 position powered per row)
Current Rating (IDMD):
3 A per pin
Contact Resistance:
15 mΩ
Lead Size Range:
(0,56 mm) .022" SQ to
(0,71 mm) .028" SQ
Lead Insertion Depth:
(5,59 mm) .220" to
(6,22 mm) .245"
Insertion Force:
(Single contact only)
4 oz (1,11 N) avg.
((0,64 mm) .025" SQ probe)
Withdrawal Force:
3 oz (0,83 N) avg.
RoHS Compliant:
Yes
Mates with:
TSW, MTSW, TSM, EJH,
PHT, HMTSW, HTSW,
HW, DW, EW, ZW, MTLW
TYPE
STRIP
IDSD Mates with:
TST, HTST, ZST,
BST, EJH
ROW
OPTION
NO. PINS
PER ROW
END
ASSEMBLY
S
–S = Single
End
= Single
D
= Double
(Color coded
cable N/A for
31 thru 36
pins/row.
See –G
option.)
IDM
= Standard Tail Male Plug
IDS
= Socket
Socket or Male Plug on one end
–D = Double
End
–02 thru –32
DOUBLE
Full size (64 positions):
(82,55) 3.250
Less than 64 positions:
No. Positions/row X (2,54) .100 + (1,68) .066
IDMD
(Double)
IDMS
(Single)
Socket or Male Plug on each end
SINGLE
Full size (32 positions):
(81,53) 3.210
Less than 32 positions:
No. Positions/row X (2,54) .100 + (0,71) .028
(2,54)
.100
–T = Transfer
End
(5,08)
.200
(6,10)
.240
MAX
(0,48)
.019
(0,46)
.018
x
(0,48)
.019
(3,18)
.125
(2,54)
.100
(2,54)
.100
Male Plug on one end with socket on
other. Begin part number with IDM.
(For square or long tail see HCMX Series)
OTHER SOLUTIONS
RECOGNITIONS
–02 thru –36
For complete scope
of recognitions see
www.samtec.com/quality
DOUBLE
Full size (72 positions):
(92,71) 3.650
Less than 72 positions:
No. Positions/row x (2,54) .100 + (1,50) .059
SINGLE
Full size (36 positions):
(91,69) 3.610
Less than 36 positions:
No. Positions/row x (2,54) .100 + (0,48) .019
IDSS
(Single)
Molded-To-Position
IDC Assemblies
IDSD
(Double)
(5,08)
.200
(9,27)
.365
REF
(2,54)
.100
(0,76)
.030
SQ
(2,54)
.100
Note:
This Series is non-standard,
non-returnable.
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
Low profile
Skinny side locks
Dual beam contacts
Single and double row
(3,05 mm) .120"
and (5,84 mm) .230"
length tail
available
Call
Samtec
for HCXX
Series.
IDSD–05–D–04.25–S02
IDSD–24–S–05.00
IDSS, IDSD, IDMS, IDMD SERIES
ASSEMBLED
LENGTH
EJECTOR HEADERS
& LOCKING CLIPS
OPTION
IDSS or IDSD
STRIP ASSEMBLY
– “XX.XX”
• Locking clips
POLARIZING KEY
= Assembled Length
(0,64) .025
SQ
Assembled Length in
INCHES (±1/8" )
(2 inches minimum)
(5,84)
.230
LOCKING
CLIP
Optional polarizing key for
use with IDSS & IDSD
Series. Also polarizes
SSW, SSQ, ESW & ESQ
Series. Black High
Temperature Thermoplastic
.025" SQ
TERMINAL
STRIP (TSW)
PC
BOARD
See TSW Series.
Order: Part Number PK-01-06
(Available in wheels of six each)
Plating
–T = Tin
(Both ends)
Tin IDM
(0,25 µm) Gold IDS
–C = 10µ"
(-T End Assembly Required)
• Ejector headers
See EJH Series.
–ST “X”
–S “XX”
–R
= Stripped & Tinned
= Daisy Chain Single
= Reversed
Specify Suffix from table.
All dimensions are ± 1/16".
Not available in 28 positions and higher.
“XX” ± 1⁄8"
2"
min.
Single Row
Connectors
(IDSS)
(0,25 µm) Gold IDM
–A = 10µ"
Tin IDS
Standard plating is selective
gold over BeCu contact for IDS;
Selective gold over phosphor
bronze for IDM.
Outer Most
4" minimum
1
–P “XX”
=Polarized
72
04
–ST8
–ST4
–ST2
–ST3
1/8" (3,18)
1/4" (6,35)
1/2" (12,70)
3/8" (9,53)
4
–M
= Middle Reversed
7
–D “XX”
= Daisy Chain, Double
= Breakout
03
8
02
–B “XX”
71
When mating double row
connector with two single row
connectors, the outer most
single will be connected to
Conductor #1 and the inside
single to Conductor #2.
01
Specify “XX” as number of
conductors to be broken out.
Specify “XX” as position. For
Double the same position will
be polarized on both ends.
(Not available on IDM unless
transfer, then only the socket
is polarized.)
“XX” ± 1⁄8"
2"
min.
Double Row
Connectors
(IDSD or
IDMD)
Requires –SXX, –WXX or –DXX
8
–O
Outer Most
2
= Outside Reversed
“XX”
4" minimum
–G
5"max.
2"min.
= Gray Cable
Specify –G for Gray cable. Gray
cable has one red edge. IDSS
and IDMS uses .100" centerline
cable. IDSD and IDMD uses
.050" centerline cable. Cable is
28 AWG 7/36 copper wire.
Standard cable is same as
above except color coded.
Breakout starts with Number 1
lead indicated by brown wire or
red stripe. Shown on top side.
7
–W “XX”
–RW
Same as –S “XX” except outer
strip connected to Conductor
#2 and inside strip connected
to Conductor #1.
= Reversed Wiring
#1 wire opposite position #1.
3
= Wiring Reversed
Daisy Chain, Single
5
6
7
WWW.SAMTEC.COM
8
