IPS1-120-01-L-D-VS
IPS1-120-01-L-D-VS
    SAMTEC(申泰)
    SMD,P=2.54mm
    排母 间距:2.54mm 2x20P 立贴
IPS1-120-01-L-D-VS 数据手册
F-215 (Rev 25JUN15) IPS1–120–01–L–D–VS IPS1–125–01–L–D (2,54 mm) .100" IPS1 SERIES SHROUDED POWER CONNECTOR SET Mates with: IPT1 SPECIFICATIONS Each contact individually shrouded for electrical and mechanical protection For complete specifications see www.samtec.com?IPS1 Insulator Material: Black LCP Contact Material: Phosphor Bronze Plating: Sn or Au over 50µ" (1.27 µm) Ni Operating Temp Range: -55°C to +105°C with Tin; -55°C to +125°C with Gold Insertion Depth: (3.81 mm) .150" to (6.48 mm) .255" Wiping Distance: (0.38 mm) .015" Insertion Force (SMT): 3.0 oz (0.83 N) avg. Withdrawal Force (SMT): 2.6 oz (0.72 N) avg. Insertion Force (T/H): 6.0 oz (1.67 N) avg. Withdrawal Force (T/H): 5.0 oz (1.39 N) avg. Voltage Rating: 775 VAC/1095 VDC RoHS Compliant: Yes PINS 1 2 3 4 ALL Processing: IPT1/IPS1 CURRENT RATING (PER CONTACT) 5.9 A 4.8 A 4.1 A 3.6 A 2.3 A (4.70 mm) .185" Choice of Through-Hole or Surface Mount • Individually shrouded contacts • Locking clip option IPS1 1 NO. PINS PER ROW 01 PLATING OPTION Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.13 mm) .005" max (05-10) (0.15 mm) .006" max (15-25) Leave blank for Through-hole –L 05, 10, 15, 20, 25 RECOGNITIONS TAIL OPTION D = 10µ" (0.25 µm) Gold on contact, Matte Tin on tail (Standard sizes) For complete scope of recognitions see www.samtec.com/quality –VS = Surface Mount –RA = Right Angle No. of positions x (2.54) .100 + (0.38) .015 50 02 (4.95) .195 (2.54) .100 49 (2.54) .100 Through-hole • Other sizes • Other platings • Latching feature • No. 1 position polarized Contact Samtec. –LC = Locking Clip (Manual placement required) (–VS only) –K = (5.50 mm) .217" DIA Polyimide film Pick & Place Pad (–VS only) –TR = Tape & Reel Packaging (–VS only) 01 ALSO AVAILABLE (MOQ Required) OTHER OPTION Surface Mount (7.87) .310 (3.81) .150 (8.51) .335 (2.54) .100 (0.41) .016 (0.51) .020 (1.27) .050 (0.79) .031 (2.54) .100 –VS Note: Some sizes, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. (2.54) .100 –RA
IPS1-120-01-L-D-VS 价格&库存
很抱歉,暂时无法提供与“IPS1-120-01-L-D-VS”相匹配的价格&库存,您可以联系我们找货
IPS1-120-01-L-D-VS
  • 1+40.995371+5.28161
