SHROUDED
HEADER & STACKER
(2.00 mm) .0787" PITCH • LTMM/ZLTMM SERIES
LTMM/ZLTMM
Mates:
SQT, SQW, ESQT, SMM
-1
LTMM
04, 05,
06, 07,
08, 10, 12,
13, 15, 17,
20, 22, 25
SPECIFICATIONS
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +105 °C with Tin;
-55 °C to +125 °C with Gold
PROCESSING
- 02 -
NO. PINS
PER ROW
D
–F
TAIL
OPTION
–“XX”
= Polarized
Position
–RA
= Right-angle
–L
–SM
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
= Surface Mount
–T
–LC
= Locking Clip
(-SM only)
(Manual
placement
required)
–K
= Matte Tin
1RRISRVLWLRQV
OTHER
OPTION
Leave blank for
Through-hole
= Gold flash
on post,
Matte Tin on tail
(Standard sizes)
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max
PLATING
OPTION
= (7.50 mm)
.295" DIA Film
Pick &
Place Pad
(-SM only)
–TR
= Tape & Reel
(–SM only)
–FR
—TH
ALSO AVAILABLE
MOQ Required
Other sizes
Other plating
ZLTMM
-1
NO. PINS
PER ROW
—TH
—RA
—SM
04, 05,
06, 07,
08, 10, 12,
13, 15, 17,
20, 22, 25
LEAD
STYLE
Specify
LEAD
STYLE
from
chart
(Standard sizes)
PLATING
OPTION
–L
–T
(4.80)
.190
BODY
HEIGHT
(6.35)
B
(OAL) .250
MIN
(2.29)
.090
MIN
Note:
This Series is non-standard,
non-returnable.
F-224
D
–F
= Gold flash
on post,
Matte Tin on tail
= Matte Tin
(6.00)
.237
—RA
—SM
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
(2.00) .0787 x
No. of positions + (2.39) .094
= Full Reel
Tape & Reel
(must order
max. quantity
per reel;
contact Samtec
for quantity
breaks)
(–SM only)
BODY
HEIGHT
–“XXX”
= Body
Height
LEAD
STYLE
B
(OAL)
OTHER
OPTION
–“XX”
= Polarized
Position
MAX BODY
HEIGHT
–75
(9.58) 0.377
(7.42) 0.292
–62
(10.08) 0.397
(7.92) 0.312
–65
(10.49) 0.413
(8.33) 0.328
–73
(12.09) 0.476
(9.93) 0.391
–63
(14.10) 0.555
(11.94) 0.470
–66
(15.09) 0.594
(12.93) 0.509
–69
(15.60) 0.614
(13.44) 0.529
–74
(17.09) 0.673
(14.94) 0.588
–70
(17.60) 0.693
(15.44) 0.608
–71
(21.08) 0.830
(18.92) 0.745
–72
(21.62) 0.851
(19.46) 0.766
Note:
For added mechanical stability, Samtec recommends mechanical
board spacers be used in applications with gold or selective gold
plated connectors. Contact ipg@samtec.com for more information.
samtec.com?LTMM or samtec.com?ZLTMM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“LTMM-118-02-G-D-SM”相匹配的价格&库存,您可以联系我们找货
