PSIP-05V-LE
PSIP-05V-LE
    JST
    P=4mm
    1X5P
PSIP-05V-LE 数据手册
PSI CONNECTOR 4.0mm pitch/Disconnectable Crimp style connectors Wire-to-wire type Side entry type • Secure locking structure • Mis-mating prevention mechanism by keying (2 to 4 circuits/3 kinds of keying) • Finger-friendly design • Large electric current was realized. Specifications ––––––––––––––––––– Single type Double type • Current rating: 12 A AC, DC (Refer to the following table.) • Voltage rating: 300 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,500 VAC/minute • Applicable wire: AWG #26 to #16 * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. Note: The current rating differs depending on the number of circuits and the wire size used in each connector. The table below lists the current rating as a function of the number of circuits and the wire size. Current unit:A Top entry type Circuits 2 3 4, 5, 6, 8 10, 12 14 This PSI connector is designed for wire-toboard and wire-to-wire 4.0mm pitch connector. Low insertion force type contact is adopted and it provides excellent operability. This connector has the secure locking device that has the mechanism for preventing the inverse insertion. By adopting key shape and multi colors of housing, prevention function of mis-mating is considered. 1 # 16 # 18 12 11 10 9 9 10 9 8 7 7 Wire size (AWG) # 20 # 22 8 7 6 6 6 5 5 5 5 4.5 # 24 # 26 4 4 4 4 4 3 3 3 3 3 Note: Do not branch in parallel current which exceeds the rated current (e.g. more than 12 A in the case of 2 circuits with AWG #12). If branched in parallel, current imbalance or other problems may develop. If it is absolutely necessary to branch such a large current in parallel, design the circuits without causing any imbalance and provide an extra margin for each circuit. Standards –––––––––––––––––––––– 0 Recognized E 60389 1 Certified LR 20812 2 R50259465 PSI CONNECTOR Contact Top entry type ● Single type ● Double type 10 15.95 ±0.05 ±0.05 ±0.05 4.5 +0.1 0 17.8 φ1.3 φ1.3 1.65 ±0.05 4 ±0.05 1.65 A ±0.05 +0.1 0 17.8 +0.1 0 4.5 φ1.65 +0.1 0 5.95 φ1.65 ±0.05 4 ±0.05 A±0.05 Side entry type Wire-to-wire type 22.1 9.35 10.25 10 F ±0.05 +0.1 0 7.2 4±0.05 9 3 30.9 +0.1 0 +0.1 0 0.8 H ±0.05 3 ±0.05 9 ±0.05 φ1.7 φ1.65 4 ±0.05 ±0.05 +0.1 0 ±0.05 A±0.05 A ±0.05 φ1.65 +0.1 0 ±0.05 G 8.7 19.6 +0.1 0 φ1.7 +0.1 0 φ1.7 +0.1 0 Keying: A, B types φ1.7 +0.1 0 Keying: C type Circuits F 0.8 t 1.2 1.2 t 2.0 2 3 Note: 1. The above figure is the figure viewed from the connector mounting side 2. Tolerances are non-cumulative: ±0.05 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 13 17 13.3 17.3 G H Applicable panel thickness 9 13 6.8 8.4 0.8∼2.0 Socket contact Applicable wire mm2 AWG# Model No. SPSI-001T-M1.1 SPSI-41T-M1.1 0.13∼0.33 26∼22 1.3∼2.4 2,600 0.5 ∼1.25 20∼16 1.7∼3.2 2,600 11.3 6.5 2.2 Insulation O.D. (mm) Q’ty / reel Material and Finish 4 2.8 Copper alloy, tin-plated RoHS compliance Contact Crimping machine Crimp applicator MKS-L SPSI-001T-M1.1 AP-K2N SPSI-41T-M1.1   ―   MKS-L   ―   Applicator Dies Crimp applicator with dies MK/SPSI/M-001-11 APLMK SPSI/M001-11 ― ― MK/SPSI/M-41-11 APLMK SPSI/M41-11 ― ― 2 PSI CONNECTOR Socket housing Circuits Keying Top entry type A 2 B C B A A B 3 B C A A B C 14.9 14.9 10 15.95 4 5 — 6 — 8 — 10 — 12 — 14 — Model No. PSIP-02V-LE-A PSIP-02V-Y-B PSIP-02V-R-C PSIP-03V-LE-A PSIP-03V-Y-B PSIP-03V-R-C PSIP-04V-LE-A PSIP-04V-Y-B PSIP-04V-R-C PSIP-05V-LE PSIP-06V-LE PSIP-08V-LE PSIP-10V-LE PSIP-12V-LE PSIP-14V-LE Dimensions (mm) Q’ty / box A B 4.0 8.7 500 4.0 8.7 500 4.0 8.7 500 8.0 12.7 300 8.0 12.7 300 8.0 12.7 300 12.0 16.7 200 12.0 16.7 200 12.0 16.7 200 16.0 20.7 200 8.0 12.7 200 12.0 16.7 200 16.0 20.7 150 20.0 24.7 150 24.0 28.7 100 Material Glass-filled PBT, UL94V-0 RoHS compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. PSIP-02V-LE-A LE...light blue Y...yellow R...red Header Circuits Keying Top entry type A 2 B 9.1 B C A 12.35 3 B C A 4 B C φ1.1 4 1.65 3.7 □1.14 4.5 A 15.05 B 5 — 6 — 8 — 10 — 12 — 14 — Model No. B02B-PSILE-A1 B02B-PSIY-B1 B02B-PSIR-C1 B03B-PSILE-A1 B03B-PSIY-B1 B03B-PSIR-C1 B04B-PSILE-A1 B04B-PSIY-B1 B04B-PSIR-C1 B05B-PSILE-1 B06B-PSILE-1 B08B-PSILE-1 B10B-PSILE-1 B12B-PSILE-1 B14B-PSILE-1 Dimensions (mm) Q’ty / box A B 4.0 8.7 500 4.0 8.7 500 4.0 8.7 500 8.0 12.7 300 8.0 12.7 300 8.0 12.7 300 12.0 16.7 200 12.0 16.7 200 12.0 16.7 200 16.0 20.7 200 8.0 12.7 200 12.0 16.7 200 16.0 20.7 150 20.0 24.7 150 24.0 28.7 100 Material and Finish 12.35 Post: Copper alloy, copper-undercoated, tin-plated (reflow treatmnent) Header: Glass-filled PBT, UL94V-0 φ1.1 4 1.65 3.7 □1.14 4.5 5.95 Circuits Keying A A 2 B C Side entry type A 3 B B C 16.65 Model No. S02B-PSILE-A1 S02B-PSIY-B1 S02B-PSIR-C2 S03B-PSILE-A1 S03B-PSIY-B1 S03B-PSIR-C2 Dimensions (mm) Q’ty / box A B 4.0 8.7 350 4.0 8.7 350 4.0 8.7 350 8.0 12.7 200 8.0 12.7 200 8.0 12.7 200 3 □1.14 9 4 A 9.35 3.7 Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatmnent) Header: Glass-filled PBT, UL94V-0 RoHS compliance This product displays (LF)(SN) on a label. Note: Other kinds of post-omitted products are available. Contact JST for details. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 3 B02B-PSILE-A1 LE...light blue Y...yellow R...red PSI CONNECTOR Pin contact Applicable wire mm2 AWG# Model No. SPSM-001T-M1.1 SPSM-41T-M1.1 0.13∼0.33 26∼22 1.3∼2.4 2,600 0.5 ∼1.25 20∼16 1.7∼3.2 2,600 18 2.2 Insulation O.D. (mm) Q’ty / reel Material and Finish 6.6 4 Copper alloy, tin-plated 2.8 RoHS compliance Crimping machine Crimp applicator Contact MKS-L SPSM-001T-M1.1 Applicator Dies   ―   AP-K2N MKS-L SPSM-41T-M1.1 Crimp applicator with dies MK/SPSI/M-001-11 APLMK SPSI/M001-11 ― ― MK/SPSI/M-41-11 APLMK SPSI/M41-11   ―   ― ― Receptacle housing Circuits Keying A A 2 B A 3 C B Dimensions (mm) A B C Model No. PSIR-02V-LE-A PSIR-02V-Y-B PSIR-03V-LE-A PSIR-03V-Y-B Q’ty / bag 4.0 16.1 12.5 200 4.0 16.1 12.5 200 8.0 20.1 16.5 150 8.0 20.1 16.5 150 Material 9.1 Glass-filled PBT, UL94V-0 15.85 RoHS compliance 25.45 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B PSIR-03V-LE-A LE...light blue Y...yellow 8.45 Contact position location numbers Socket housing 5 4 3 2 14 13 12 11 10 9 8 7 2 1 1 Header Header ● Top entry ● Side entry 5 6 5 4 3 4 3 2 14 13 12 11 10 9 8 7 2 1 1 6 5 4 3 1 2 Receptacle housing 3 3 2 1 Single Double Single Double Single Single 4 PSI CONNECTOR Keying Socket housing Shape A type B type C type Mating part 2 circuits Model 3 circuits Blue No. 4 circuits PSIP-02V-LE-A PSIP-03V-LE-A PSIP-04V-LE-A Yellow PSIP-02V-Y-B PSIP-03V-Y-B PSIP-04V-Y-B PSIP-02V-R-C PSIP-03V-R-C PSIP-04V-R-C Red From 2 circuit to 4 circuit are applied. Header Top entry type A type Shape B type C type Mating part 2 circuits Model 3 circuits Blue No. 4 circuits B02B-PSILE-A1 B03B-PSILE-A1 B04B-PSILE-A1 Yellow B02B-PSIY-B1 B03B-PSIY-B1 B04B-PSIY-B1 B02B-PSIR-C1 B03B-PSIR-C1 B04B-PSIR-C1 Red From 2 circuit to 4 circuit are applied. Side entry type A type Shape B type C type Mating part Note) Boss Model 2 circuits Blue No. 3 circuits S02B-PSILE-A1 S03B-PSILE-A1 Yellow S02B-PSIY-B1 S03B-PSIY-B1 From 2 circuit to 3 circuit are applied. Note) Boss: Only C type boss position is reversed. Receptacle housing A type Shape S02B-PSIR-C2 S03B-PSIR-C2 Red B type Mating part Model 2 circuits No. 3 circuits Blue PSIR-02V-LE-A PSIR-03V-LE-A Yellow PSIR-02V-Y-B PSIR-03V-Y-B From 2 circuit to 3 circuit are applied. 5
PSIP-05V-LE 价格&库存
很抱歉,暂时无法提供与“PSIP-05V-LE”相匹配的价格&库存,您可以联系我们找货
PSIP-05V-LE
    • 200+0.60370
    库存:6654
    PSIP-05V-LE
      • 200+0.57750
      库存:3000
