QFSS-078-04.25-L-D-PC4
    SAMTEC(申泰)
    SMD,P=0.64mm
    板对板连接器 立贴 针脚数:164Pin 间距:0.64mm 排数:2
QFSS-078-04.25-L-D-PC4 数据手册
F-213 QFSS–078–04.25–L–D–A QFSS–052–04.25–L–D–PC4 TM (0,635 mm) .025" QFSS–026–04.25–L–D–A QFSS SERIES SHIELDED GROUND PLANE SOCKET SPECIFICATIONS Board Mates: QMSS For complete specifications and recommended PCB layouts see www.samtec.com?QFSS Cable Mates: 6QDPS Insulator Material: Liquid Crystal Polymer Contact, Ground Plane & Shield Material: Phosphor Bronze Plating: Au over 50µ" (1,27 µm) Ni (Tin on Ground Plane tails) Current Rating: Signal Contact: 1.8A per contact @ 80°C Power Contact: 3.95A per power contact @ 80°C Ground Plane: 8.9A per ground plane @ 80°C Voltage Rating: 300 VAC mated with QMSS Operating Temp: -55°C to +125°C RoHS Compliant: Yes Standard shield grounding is GSSSSG. Application Specific options available. Increased insertion depth for rugged application 11 mm Stack Height • Increased insertion depth • Integral guide post QMSS/QFSS Rated @ 3dB Type 11 mm Stack Height Insertion Loss* Single-Ended Signaling –D 6 GHz / 12 Gbps Differential Pair Signaling –D 7 GHz / 14 Gbps Differential Pair Signaling –D–DP 7.5 GHz / 15 Gbps *Performance data includes effects of a non-optimized PCB. Performance data for other stack heights and complete test data available at www.samtec. com?QFSS or contact sig@samtec.com (1,30 mm) .051" NOMINAL WIPE Single-Ended Signal routing. Processing: Lead–Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max (026-078) Board Stacking: For applications requiring more than two connectors per board, contact ipg@samtec.com QFSS APPLICATION –L –D (52 total pins per bank 40 signals + 12 grounds to shield = –D) = 10µ" (0,25 µm) Gold on Signal Pins, Shield and Ground Plane = Single-Ended –016, –032, –048 (16 pairs per bank = –D–DP) (11.00) .433 Note: Some lengths, styles and options are non-standard, non-returnable. OTHER OPTION = 4 Power Pins/End (N/A with –A) –D–DP = Differential Pair (Tin on Signal Pin tails, and Ground Plane tails) No. of Banks x (21,34) .840 + (1,02) .040 (2,10) .083 (21,34) .840 02 (8,13) .320 APPLICATIONS (0,635) .025 (0,23) .009 01 (0,89) .035 (0,10) .004 (7,06) .278 (1,02) .040 DIA (2,00) .07874 02 No. of Banks x (21,34) .840 + (12,87) .507 (7,44) .293 (8,13) .320 –D–DP QMSS A TYPE –026, –052, –078 –D QFSS PLATING OPTION 04.25 –PC4 APPLICATION SPECIFIC OPTION • Headers without Alignment Pins • 8 Power Pins/End • 4 or 8 Power Pins/End for (2,36 mm) .093" thick board • Guide Holes • Hot Pluggable • 64 (-DP) and 104 pins per row Call Samtec. PINS PER ROW NO. OF PAIRS 01 –PC4 OPTION WWW.SAMTEC.COM (2,54) .100 (1,78) .070 See SO Series for precision machined standoffs. (2,54) .100
QFSS-078-04.25-L-D-PC4 价格&库存
很抱歉,暂时无法提供与“QFSS-078-04.25-L-D-PC4”相匹配的价格&库存,您可以联系我们找货
  • 26+268.7459526+34.92422
