QSH-030-01-H-D-A-RT1-K 数据手册
QSH–090–01–F–D–RA–GP
F-219
QSH–060–01–L–D–RA
(0.50 mm) .0197"
QSH-RA SERIES
QSH–020–01–F–D–DP–RA
RIGHT-ANGLE GROUND PLANE SOCKET
SPECIFICATIONS
Board Mates:
QTH
For complete specifications and
recommended PCB layouts see
www.samtec.com?QSH-RA or
www.samtec.com?QSH-DP-RA
Insulator Material:
Black Liquid Crystal
Polymer
Terminal Material:
Phosphor Bronze
Weld Tab:
Phosphor Bronze
Ground Plane:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
Contact:
2.2 A per pin
(2 pins powered)
Ground Plane:
21.8 A per ground plane
(1 ground plane powered)
Operating Temp Range:
-55 °C to +125 °C
Voltage Rating:
220 VAC
RoHS Compliant:
Yes
Weld Tabs
Integral metal plane
for power or ground
PINS PER ROW
NO. OF PAIRS
QSH
Optional Guide
Post option
available
PLATING
OPTION
01
OTHER
OPTION
RA
TYPE
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (020-090)
–F
= Gold Flash
on contact,
Matte Tin on tails
–030, –060, –090
–D = (60 total pins per bank)
–L
–020, –040, –060
= 10 µ" (0.25 µm)
Gold contact,
Matte Tin on tails
–D–DP = (20 pairs per bank)
–GP
–D
= Guide Post
Holes
= SingleEnded
–D–DP
= Differential
Pair
–K
= (6.50 mm) .256"
DIA Polyimide film
Pick & Place Pad
A (with option -GP)
NO. OF PINS PER
PAIRS
ROW
B (without option -GP)
–020
(13.59)
.535
(7.11)
.280
(1.59) .063 DIA
–040
–060
–060
–090
01
(8.47)
.333
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
(0.30)
.012
(2.03)
.080
(0.15)
.006
02
(0.64)
.025
SQ
–GP OPTION SHOWN
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
–030
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
A
B
(30.80)
1.213
(50.80)
2.000
(70.80)
2.788
(25.72)
1.013
(45.72)
1.800
(65.72)
2.588
QSH-030-01-H-D-A-RT1-K 价格&库存
很抱歉,暂时无法提供与“QSH-030-01-H-D-A-RT1-K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 65+176.8526565+22.71176
