QTH-090-04-C-D-A
QTH-090-04-C-D-A
    SAMTEC(申泰)
    .5MM DOUBLE ROW MI SOCKET ASSEMB
QTH-090-04-C-D-A 数据手册
® RIGHT-ANGLE & EDGE MOUNT HIGH-SPEED GROUND PLANE CONNECTORS • Right-Angle and Edge Mount designs for coplanar and perpendicular mating • Q Strip® Right-Angle High-Speed Connectors on 0.50 mm & 0.635 mm pitches • Q2™ Right-Angle & Edge Mount Rugged High-Speed Connectors on 0.635 mm pitch • Q Rate® Right-Angle Slim Body High-Speed Connectors on 0.80 mm pitch • Visit samtec.com/QSeries for complete specifications and ordering information Q STRIP ® HIGH-SPEED GROUND PLANE CONNECTORS (0.50 mm) .0197" PITCH RIGHT-ANGLE GROUND PLANE HEADERS & SOCKETS QTH-RA Board Mates: QSH SERIES - QTH –030, –060, –090 Header QSH-RA - 01 - PINS PER ROW NO. OF PAIRS –D = (60 total pins per bank) QSH –020, –040, –060 Socket –D–DP = (20 pairs per bank) Board Mates: QTH PLATING - TYPE –F = Gold Flash on contact, Matte Tin on tails –L - RA - –D = Single-Ended –D–DP OTHER OPTION –PGP = Plastic Guide Post (QTH only) –GP = Differential Pair = 10 µ" (0.25 µm) Gold contact, Matte Tin on tails =Guide Post Holes (QSH only) –K = Polyimide film Pick & Place Pad View complete specifications at: samtec.com?QTH-RA or samtec.com?QSH-RA (0.635 mm) .025" PITCH RIGHT-ANGLE GROUND PLANE HEADERS & SOCKETS QTS-RA Board Mates: QSS SERIES QTS Header QSS-RA Board Mates: QTS QSS Socket - POSITIONS PER ROW –025, –050, –075 (50 total Positions per bank) - 01 - PLATING - D - RA - –F = Gold Flash on Signal Pins and Ground Plane, Matte Tin on tails WT –WT = Weld Tab (N/A with -025 Positions) - OTHER OPTION –L = 10 µ" (0.25 µm) Gold on Signal Pins and Ground Plane, Matte Tin on tails Cable Mates: SQCD Note: Some lengths, styles and options are non-standard, non-returnable. F-224 –SP = Solder Pin (QTS only) View complete specifications at: samtec.com?QTS-RA or samtec.com?QSS-RA samtec.com/QSeries Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
QTH-090-04-C-D-A 价格&库存
很抱歉,暂时无法提供与“QTH-090-04-C-D-A”相匹配的价格&库存,您可以联系我们找货
