SCRES-G-01.00-BC-C5E
    SAMTEC(申泰)
    ACCLIMATE IP68 SEALED CIRCULAR
SCRES-G-01.00-BC-C5E 数据手册
IP68 SEALED USB & ETHERNET SCRUS/SCRES SERIES SCRUS Mates wtih: SCPU SCRUS - - SHELL SIZE –17 SPECIFICATIONS –G (Standard USB only) Insulator Material: PBT Contact Material: Phosphor Bronze Wire: 20 AWG (Power) 25 AWG (Signal) 28 AWG (Drain) O-Ring: Silicone Operating Temp Range: -20 °C to +75 °C PLATING = 30 µ" (0.76 µm) Gold on Contact, Nickel on Shell - WIRE LENGTH - - END 1 OPTION –00.25 –AMS = (0.25 m) 9.84" Cable –AM = USB A Type, Sealed –00.50 = USB A Type, Not Sealed –BMS = (0.50 m) 19.68" Cable END 2 OPTION –BM = USB B Type, Sealed = USB B Type, Not Sealed –MB Standard lengths = Mini USB B Type, Not Sealed (Assembled Length = Wire Length + (37.9 mm) 1.50") –BC = Blunt Cut (48.45) 1.907 (39.50) 1.55 DIA –BMS SCRES Mates with: SCPE SPECIFICATIONS Insulator Material: PBT Contact Material: Phosphor Bronze Shield Material: Phosphor Bronze Wire: 24 AWG O-Ring: Silicone Overmold: PA66 Current Rating: 3.8 A per pin (1 pin powered) Operating Temp Range: -40 °C to +70 °C SCRES DUST CAP –AMS - PLATING –G = 50 µ" (1.27 µm) Gold on Contact, Nickel on Shell) - WIRE LENGTH - –00.25 = (0.25 m) 9.84" Cable –00.50 END OPTION –D = Double Ended = (0.50 m) 19.68" Cable - C5E –C5E = Cat 5e rating –BC = Blunt Cut Standard lengths Assembled Length = Wire Length + (12.70) .50 (48.45) 1.907 –D SHOWN Note: Some lengths, styles and options are non-standard, non-returnable. Dust cap: DCA-17-03 (USB Flash Drive Cover) –AMS END NO. 1 END NO. 2 DUST CAP & PANEL PLUG Dust cap: DCA-17-01 Panel Plug: SCPPA-17-01 samtec.com?SCRUS or samtec.com?SCRES samtec.com/AccliMate F-224225 WEB Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
SCRES-G-01.00-BC-C5E 价格&库存
很抱歉,暂时无法提供与“SCRES-G-01.00-BC-C5E”相匹配的价格&库存,您可以联系我们找货
  • 1+1390.61036
  • 10+1316.45624
  • 25+1266.99195
  • 50+1236.03898
  • 100+805.16403
  • 250+661.48665
库存:473
